pmcnano Posted August 25, 2014 #1 Posted August 25, 2014 Hello! After replacing (growing) my SHR Raid from 4 x 3TB HDD's to 2 x 4TB + 2 x 3TB I got "System partition failed" in both 3tb's drives. Theres a repair button in the storage manager, however I get a blank pop-up that says "ok" and nothing happens. Any clue? Is there any way to repair this manually?
Dfds Posted August 26, 2014 #2 Posted August 26, 2014 How did you try to expand the volume? Are you getting any messages in the logs? Can you post some screen shots.
pmcnano Posted August 28, 2014 Author #4 Posted August 28, 2014 Hello, as Poechi said, I replaced one, repaired, completed repair then turn off again, replaced the second one, repair. Everything works fine but I still got that message and I cant seem to fix the system partition. No relevant message in the logs, is there any other log I should check? like in telnet or something? I might just redo the whole setup, just have to buy a 4TB drive to backup everything. Paul
