007revad Posted November 20, 2023 Share #1 Posted November 20, 2023 (edited) I'm trying to update my Synology_HDD_db script but I've been having issues getting E10M20-T1, M2D20 and M2D18 working in DS1823xs+, DS1821+ and DS1621+ in DSM 7.2-64570-U2 and later. These 3 models all use device tree, have 2 internal M.2 slots and do not officially support E10M20-T1, M2D20, M2D18 or M2D17. Setting the power_limit in model.dtb to 100 for each NVMe drive does not work for these models. The only way I can get more than 2 NVMe drives to work in DS1823xs+, DS1821+ and DS1621+ is to replace these 2 files with versions from 7.2-64570 (which I'd rather not do). /usr/lib/libsynonvme.so.1 /usr/syno/bin/synonvme And there are error messages in synoscgi.log, synosnmpcd.log and synoinstall.log With 3 NVMe drives installed the logs contain: nvme_model_spec_get.c:90 Incorrect power limit number 3!=2 With 4 NVMe drives installed the logs contain: nvme_model_spec_get.c:90 Incorrect power limit number 4!=2 I suspect that the DS1823xs+, DS1821+ and DS1621+ have the number of M.2 drives hard coded to 2 somewhere. If I restore these 2 files to the versions from 7.2.1-69057-U1 /usr/lib/libsynonvme.so.1 /usr/syno/bin/synonvme And add the default power_limit 14.85,9.075 the Internal M.2 slots show in storage manager and the fans run at normal speed. The "Incorrect power limit" log entries are gone, but synoscgi.log now contains the following for NVMe drives in the E10M20-T1: synoscgi_SYNO.Core.System_1_info[24819]: nvme_model_spec_get.c:81 Fail to get fdt property of power_limit synoscgi_SYNO.Core.System_1_info[24819]: nvme_model_spec_get.c:359 Fail to get power limit of nvme0n1 synoscgi_SYNO.Core.System_1_info[24819]: nvme_slot_info_get.c:37 Failed to get model specification synoscgi_SYNO.Core.System_1_info[24819]: nvme_dev_port_check.c:23 Failed to get slot informtion of nvme0n1 synoscgi_SYNO.Core.System_1_info[24819]: nvme_model_spec_get.c:81 Fail to get fdt property of power_limit synoscgi_SYNO.Core.System_1_info[24819]: nvme_model_spec_get.c:359 Fail to get power limit of nvme1n1 synoscgi_SYNO.Core.System_1_info[24819]: nvme_slot_info_get.c:37 Failed to get model specification synoscgi_SYNO.Core.System_1_info[24819]: nvme_dev_port_check.c:23 Failed to get slot informtion of nvme1n1 I get the default power_limit 14.85,9.075 for the DS1823xs+, DS1821+ and DS1621+ with: cat /sys/firmware/devicetree/base/power_limit | cut -d"," -f1 Apparently other models don't have /sys/firmware/devicetree/base/power_limit Edited November 20, 2023 by 007revad Quote Link to comment Share on other sites More sharing options...
tentacleskilt Posted November 23, 2023 Share #2 Posted November 23, 2023 You're having trouble installing more than two NVMe drives on your Synology DS1823xs+, DS1821+, or DS1621+ NAS. This is because these models have a hardcoded power limit of two NVMe drives. So I think there are two workarounds: Replace the two files /usr/lib/libsynonvme.so.1 and /usr/syno/bin/synonvme with the versions from DSM 7.2-64570-U2. Use a custom device tree to override the hardcoded power limit. That's all:) Quote Link to comment Share on other sites More sharing options...
