GatekeeperZA Posted June 19, 2014 #1 Posted June 19, 2014 Ok please can someone help. I noticed something strange. When the power fails and my ups kicks in my system does not shut down. is this normal and if so how do I enable it to shutdown when running on ups... ? This happens on all 3 my microservers 2 on different ups'es any clarity or workaround would be great.
anthonyuk Posted June 20, 2014 #2 Posted June 20, 2014 My understanding is that when the UPS reaches a low battery point then the Diskstation unmounts all volumes and stops all services. I'm still on 4.2 so in later versions it may have changed but I see no option to shutdown, only by using the option to shut down the UPS.
GatekeeperZA Posted June 20, 2014 Author #3 Posted June 20, 2014 ok so it wont "turn off the system" it will stay on but unmount and stop services ..? is that correct .. ?
XPEH Posted June 21, 2014 #4 Posted June 21, 2014 ok so it wont "turn off the system" it will stay on but unmount and stop services ..? is that correct .. ? As Synology words it: "DiskStation enters Safe Mode"
