Ozadozky Posted April 23, 2023 Share #1 Posted April 23, 2023 Hello everyone, I'm trying to install Xpenology 7.1 on an HPE ML110 G10 server, but I've been having some issues. The installation gets to the point of booting Tiny core, but after a while, the server reboots and I can't continue with the installation. I have tried installing in both Legacy and UEFI mode, but the results are the same. I've already tried several things, but nothing seems to work. Therefore, I would like to ask the community for help. It's funny, because I've already done this installation on ML110 G5 model servers with good results, but I don't know why it's failing on my newer model. Has anyone had a similar problem and found a solution? Is there anything I can try to do to fix this problem? I would appreciate any help or suggestions you can offer. Thank you very much in advance. Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 23, 2023 Share #2 Posted April 23, 2023 beside using another usb flash drive there would be trying arpl as loader https://github.com/fbelavenuto/arpl/releases if the hardware is new and untested try a rescue/live linux to boot a see if it runs without problems Quote Link to comment Share on other sites More sharing options...