007revad Posted November 23, 2023 Author Share #3 Posted November 23, 2023 Yep, I'm aware of the 14.85,9.075 power limit in /run/model.dtb and /sys/firmware/devicetree/base/power_limit I do edit the device tree already to add support for the E10M20-T1 or M2D20 or M2D18 With 3 NVMe drives installed if I set the power limit to 14.85,9.075,9.075 or 14.85,14.85,14.85 or 100,100,100 all the NVMe drives vanish from storage manager and the synoscgi.log shows "Incorrect power limit number 3!=2" With 4 NVMe drives installed if I set the power limit to 14.85,9.075,9.075,9.075 or 14.85,14.85,14.85,14.85 or 100,100,100,100 all the NVMe drives vanish from storage manager and the synoscgi.log shows "Incorrect power limit number 4!=2" So somewhere in 7.2-64570-U1 it knows there should not be more than 2 M.2 drives in a DS1823xs+, DS1821+, or DS1621+ The synoscgi.log shows: synoscgi_SYNO.Storage.CGI.Storage_1_load_info[32509]: nvme_dev_is_u2_slot.c:31 Failed to get slot informtion of /dev/nvme2n1 synoscgi_SYNO.Storage.CGI.Storage_1_load_info[32536]: nvme_model_spec_get.c:90 Incorrect power limit number 3!=2 synoscgi_SYNO.Storage.CGI.Storage_1_load_info[32536]: nvme_model_spec_get.c:164 Fail to get power limit of nvme2n1 synoscgi_SYNO.Storage.CGI.Storage_1_load_info[32536]: nvme_slot_info_get.c:37 Failed to get model specification synoscgi_SYNO.Storage.CGI.Storage_1_load_info[32536]: nvme_dev_is_u2_slot.c:31 Failed to get slot informtion of /dev/nvme2n1 I would rather my Synology_HDD_db script did not have to resort to using older versions of nvme and libsynonvme.so.1 because the script is used by @AuxXxilium and @Peter Suh and maybe other xpenology devs. synonvme in DSM 7.2-64570-U1, U2, U3 and 7.2.1-69057-U1 are the same but include power_limit synonvme 7.2-64570 ef36da23c30c17aeef6af943a958a124 synonvme 7.2-64570-U1 97d51425e6ac48ce1ed5fafd8810d359 synonvme 7.2-64570-U2 97d51425e6ac48ce1ed5fafd8810d359 synonvme 7.2-64570-U3 97d51425e6ac48ce1ed5fafd8810d359 synonvme 7.2.1-69057-U1 97d51425e6ac48ce1ed5fafd8810d359 libsynonvme.so.1 in DSM 7.2-64570-U1, U2 and U3 are the same but 7.2.1-69057-U1 is different: libsynonvme.so.1 7.2-64570 2b41e149acdb7281f6145f9fae214285 libsynonvme.so.1 7.2-64570-U1 1726d502a568c0843d43a2d95bcc6566 libsynonvme.so.1 7.2-64570-U2 1726d502a568c0843d43a2d95bcc6566 libsynonvme.so.1 7.2-64570-U3 1726d502a568c0843d43a2d95bcc6566 libsynonvme.so.1 7.2.1-69057-U1 b4f3463cf353978209171b5fc5a4bc2c Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted November 24, 2023 Share #4 Posted November 24, 2023 (edited) Models that inevitably require modification of libsynonvme.so.1 and are limited to only 1 or 2 mountable nmves are also clearly shown in rr's script that references my nvme-cache. https://github.com/PeterSuh-Q3/tcrp-addons/blob/main/nvme-cache/src/install-nvme-cache.sh https://github.com/wjz304/rr-addons/blob/main/nvmecache/all/usr/bin/nvmecache.sh DS918+ RS1619xs+ DS419+ DS1019+ DS719+ DS1621xs+ Limited to the 6 models above. If you look at the contents of the file with an actual hex editor, this model name and the PCIE address of the specified genuine product are recorded. Other models depend on device tree configuration or configuration in the extensionPorts file. Adjust to recognize nvme cache in these three types. 1823xs+, DS1821+ and DS1621+ are device tree based models, so the libsynonvme.so.1 file is not involved. If you consider it complexly rather than simply distinguishing it, confusion can arise. Edited November 24, 2023 by Peter Suh 1 Quote Link to comment Share on other sites More sharing options...
007revad Posted November 24, 2023 Author Share #5 Posted November 24, 2023 Thanks @Peter Suh. I've got it working now. I had a look at some other Synology model's DSM 7.2.1 device tree and noticed they also have a power limit for the M2 cards. Previously I only knew about the global power limit for built-in M.2 slots. 1 Quote Link to comment Share on other sites More sharing options...
tentacleskilt Posted November 30, 2023 Share #6 Posted November 30, 2023 On 11/24/2023 at 2:34 PM, Peter Suh said: Models that inevitably require modification of libsynonvme.so.1 and are limited to only 1 or 2 mountable nmves are also clearly shown in rr's script that references my nvme-cache. https://github.com/PeterSuh-Q3/tcrp-addons/blob/main/nvme-cache/src/install-nvme-cache.sh https://github.com/wjz304/rr-addons/blob/main/nvmecache/all/usr/bin/nvmecache.sh DS918+ RS1619xs+ DS419+ DS1019+ DS719+ DS1621xs+ Limited to the 6 models above. If you look at the contents of the file with an actual hex editor, this model name and the PCIE address of the specified genuine product are recorded. Other models depend on device tree configuration or configuration in the extensionPorts file. Adjust to recognize nvme cache in these three types. 1823xs+, DS1821+ and DS1621+ are device essay tree based models, so the libsynonvme.so.1 file is not involved. If you consider it complexly rather than simply distinguishing it, confusion can arise. Thx, this solution has helped me too) Blessing you! 1 Quote Link to comment Share on other sites More sharing options...
