The system is: Jun's Loader v1.04b DS918+ v.6.2.3-25426 Update 3 (with extra.izma and extra2.izma, but it also worked with original .izma), MB Asus K31AN with J2900, 8GB DDR3, PCIe to Sata controller (ASM1061), included 2 x 4TB WD Purple - one in Sata to MB and one in PCIe to Sata controller, (both hdd "basic" and ext4).
bojidar13
Terribly slow data transfer speed via USB3.0.
bojo@NAS:/$ lsusb
|__usb1 1d6b:0002:0404 09 2.00 480MBit/s 0mA 1IF (Linux 4.4.59+ xhci-hcd xHCI Host Controller 0000:00:14.0) hub
|__1-2 05e3:0608:8537 09 2.00 480MBit/s 100mA 1IF ( ffffffd6ffffffa3ffffffebffffffcb) hub
|__1-2.1 f400:f400:1100 00 2.00 480MBit/s 500mA 1IF (SMI Corporation USB DISK FC160826094025E8YLXJ)
|__usb2 1d6b:0003:0404 09 3.00 5000MBit/s 0mA 1IF (Linux 4.4.59+ xhci-hcd xHCI Host Controller 0000:00:14.0) hub
|__2-1 058f:6387:0002 00 3.20 5000MBit/s 800mA 1IF (Alcor Intenso Speed Line 22050784010033)
bojo@NAS:/$ lsmod | grep xhci
etxhci_hcd 86330 0
xhci_pci 4650 0
xhci_hcd 104955 1 xhci_pci
usbcore 198691 22 asix,etxhci_hcd,r8152,plusb,usblp,uhci_hcd,rtl8150,mcs7830,usb_storage,aqc111,ohci_hcd,ehci_hcd,ehci_pci,usbhid,usbnet,pegasus,ax88179_178a,xhci_hcd,xhci_pci,cx82310_eth
bojo@NAS:/$ lspci -v | grep xhci
Kernel driver in use: xhci_hcd
bojo@NAS:/$ sudo dd bs=1M count=256 if=/dev/zero of=/volumeUSB1/test conv=fdatasync
256+0 records in
256+0 records out
268435456 bytes (268 MB) copied, 2.22498 s, 121 MB/s
bojo@NAS:/$ sudo dd bs=1M count=256 if=/volumeUSB1/test of=/test conv=fdatasync
256+0 records in
256+0 records out
268435456 bytes (268 MB) copied, 2.17114 s, 124 MB/s
mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Tue Dec 13 23:16:07 2022] EXT4-fs (md4): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Tue Dec 13 23:16:08 2022] init: dhcp-client (eth0) main process (8992) killed b y TERM signal
[Tue Dec 13 23:16:10 2022] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) D river
[Tue Dec 13 23:16:10 2022] Warning! ehci_hcd should always be loaded before uhci _hcd and ohci_hcd, not after
[Tue Dec 13 23:16:10 2022] ehci-pci: EHCI PCI platform driver
[Tue Dec 13 23:16:10 2022] uhci_hcd: USB Universal Host Controller Interface dri ver
[Tue Dec 13 23:16:10 2022] usbcore: registered new interface driver usblp
[Tue Dec 13 23:16:10 2022] usbcore: registered new interface driver usbhid
[Tue Dec 13 23:16:10 2022] usbhid: USB HID core driver
[Tue Dec 13 23:16:10 2022] input: USBDevice as /devices/pci0000:00/0000:00:14.0/ usb1/1-2/1-2.4/1-2.4:1.0/0003:0E8F:2517.0001/input/input4
[Tue Dec 13 23:16:10 2022] hid-generic 0003:0E8F:2517.0001: input: USB HID v1.10 Keyboard [USBDevice] on usb-0000:00:14.0-2.4/input0
[Tue Dec 13 23:16:10 2022] input: USBDevice as /devices/pci0000:00/0000:00:14.0/ usb1/1-2/1-2.4/1-2.4:1.1/0003:0E8F:2517.0002/input/input5
[Tue Dec 13 23:16:10 2022] Get empty minor:104
[Tue Dec 13 23:16:10 2022] hid-generic 0003:0E8F:2517.0002: input,hiddev0: USB H ID v1.10 Mouse [USBDevice] on usb-0000:00:14.0-2.4/input1
[Tue Dec 13 23:16:11 2022] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Tue Dec 13 23:16:11 2022] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Tue Dec 13 23:16:15 2022] iSCSI:target_core_rodsp_server.c:1027:rodsp_server_in it RODSP server started, login_key(086266a3c238).
