MrEze Posted August 25, 2023 Share #1 Posted August 25, 2023 I am having problems with media playback when using Jellyfin on Synology DSM 7.2. I get a "Playback Error: This client isn't compatible with the media and the server isn't sending a compatible media format." It seems to be something with the transcoding. If I turn off transcoding then my media will play. Previously, I did not have this problem. I was able to play with transcoding turned on, so I don't know what changed. Can anyone help me with this? Quote Link to comment Share on other sites More sharing options...
MrEze Posted August 27, 2023 Author Share #2 Posted August 27, 2023 Can anyone offer any suggestions on how to resolve this? Quote Link to comment Share on other sites More sharing options...
dj_nsk Posted August 28, 2023 Share #3 Posted August 28, 2023 В 26.08.2023 в 02:29, MrEze сказал: I am having problems with media playback when using Jellyfin on Synology DSM 7.2. I get a "Playback Error: This client isn't compatible with the media and the server isn't sending a compatible media format." It seems to be something with the transcoding. If I turn off transcoding then my media will play. Previously, I did not have this problem. I was able to play with transcoding turned on, so I don't know what changed. Can anyone help me with this? most likely, hw-transcoding is not working for you for some reason. try to check via SSH: ls /dev/dri you should get: "card0 renderD128" what are you using: DSM model and version, CPU/GPU? Quote Link to comment Share on other sites More sharing options...
MrEze Posted August 28, 2023 Author Share #4 Posted August 28, 2023 (edited) When I try to check using ssh ls /dev/dri, it says "no such file or directory". So not sure how to do this. I am using DSM 7.2-64570, CPU is AMD Ryzen 5700X and GPU is Nvidia T400. Edited August 28, 2023 by MrEze Quote Link to comment Share on other sites More sharing options...
MrEze Posted August 28, 2023 Author Share #5 Posted August 28, 2023 (edited) I am using Synology Model DS923+ Edited August 28, 2023 by MrEze Quote Link to comment Share on other sites More sharing options...
MrEze Posted August 28, 2023 Author Share #6 Posted August 28, 2023 (edited) Ok, I think I discovered part of the problem. The script I am using doesn't pass in --device to the docker container, so it can't transcode using HW acceleration. However when I add --device, I get an error saying that "Container Manager API has failed", and "Error gathering device information while adding custom device "/dev/dri/renderD128" no such file or directory". Here is the script I am using, but doesn't work because there is no /dev/dri directory on my system. docker run -d --name=jellyfin \ -v /volume1/docker/jellyfin/config:/config \ -v /volume1/docker/jellyfin/cache:/cache \ -v /volume1/MEDIA:/media \ --user 1026:100 \ --net=host \ --restart=unless-stopped \ --device /dev/dri/renderD128:/dev/dri/renderD128 \ --device /dev/dri/card0:/dev/dri/card0 \ jellyfin/jellyfin:latest If I remove the two "--device " then it will work without transcoding. I am using the DS923+ which I thought was able to transcode 4kstreams. Does anyone know how to fix this? Edited August 28, 2023 by MrEze Quote Link to comment Share on other sites More sharing options...
dj_nsk Posted August 30, 2023 Share #7 Posted August 30, 2023 В 28.08.2023 в 12:57, MrEze сказал: When I try to check using ssh ls /dev/dri, it says "no such file or directory". So not sure how to do this. I am using DSM 7.2-64570, CPU is AMD Ryzen 5700X and GPU is Nvidia T400. I don't think DS923+ can work with discrete graphics cards Quote Link to comment Share on other sites More sharing options...
MrEze Posted August 30, 2023 Author Share #8 Posted August 30, 2023 (edited) 2 hours ago, dj_nsk said: I don't think DS923+ can work with discrete graphics cards I made a mistake it is the DS920+, but I also tried using the DS1520+ and I get the same issue. Not sure if it has something to do with the loader I was using (tinycore-redpill.v0.9.5.0.m-shell.img). I had to use this loader because it was the only one that would install the DSM on my computer. I tried using arc-23.8.30.img and arpl-i18n-23.8.11.img, but neither of them would install the DSM. Edited August 30, 2023 by MrEze Quote Link to comment Share on other sites More sharing options...
dj_nsk Posted August 31, 2023 Share #9 Posted August 31, 2023 13 часов назад, MrEze сказал: I made a mistake it is the DS920+, but I also tried using the DS1520+ and I get the same issue. only DS918+ and DS920+ have HW-transcoding if there is a built-in iGPU Intel. See here. Quote Link to comment Share on other sites More sharing options...
dj_nsk Posted August 31, 2023 Share #10 Posted August 31, 2023 В 29.08.2023 в 05:08, MrEze сказал: ...to the docker container... You can use Jellyfin package directly in DSM, not needs the docker Quote Link to comment Share on other sites More sharing options...
haldi Posted November 6, 2023 Share #11 Posted November 6, 2023 (edited) AFAIK you can't pass through hardware to docker containers on Synology. Or was that the VMM? Btw. Nvidia drivers if you install ,Jellyfin nativ package. Edited November 6, 2023 by haldi Quote Link to comment Share on other sites More sharing options...
