petersonal Posted December 20, 2019 #1 Posted December 20, 2019 Dear all! I am using xigmanas now, booting and running the system from pendrive. Is this possible, with this OS? Quote
0 CyberSardinha Posted December 20, 2019 #2 Posted December 20, 2019 Yes it is Possible. That's what most people do Quote
0 petersonal Posted December 20, 2019 Author #3 Posted December 20, 2019 Thank you. I will work with this tutorial, is this still valid? Quote
0 CyberSardinha Posted December 20, 2019 #4 Posted December 20, 2019 That's what i used... I can do up to 6.2.1 but for some reason 6.2.2 is crasching on my system Quote
0 petersonal Posted December 20, 2019 Author #5 Posted December 20, 2019 I can not even wirte the pendrive, at frist attempt, i got blue screnn computer crashed...secound time I tryed to write with rufus, still failing the write procedure. Some questions: mac1 should be the target nas hardware ethernet port, right? there sn part, i just generated some from ds916+ and i am using v1.03b / ds2615 found here: https://mega.nz/#F!yQpw0YTI!DQqIzUCG2RbBtQ6YieScWg!TM4QVAob - is this correct? Quote
0 CyberSardinha Posted December 20, 2019 #6 Posted December 20, 2019 the mac1 is the mac address from your network card I would use the ds918+ because for 6.2 the ds3615 you need to have an Intel e1000e NIC. try with the 1.04b Quote
0 bearcat Posted December 25, 2019 #7 Posted December 25, 2019 @petersonal The more precise answer: Yes, you can boot and install the OS from an USB stick, but the OS itself will be installed on all your HDD's. The USB stick will then only be used for booting your system, since it will have the "bootimage" that emulates the HW chosen. (DS3615xs being the most compatible without adding extra drivers or hardware). Quote
petersonal
Dear all!
6 answers to this question