[Tue Dec 13 23:16:15 2022] iSCSI:extent_pool.c:766:ep_init syno_extent_pool succ essfully initialized
[Tue Dec 13 23:16:15 2022] iSCSI:target_core_device.c:617:se_dev_align_max_secto rs Rounding down aligned max_sectors from 4294967295 to 4294967288
[Tue Dec 13 23:16:15 2022] iSCSI:target_core_lunbackup.c:361:init_io_buffer_head 512 buffers allocated, total 2097152 bytes successfully
[Tue Dec 13 23:16:15 2022] iSCSI:target_core_file.c:146:fd_attach_hba RODSP plug in for fileio is enabled.
[Tue Dec 13 23:16:15 2022] iSCSI:target_core_file.c:153:fd_attach_hba ODX Token Manager is enabled.
[Tue Dec 13 23:16:15 2022] iSCSI:target_core_multi_file.c:91:fd_attach_hba RODSP plugin for multifile is enabled.
[Tue Dec 13 23:16:15 2022] iSCSI:target_core_ep.c:786:ep_attach_hba RODSP plugin for epio is enabled.
[Wed Dec 14 07:38:18 2022] Loaded X.509 cert 'Synology Kernel Module Signing Cer tification Authority: 600839b5d127e0e11d817a31f0575d323a7c0e28'
[Wed Dec 14 07:38:18 2022] Loaded X.509 cert 'Synology kernel module signing key : 4646ce54489669338118a3b1286da156ac366fa5'
[Wed Dec 14 07:38:18 2022] page_owner is disabled
[Wed Dec 14 07:38:18 2022] AppArmor: AppArmor sha1 policy hashing enabled
[Wed Dec 14 07:38:18 2022] hctosys: unable to open rtc device (rtc0)
[Wed Dec 14 07:38:18 2022] Freeing unused kernel memory: 864K (ffffffff81879000 - ffffffff81951000)
[Wed Dec 14 07:38:18 2022] Write protecting the kernel read-only data: 8192k
[Wed Dec 14 07:38:18 2022] Freeing unused kernel memory: 520K (ffff88000157e000 - ffff880001600000)
[Wed Dec 14 07:38:18 2022] Freeing unused kernel memory: 200K (ffff8800017ce000 - ffff880001800000)
[Wed Dec 14 07:38:18 2022] ACPI: bus type USB registered
[Wed Dec 14 07:38:18 2022] usbcore: registered new interface driver usbfs
[Wed Dec 14 07:38:18 2022] usbcore: registered new interface driver hub
[Wed Dec 14 07:38:18 2022] usbcore: registered new interface driver ethub
[Wed Dec 14 07:38:18 2022] usbcore: registered new device driver usb
[Wed Dec 14 07:38:18 2022] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Drive r
[Wed Dec 14 07:38:18 2022] xhci_hcd 0000:00:14.0: xHCI Host Controller
[Wed Dec 14 07:38:18 2022] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 1
[Wed Dec 14 07:38:18 2022] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci vers ion 0x100 quirks 0x00009010
[Wed Dec 14 07:38:18 2022] xhci_hcd 0000:00:14.0: cache line size of 64 is not s upported
[Wed Dec 14 07:38:18 2022] hub 1-0:1.0: USB hub found
[Wed Dec 14 07:38:18 2022] hub 1-0:1.0: 6 ports detected
[Wed Dec 14 07:38:18 2022] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 2
[Wed Dec 14 07:38:18 2022] usb usb2: We don't know the algorithms for LPM for th is host, disabling LPM.
