2 hours ago, apriliars3 said:
How is the speed with your Gen 8?
It’s great! I’m getting the full 2.5gb. Though I have all ssd’s in it. I’ve got another that I just bought one for too. Didn’t need any drivers, just worked. I have a Qnap five port switch and 10gig network in my Mac mini. Was a leap of faith, but I’m happy and hope it helps someone else. I tried with a usb network adapter, but it was flakey.
  • Like 2
  • 6 months later...
On 9/10/2023 at 12:32 PM, blue max said:
This one works on an HP Microserver Gen8 at least.
https://www.amazon.co.uk/gp/product/B0BG2CZTYC/ref=ox_sc_saved_image_1?smid=A1M3GLTR4UTMMM&th=1
The Nic-RTL8125B with the red heatsink (as there are multiple there.
Only really useful if you have moved to SSD's.
May I ask: Did you add it as an upgrade, or did you have to reinstall Xpenology? Which driver/package have you used?
  • 2 months later...
I'm curious as well as I'm in the process of upgrading to 2.5 gigabit on my main2.5Gb PCIe Network Card, NICGIGA 2.5
I have the card in my cart just waiting till Friday to purchase
