Trantor Posted December 15, 2013 Share #1 Posted December 15, 2013 This is not an official synology product This is only design for testing purpose not for production. No warranty for any damages, loss of data or anything else. This is based on jukolaut's work. Create the virtual machine in esxi and add hardware: - IDE controller with single harddisk (vmdk file in archive). Boot from this. - PVSCSI controller and raw harddisks or vmdk files for data. - VMXNET3 / E1000 network. - Boot, install the pat file with Synology Assistant, Enjoy Version 1.2 is now available : http://xpenology.trantor.be/esxi/ (please click on ad to help me with this project) To install open-vm-tools : Install the provided .spk with the package center (thank gnoboot) To install bootstrap : Connect to ssh as root, and type : sh syno-i686-bootstrap_1.2-7_i686.xsh then reboot How to install optware bootstrap and open-vm-tools (old method) (thanks to Tuatara) Changelog: v1.2 (15/03/2014) - Update to 4.3-3827 build - Use *REAL* mac adresses (thank gnoboot) - Change the default serial number (edit grub.conf to change it) - Add PS2 keyboard support (you can now write in the esxi console) - NFS and CIFS mount working - iSCSI (block & regular) in iet mode working (For regular mode, LUN must be created with advanced LUN features disabled) - Update mpt2sas to v18 - Sound drivers included - HBA drivers are included (install DSM on a HBA is not supported) v1.1 (22/12/2013) - Fix NFS support (copy modules to /lib/modules) v1 (15/12/2013) - Patch kernel source with jukolaut fix to get VMware PVSCSI working - Patch synobios to prevent SYNOIO messages - Build special ESXi kernel - All drivers included in standard version are also present here except SATA ones Quote Link to comment Share on other sites More sharing options...
costib Posted December 15, 2013 Share #2 Posted December 15, 2013 Thanks, I'll try it later this evening. download link is down "410 - Gone" Quote Link to comment Share on other sites More sharing options...
ad911 Posted December 15, 2013 Share #3 Posted December 15, 2013 Thanks, I'll try it later this evening. download link is down "410 - Gone" I have downloaded the file without any problem Quote Link to comment Share on other sites More sharing options...
Trantor Posted December 15, 2013 Author Share #4 Posted December 15, 2013 Thanks, I'll try it later this evening. download link is down "410 - Gone" Like all my links, they are valid only for 60sec (to prevent leech). Just refresh the page and "quickly" click on the link . Quote Link to comment Share on other sites More sharing options...
Djey Posted December 15, 2013 Share #5 Posted December 15, 2013 Oh yeah! Thanks a lot Trantor Quote Link to comment Share on other sites More sharing options...
costib Posted December 15, 2013 Share #6 Posted December 15, 2013 Since the release of your first ESXi version "3211_repack-trantor_v1.2a_beta2a", the main VM was in production without any problems, thanks! Installed now a test VM with this version, looks good, no problems so far (no more error after installation, which was gone after reboot, with this version). I plan to keep testing it for some time, to see if it's reliable enough. If everything goes well, I hope to replace the 3211 version in the following weeks, with the next ESXi release of 4.3. Luckily until then maybe we have the working vm-tools (the only important thing missing until now) and also the last official update included. Once again, many thanks Trantor. You gave us a nice present for this Christmas PS: The patience has paid off Quote Link to comment Share on other sites More sharing options...
tantonsen Posted December 16, 2013 Share #7 Posted December 16, 2013 (edited) Now i get timeout Creating NFS share? My HDD temp reboot problem is gone though. netstat -tulpn | grep 2049 Gives me insmod: can't insert '/lib/modules/auth_rpcgss.ko': No such file or directory Edited December 16, 2013 by Guest Quote Link to comment Share on other sites More sharing options...
myhtpc Posted December 16, 2013 Share #8 Posted December 16, 2013 Hi Trantor, thanks a lot for all your efforts. It's amazing how you take care on all our interests. One quick question: Do you have any idea on timing for the VM-Tools? Thanks myhtpc Quote Link to comment Share on other sites More sharing options...
laikei Posted December 16, 2013 Share #9 Posted December 16, 2013 Great work , I have install DSM4.3 without any error. Does anyone try install application ?? Its said cant connect, why ?? Thanks. Quote Link to comment Share on other sites More sharing options...
tantonsen Posted December 16, 2013 Share #10 Posted December 16, 2013 ^Package install does not work here too, does ur NFS work? Quote Link to comment Share on other sites More sharing options...
costib Posted December 16, 2013 Share #11 Posted December 16, 2013 Just tried now: "Connection failed. Please check your network settings" , and no apps are displayed. But adding 3rd party repository sources works . Quote Link to comment Share on other sites More sharing options...
myhtpc Posted December 16, 2013 Share #12 Posted December 16, 2013 couldn't add packages either. Same problem with connection Quote Link to comment Share on other sites More sharing options...
tantonsen Posted December 16, 2013 Share #13 Posted December 16, 2013 ^And NFS? Quote Link to comment Share on other sites More sharing options...