[Wed Dec 14 07:38:18 2022] hub 2-0:1.0: USB hub found
[Wed Dec 14 07:38:18 2022] hub 2-0:1.0: 1 port detected
[Wed Dec 14 07:38:18 2022] usbcore: registered new interface driver usb-storage
[Wed Dec 14 07:38:18 2022] VMware PVSCSI driver - version 1.0.5.0-k
[Wed Dec 14 07:38:18 2022] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:0 1:03 EST 2006)
[Wed Dec 14 07:38:18 2022] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
[Wed Dec 14 07:38:18 2022] Fusion MPT base driver 3.04.20
[Wed Dec 14 07:38:18 2022] Copyright (c) 1999-2008 LSI Corporation
[Wed Dec 14 07:38:18 2022] Fusion MPT SPI Host driver 3.04.20
[Wed Dec 14 07:38:18 2022] Fusion MPT misc device (ioctl) driver 3.04.20
[Wed Dec 14 07:38:18 2022] mptctl: Registered with Fusion MPT base driver
[Wed Dec 14 07:38:18 2022] mptctl: /dev/mptctl @ (major,minor=10,220)
[Wed Dec 14 07:38:18 2022] megasas: 06.808.16.00-rc1
[Wed Dec 14 07:38:18 2022] Fusion MPT SAS Host driver 3.04.20
[Wed Dec 14 07:38:18 2022] mpt3sas version 09.102.00.00 loaded
[Wed Dec 14 07:38:18 2022] rtc_cmos 00:00: RTC can wake from S4
[Wed Dec 14 07:38:18 2022] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0
[Wed Dec 14 07:38:18 2022] rtc_cmos 00:00: alarms up to one month, y3k, 242 byte s nvram
[Wed Dec 14 07:38:18 2022] usb 1-2: new high-speed USB device number 2 using xhc i_hcd
[Wed Dec 14 07:38:18 2022] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014.
[Wed Dec 14 07:38:18 2022] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000.
[Wed Dec 14 07:38:18 2022] Adaptec aacraid driver 1.2-1[41010]-ms
[Wed Dec 14 07:38:18 2022] GDT-HA: Storage RAID Controller Driver. Version: 3.05
[Wed Dec 14 07:38:19 2022] RocketRAID 3xxx/4xxx Controller driver v1.10.0
[Wed Dec 14 07:38:19 2022] isci: Intel(R) C600 SAS Controller Driver - version 1 .2.0
[Wed Dec 14 07:38:19 2022] Got empty serial number. Generate serial number from product.
[Wed Dec 14 07:38:19 2022] hub 1-2:1.0: USB hub found
[Wed Dec 14 07:38:19 2022] hub 1-2:1.0: 4 ports detected
[Wed Dec 14 07:38:19 2022] aic94xx: Adaptec aic94xx SAS/SATA driver version 1.0. 3 loaded
[Wed Dec 14 07:38:19 2022] synobios: load, major number 201
[Wed Dec 14 07:38:19 2022] Brand: Synology
[Wed Dec 14 07:38:19 2022] Model: DS-918+
[Wed Dec 14 07:38:19 2022] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Wed Dec 14 07:38:19 2022] synobios cpu_arch proc entry initialized
[Wed Dec 14 07:38:19 2022] synobios crypto_hw proc entry initialized
[Wed Dec 14 07:38:19 2022] synobios syno_platform proc entry initialized
[Wed Dec 14 07:38:19 2022] synobios open /dev/ttyS1 success
[Wed Dec 14 07:38:19 2022] synobios: unload
[Wed Dec 14 07:38:19 2022] md: Autodetecting RAID arrays.
[Wed Dec 14 07:38:19 2022] usb 1-2.1: new high-speed USB device number 3 using x hci_hcd
[Wed Dec 14 07:38:19 2022] md: invalid raid superblock magic on sdb3
[Wed Dec 14 07:38:19 2022] md: sdb3 does not have a valid v0.90 superblock, not importing!
[Wed Dec 14 07:38:19 2022] md: invalid raid superblock magic on sdc3
[Wed Dec 14 07:38:19 2022] md: sdc3 does not have a valid v0.90 superblock, not importing!
[Wed Dec 14 07:38:19 2022] md: Scanned 6 and added 4 devices.
[Wed Dec 14 07:38:19 2022] md: autorun ...
[Wed Dec 14 07:38:19 2022] md: considering sdb1 ...
[Wed Dec 14 07:38:19 2022] md: adding sdb1 ...
[Wed Dec 14 07:38:19 2022] md: sdb2 has different UUID to sdb1
[Wed Dec 14 07:38:19 2022] md: adding sdc1 ...
