DemoGeek Posted June 1, 2020 #1 Posted June 1, 2020 Trying to following this from other post to edit the grub.cnf from installed system (DS918+ / 6.2.3-25426) BUT getting error admin@your_DS:~$ sudo -i Password: root@your_DS:~# mkdir -p /tmp/synoboot_part0 root@your_DS:~# cd /dev root@your_DS:/dev# mount -t vfat synoboot1 /tmp/synoboot_part0 <=== mount: special device synoboot1 does not exist root@your_DS:/dev# ls /tmp/synoboot_part0 bzImage EFI grub info.txt root@your_DS:/dev# cd /tmp/synoboot_part0/grub #edit drub.cfg with mc or nano Any help is greatly appreciated! Quote
flyride Posted June 1, 2020 #2 Posted June 1, 2020 # cd /dev # mount synoboot1 /tmp/synoboot_part0 Now if your synoboot doesn't exist because you need to implement FixSynoboot.sh, that's an entirely different problem. # ls /dev/synoboot* /dev/synoboot /dev/synoboot1 /dev/synoboot2 Quote
DemoGeek Posted June 1, 2020 Author #3 Posted June 1, 2020 May be I am wrong but I see same error on the both DS918+ (DS918+ / 6.2.3-25426) - and DS3617 on latest 6.2.3 - 25426. Both are fresh installs and not sure how to go about Fixsynoboot.sh. Thanks for your quick reply though! Quote
DemoGeek Posted June 1, 2020 Author #5 Posted June 1, 2020 That did it!!!! Thanks so much.... Kind Regards, Quote
