ziomekdjpl Posted May 5, 2017 #1 Posted May 5, 2017 Hey I have problem with transmission. I install it from http://packages.synocommunity.com. When i try to start it its failed. In dmesg i have: process terminated with status 1 I add account transmission with administrator rights, nothing change. anybody try to start this package?
firelord Posted May 5, 2017 #2 Posted May 5, 2017 I've added the repo to my 6.1.1 u1 but I don't see transmission in the list
ziomekdjpl Posted May 5, 2017 Author #4 Posted May 5, 2017 More info from LOG: 2017-05-05T13:50:47+02:00 serwer synoscgi_SYNO.Core.Package.Installation_1_install[17881]: resource_api.cpp:163 Acquire service-cfg for transmission when 0x0001 (done) 2017-05-05T13:50:49+02:00 serwer [ 1640.349913] init: pkgctl-transmission pre-start process (18079) terminated with status 1 2017-05-05T13:50:49+02:00 serwer synoscgi_SYNO.Core.Package.Control_1_start[17881]: servicecfg_internal_lib.c:187 Failed to start job [pkgctl-transmission][0xD900 privilege.cpp:60] 2017-05-05T13:50:50+02:00 serwer synoscgi_SYNO.Core.Package.Control_1_start[17881]: service_initjob_action.c:27 InitJobStart failed, [0xD900 privilege.cpp:60] 2017-05-05T13:50:50+02:00 serwer synoscgi_SYNO.Core.Package.Control_1_start[17881]: pkgstartstop.cpp:273 Failed to start pkgctl-transmission (err=-1) [0xD900 privilege.cpp:60] 2017-05-05T13:51:56+02:00 serwer transmission-daemon[18819]: Couldn't create "/usr/local/transmission/var//resume": Permission denied (file-posix.c:189) 2017-05-05T13:51:56+02:00 serwer transmission-daemon[18819]: Couldn't create "/usr/local/transmission/var//torrents": Permission denied (file-posix.c:189) 2017-05-05T13:51:56+02:00 serwer transmission-daemon[18819]: Couldn't create "/usr/local/transmission/var//blocklists": Permission denied (file-posix.c:189) 2017-05-05T13:51:56+02:00 serwer transmission-daemon[18819]: UDP Failed to set receive buffer: requested 4194304, got 425984 (tr-udp.c:84) 2017-05-05T13:51:56+02:00 serwer transmission-daemon[18819]: UDP Failed to set send buffer: requested 1048576, got 425984 (tr-udp.c:95) 2017-05-05T13:51:56+02:00 serwer transmission-daemon[18819]: Couldn't save temporary file "/volume1/@appstore/transmission/var/settings.json.tmp.NA5eg0": Permission denied (variant.c:1280) 2017-05-05T13:51:56+02:00 serwer transmission-daemon[18819]: Unable to save pidfile "/usr/local/transmission/var/transmission.pid": Permission denied (daemon.c:548) Never mind, its work again. First you need to make transmission account with admin groups. After that you install transmission
bm1555 Posted February 2, 2018 #5 Posted February 2, 2018 Follow this guide to install tranmission. working on DSM 6.1.4-15217 Update 5