[Wed Dec 14 07:38:19 2022] md: sdc2 has different UUID to sdb1
[Wed Dec 14 07:38:19 2022] md: created md0
[Wed Dec 14 07:38:19 2022] md: bind<sdc1>
[Wed Dec 14 07:38:19 2022] md: bind<sdb1>
[Wed Dec 14 07:38:19 2022] md: running: <sdb1><sdc1>
[Wed Dec 14 07:38:19 2022] md/raid1:md0: active with 2 out of 16 mirrors
[Wed Dec 14 07:38:19 2022] usb 1-2.1: ep 0x81 - rounding interval to 128 microfr ames, ep desc says 255 microframes
[Wed Dec 14 07:38:19 2022] usb 1-2.1: ep 0x2 - rounding interval to 128 microfra mes, ep desc says 255 microframes
[Wed Dec 14 07:38:19 2022] usb-storage 1-2.1:1.0: USB Mass Storage device detect ed
[Wed Dec 14 07:38:19 2022] scsi host4: usb-storage 1-2.1:1.0
[Wed Dec 14 07:38:19 2022] md0: detected capacity change from 0 to 2549940224
[Wed Dec 14 07:38:19 2022] md: considering sdb2 ...
[Wed Dec 14 07:38:19 2022] md: adding sdb2 ...
[Wed Dec 14 07:38:19 2022] md: adding sdc2 ...
[Wed Dec 14 07:38:19 2022] md: created md1
[Wed Dec 14 07:38:19 2022] md: bind<sdc2>
[Wed Dec 14 07:38:19 2022] md: bind<sdb2>
[Wed Dec 14 07:38:19 2022] md: running: <sdb2><sdc2>
[Wed Dec 14 07:38:19 2022] md/raid1:md1: active with 2 out of 16 mirrors
[Wed Dec 14 07:38:19 2022] md1: detected capacity change from 0 to 2147418112
[Wed Dec 14 07:38:19 2022] random: sfdisk: uninitialized urandom read (16 bytes read, 100 bits of entropy available)
[Wed Dec 14 07:38:19 2022] random: sfdisk: uninitialized urandom read (16 bytes read, 105 bits of entropy available)
[Wed Dec 14 07:38:19 2022] random: sfdisk: uninitialized urandom read (16 bytes read, 106 bits of entropy available)
[Wed Dec 14 07:38:19 2022] random: sfdisk: uninitialized urandom read (16 bytes read, 111 bits of entropy available)
[Wed Dec 14 07:38:19 2022] usb 1-2.4: new low-speed USB device number 4 using xh ci_hcd
[Wed Dec 14 07:38:19 2022] random: nonblocking pool is initialized
[Wed Dec 14 07:38:19 2022] usb 1-2.4: ep 0x81 - rounding interval to 64 microfra mes, ep desc says 80 microframes
[Wed Dec 14 07:38:19 2022] usb 1-2.4: ep 0x82 - rounding interval to 64 microfra mes, ep desc says 80 microframes
[Wed Dec 14 07:38:20 2022] EXT4-fs (md0): barriers disabled
[Wed Dec 14 07:38:20 2022] EXT4-fs (md0): mounted filesystem with ordered data m ode. Opts:
[Wed Dec 14 07:38:20 2022] scsi 4:0:0:0: Direct-Access SMI USB DISK 1100 PQ: 0 ANSI: 4
[Wed Dec 14 07:38:20 2022] sd 4:0:0:0: [synoboot] 15728640 512-byte logical bloc ks: (8.05 GB/7.50 GiB)
[Wed Dec 14 07:38:20 2022] sd 4:0:0:0: [synoboot] Write Protect is off
[Wed Dec 14 07:38:20 2022] sd 4:0:0:0: [synoboot] Mode Sense: 43 00 00 00
[Wed Dec 14 07:38:20 2022] sd 4:0:0:0: [synoboot] Write cache: enabled, read cac he: enabled, doesn't support DPO or FUA
[Wed Dec 14 07:38:20 2022] synoboot: synoboot1 synoboot2 synoboot3
[Wed Dec 14 07:38:20 2022] sd 4:0:0:0: [synoboot] Attached SCSI removable disk
[Wed Dec 14 07:38:23 2022] EXT4-fs (md0): mounted filesystem with ordered data m ode. Opts: barrier=1
[Wed Dec 14 07:38:34 2022] Solarflare NET driver v4.0
[Wed Dec 14 07:38:34 2022] e1000: Intel(R) PRO/1000 Network Driver - version 7.3 .21-k8-NAPI
[Wed Dec 14 07:38:34 2022] e1000: Copyright (c) 1999-2006 Intel Corporation.
[Wed Dec 14 07:38:34 2022] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.f ranken.de
[Wed Dec 14 07:38:34 2022] VMware vmxnet3 virtual NIC driver - version 1.4.5.0-k -NAPI
[Wed Dec 14 07:38:34 2022] igbvf: Intel(R) Gigabit Virtual Function Driver - 2.3 .8.2
[Wed Dec 14 07:38:34 2022] igbvf: Copyright (c) 1999-2015 Intel Corporation.
