Cloud Sync Onedrive problem
GroupPolicy
I use it in a small office setting and it works with no problems.  I also have in synced to 2 different google drive accounts and all three work just fine.
Do you have the sync schedule turn on?  Does what's in the OneDrive cloud match whats on the NAS (more or less)?
Are you using OneDrive or Google Drive?  Because problem only onedrive, I have the exact same files that onedrive. You using 6.1.5 ?
