Knulen Posted November 1, 2019 #1 Posted November 1, 2019 (edited) Hello, I'm new here. I'm a student and I was thinking of buying a cheap second hand 1-bay Synology as a backup nas, but I also have an Dell Optiplex 745 USFF here and I was wondering if I could also just use this one with XPEnology? The specifications can be found here: https://www.dell.com/downloads/global/products/optix/en/opti_745techspecs.pdf (last column) I read I could use a Q6600, so I could put that one in because I have one laying around somewhere. I've also found these topics: The normal Optiplex 745 is mentioned here Where @Hostilian mentioned the 745 Edited November 1, 2019 by Knulen Quote
IG-88 Posted November 1, 2019 #2 Posted November 1, 2019 the cpu would be no problem, the original ds 3615xs came with 4GB but might work with less look if you can set sata to ahci in bios, if its ahci then a recent 6.1/6.2 install seems possible safe would be to try 5.2 or 6.0 (6.0 still has all the sata/pata drivers the 6.1/6.2 is lacking) Quote
Knulen Posted November 4, 2019 Author #3 Posted November 4, 2019 It seems there is no option for AHCI so I'll give 6.0 (or if that doesn't work, 5.2) a try. But I'm really new to this. Is there a full noob-proof guide to install 6.0 and where to get the right files from? Quote
Knulen Posted November 4, 2019 Author #4 Posted November 4, 2019 (edited) I'm trying to follow this guide, but I need a mac adres that is coupled with the serial number? https://github.com/XPEnology/JunLoader/wiki/Installing-DSM-6.0-Bare-Metal#2-editing-the-configuration The link to the generator is faulty so I used this one: https://xpenogen.github.io/serial_generator/index.html But I still need a mac adres that is coupled to this serial number? ( serched for it but couldn't find one that also makes a mac address. Only one that states it doesn't work for XPEnology and one where I have to download a file from a sketchy site) edit: or is the mac address just the real mac address of the computer? edit2: I think I should just use the real MAC address of the computer. But I can't test it because the computer won't connect to this network (it's a protected network) so I'll try to do this at home later. Edited November 4, 2019 by Knulen Quote
IG-88 Posted November 4, 2019 #5 Posted November 4, 2019 for just hte nas base the only usb vid/pid is to set mac, and san can be used later in the grub.cfg and are used for special things like quickconnect, some plugins or codec licensing so no need for now you usually use the real mac if our nic to get WOL working, but thats optional if you dint need wol or want to use it later, just for testing its not important Quote