[Wed Dec 14 07:38:34 2022] ixgbevf: Intel(R) 10GbE PCI Express Virtual Function Driver - version 4.11.1
[Wed Dec 14 07:38:34 2022] ixgbevf: Copyright(c) 1999 - 2021 Intel Corporation.
[Wed Dec 14 07:38:34 2022] systemd-udevd[6762]: starting version 204
[Wed Dec 14 07:38:34 2022] usbcore: registered new interface driver ax88179_178a
[Wed Dec 14 07:38:34 2022] usbcore: registered new interface driver asix
[Wed Dec 14 07:38:34 2022] Atheros(R) L2 Ethernet Driver - version 2.2.3
[Wed Dec 14 07:38:34 2022] Copyright (c) 2007 Atheros Corporation.
[Wed Dec 14 07:38:34 2022] bna: QLogic BR-series 10G Ethernet driver - version: 3.2.25.1
[Wed Dec 14 07:38:34 2022] usbcore: registered new interface driver cx82310_eth
[Wed Dec 14 07:38:35 2022] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[Wed Dec 14 07:38:35 2022] e100: Copyright(c) 1999-2006 Intel Corporation
[Wed Dec 14 07:38:35 2022] enic: Cisco VIC Ethernet NIC Driver, ver 2.3.0.20
[Wed Dec 14 07:38:35 2022] usbcore: registered new interface driver MOSCHIP usb- ethernet driver
[Wed Dec 14 07:38:35 2022] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[Wed Dec 14 07:38:35 2022] usbcore: registered new interface driver pegasus
[Wed Dec 14 07:38:35 2022] usbcore: registered new interface driver plusb
[Wed Dec 14 07:38:35 2022] usbcore: registered new interface driver rtl8150
[Wed Dec 14 07:38:35 2022] via_rhine: v1.10-LK1.5.1 2010-10-09 Written by Donald Becker
[Wed Dec 14 07:38:35 2022] usbcore: registered new interface driver r8152
[Wed Dec 14 07:38:35 2022] vxge: Copyright(c) 2002-2010 Exar Corp.
[Wed Dec 14 07:38:35 2022] vxge: Driver version: 2.5.3.22640-k
[Wed Dec 14 07:38:35 2022] usbcore: registered new interface driver aqc111
[Wed Dec 14 07:38:35 2022] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Wed Dec 14 07:38:35 2022] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Wed Dec 14 07:38:35 2022] 9pnet: Installing 9P2000 support
[Wed Dec 14 07:38:35 2022] 9p: Installing v9fs 9p2000 file system support
[Wed Dec 14 07:38:35 2022] 2022-12-14 5:38:36 UTC
[Wed Dec 14 07:38:35 2022] synobios: load, major number 201
[Wed Dec 14 07:38:35 2022] Brand: Synology
[Wed Dec 14 07:38:35 2022] Model: DS-918+
[Wed Dec 14 07:38:35 2022] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Wed Dec 14 07:38:35 2022] synobios cpu_arch proc entry initialized
[Wed Dec 14 07:38:39 2022] r8168: eth0: link up
[Wed Dec 14 07:38:40 2022] EXT4-fs (md3): barriers disabled
[Wed Dec 14 07:38:40 2022] EXT4-fs (md4): barriers disabled
[Wed Dec 14 07:38:40 2022] EXT4-fs (md3): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Wed Dec 14 07:38:40 2022] EXT4-fs (md4): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Wed Dec 14 07:38:41 2022] init: dhcp-client (eth0) main process (8660) killed b y TERM signal
[Wed Dec 14 07:38:42 2022] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) D river
[Wed Dec 14 07:38:42 2022] Warning! ehci_hcd should always be loaded before uhci _hcd and ohci_hcd, not after
[Wed Dec 14 07:38:42 2022] ehci-pci: EHCI PCI platform driver
[Wed Dec 14 07:38:42 2022] uhci_hcd: USB Universal Host Controller Interface dri ver
[Wed Dec 14 07:38:42 2022] usbcore: registered new interface driver usblp
[Wed Dec 14 07:38:43 2022] usbcore: registered new interface driver usbhid
[Wed Dec 14 07:38:43 2022] usbhid: USB HID core driver
[Wed Dec 14 07:38:43 2022] input: USBDevice as /devices/pci0000:00/0000:00:14.0/ usb1/1-2/1-2.4/1-2.4:1.0/0003:0E8F:2517.0001/input/input4
[Wed Dec 14 07:38:43 2022] hid-generic 0003:0E8F:2517.0001: input: USB HID v1.10 Keyboard [USBDevice] on usb-0000:00:14.0-2.4/input0
[Wed Dec 14 07:38:43 2022] input: USBDevice as /devices/pci0000:00/0000:00:14.0/ usb1/1-2/1-2.4/1-2.4:1.1/0003:0E8F:2517.0002/input/input5
[Wed Dec 14 07:38:43 2022] Get empty minor:104
[Wed Dec 14 07:38:43 2022] hid-generic 0003:0E8F:2517.0002: input,hiddev0: USB H ID v1.10 Mouse [USBDevice] on usb-0000:00:14.0-2.4/input1
[Wed Dec 14 07:38:44 2022] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Wed Dec 14 07:38:44 2022] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Wed Dec 14 07:38:47 2022] iSCSI:target_core_rodsp_server.c:1027:rodsp_server_in it RODSP server started, login_key(086266a3c238).