Trantor Posted December 16, 2013 Author Share #14 Posted December 16, 2013 Now i get timeout Creating NFS shareinsmod: can't insert '/lib/modules/auth_rpcgss.ko': No such file or directory I will look about this module. Just tried now: "Connection failed. Please check your network settings" , and no apps are displayed.But adding 3rd party repository sources works . This is strange because on my ESXi 5.5 package manager work and I can install apps... Does the console show anything ? Quote Link to comment Share on other sites More sharing options...
tantonsen Posted December 16, 2013 Share #15 Posted December 16, 2013 Now i get timeout Creating NFS shareinsmod: can't insert '/lib/modules/auth_rpcgss.ko': No such file or directory I will look about this module. Just tried now: "Connection failed. Please check your network settings" , and no apps are displayed.But adding 3rd party repository sources works . This is strange because on my ESXi 5.5 package manager work and I can install apps... Does the console show anything ? package Manager works now ... maybe there server was down?!? Quote Link to comment Share on other sites More sharing options...
myhtpc Posted December 16, 2013 Share #16 Posted December 16, 2013 Package Manager works on my side now as well. NFS doesn' Quote Link to comment Share on other sites More sharing options...
costib Posted December 16, 2013 Share #17 Posted December 16, 2013 I was not mistaking, immediately after installation, yesterday, I saw that Package Manager was working OK, that's why it was no problem on my side. Good that is is back online now. Quote Link to comment Share on other sites More sharing options...
Trantor Posted December 16, 2013 Author Share #18 Posted December 16, 2013 Like costib, I have seen Package Manager working during my test ^^ I will look for auth_rpcgss module for NFS support Quote Link to comment Share on other sites More sharing options...
ad911 Posted December 16, 2013 Share #19 Posted December 16, 2013 yes, the package manager server was down for a while Quote Link to comment Share on other sites More sharing options...
Trantor Posted December 16, 2013 Author Share #20 Posted December 16, 2013 auth_rpcgss is build-in the kernel so module. According /usr/syno/etc/rc.d/S83nfsd.sh we need : rpcsec_gss_krb5.ko, exportfs.ko and nfsd.ko. When we try to insmod exportfs.ko there is an error : invalid module format, on the xpenology console : duplicate symbole (own by kernel). Kernel need recompil to remove build-in exportfs. Does tNFS work on the standard build ? EDIT: I don't know how to get EXPORTFS=m because NFSD=m/y force EXPORTFS=y If someone know some kernel config voodoo magic ^^ Quote Link to comment Share on other sites More sharing options...
snake33 Posted December 16, 2013 Share #21 Posted December 16, 2013 Version 1 is now available : http://xpenology.trantor.be/esxi/ (please click on ad to help me with this project) Hello, thank you for the great work. What's it for? (XPEnology DS3612xs DSM 4.3 build 3810 (ESXi v1) Quote Link to comment Share on other sites More sharing options...
tantonsen Posted December 17, 2013 Share #22 Posted December 17, 2013 auth_rpcgss is build-in the kernel so module.According /usr/syno/etc/rc.d/S83nfsd.sh we need : rpcsec_gss_krb5.ko, exportfs.ko and nfsd.ko. When we try to insmod exportfs.ko there is an error : invalid module format, on the xpenology console : duplicate symbole (own by kernel). Kernel need recompil to remove build-in exportfs. Does tNFS work on the standard build ? EDIT: I don't know how to get EXPORTFS=m because NFSD=m/y force EXPORTFS=y If someone know some kernel config voodoo magic ^^ NFS works in XPEnology_DS3612xs_3810-repack-trantor-v1.0 in ESXI 5.5 Enabling NFS in XPEnology_DS3612xs_3810-repack-trantor-v1.0 The problem here is the missing ParaVirtual, under LSL logic SAS i get Disk overheating at random times, says 0`C not -1`C as the ESXI v1 version. Enabling NFS in Esxi V1 gives : Quote Link to comment Share on other sites More sharing options...
Trantor Posted December 17, 2013 Author Share #23 Posted December 17, 2013 The problem here is the missing ParaVirtual, under LSL logic SAS i get Disk overheating at random times, says 0`C not -1`C as the ESXI v1 version. Can you give more informations about this ? Quote Link to comment Share on other sites More sharing options...
tantonsen Posted December 17, 2013 Share #24 Posted December 17, 2013 (edited) The problem here is the missing ParaVirtual, under LSL logic SAS i get Disk overheating at random times, says 0`C not -1`C as the ESXI v1 version. Can you give more informations about this ? Yes.. When i run XPEnology_DS3612xs_3810-repack-trantor-v1.0 in ESXI 5.5, it loops (reboots with ParaVirtual) guessing a missing driver? When i tell it to use LSL Logic SAS as virtual SCSI, it boots, but under hard drive it shows disk temp at 0`C not -1 as we are used to, the real problem comes when the disk is used, if you tab back and forth between the disk info tabs, sometimes if you're lucky you can see disk temp suddenly jump from 0`C to maybe 66`C next refresh ( switching tabs) it says 0`C again, but after a random time ( 2 - 10 mins) DSM shutdown, Message says " disk drive overheating DSM shutting down" I think its becomes the incorrect temp has jumped over shutdown value in /usr/syno/etc.defaults/scemd.xml or /usr/syno/etc/scemd.xml file Disk temp jumping up and down, should be -1 ?? Was that the kind of info you where thinking about? Edited December 19, 2013 by Guest Quote Link to comment Share on other sites More sharing options...
tomtnt Posted December 18, 2013 Share #25 Posted December 18, 2013 is it possible to convert a regular n54l xpenology 4.3 build into an ESXi build without losing data on the data drives? I currently have 4 drives: 2x3gig, 2x2gig in a SHR array. How would I go about changing converting to an ESXi build? Quote Link to comment Share on other sites More sharing options...