[Wed Dec 14 07:38:47 2022] iSCSI:extent_pool.c:766:ep_init syno_extent_pool succ essfully initialized
[Wed Dec 14 07:38:47 2022] iSCSI:target_core_device.c:617:se_dev_align_max_secto rs Rounding down aligned max_sectors from 4294967295 to 4294967288
[Wed Dec 14 07:38:47 2022] iSCSI:target_core_lunbackup.c:361:init_io_buffer_head 512 buffers allocated, total 2097152 bytes successfully
[Wed Dec 14 07:38:48 2022] iSCSI:target_core_file.c:146:fd_attach_hba RODSP plug in for fileio is enabled.
[Wed Dec 14 07:38:48 2022] iSCSI:target_core_file.c:153:fd_attach_hba ODX Token Manager is enabled.
[Wed Dec 14 07:38:48 2022] iSCSI:target_core_multi_file.c:91:fd_attach_hba RODSP plugin for multifile is enabled.
[Wed Dec 14 07:38:48 2022] iSCSI:target_core_ep.c:786:ep_attach_hba RODSP plugin for epio is enabled.
[Wed Dec 14 13:51:42 2022] Loaded X.509 cert 'Synology Kernel Module Signing Cer tification Authority: 600839b5d127e0e11d817a31f0575d323a7c0e28'
[Wed Dec 14 13:51:42 2022] Loaded X.509 cert 'Synology kernel module signing key : 4646ce54489669338118a3b1286da156ac366fa5'
[Wed Dec 14 13:51:42 2022] page_owner is disabled
[Wed Dec 14 13:51:42 2022] AppArmor: AppArmor sha1 policy hashing enabled
[Wed Dec 14 13:51:42 2022] hctosys: unable to open rtc device (rtc0)
[Wed Dec 14 13:51:42 2022] Freeing unused kernel memory: 864K (ffffffff81879000 - ffffffff81951000)
[Wed Dec 14 13:51:42 2022] Write protecting the kernel read-only data: 8192k
[Wed Dec 14 13:51:42 2022] Freeing unused kernel memory: 520K (ffff88000157e000 - ffff880001600000)
[Wed Dec 14 13:51:42 2022] Freeing unused kernel memory: 200K (ffff8800017ce000 - ffff880001800000)
[Wed Dec 14 13:51:42 2022] ACPI: bus type USB registered
[Wed Dec 14 13:51:42 2022] usbcore: registered new interface driver usbfs
[Wed Dec 14 13:51:42 2022] usbcore: registered new interface driver hub
[Wed Dec 14 13:51:42 2022] usbcore: registered new interface driver ethub
[Wed Dec 14 13:51:42 2022] usbcore: registered new device driver usb
[Wed Dec 14 13:51:42 2022] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Drive r
[Wed Dec 14 13:51:42 2022] xhci_hcd 0000:00:14.0: xHCI Host Controller
[Wed Dec 14 13:51:42 2022] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 1
[Wed Dec 14 13:51:42 2022] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci vers ion 0x100 quirks 0x00009010
[Wed Dec 14 13:51:42 2022] xhci_hcd 0000:00:14.0: cache line size of 64 is not s upported
[Wed Dec 14 13:51:42 2022] hub 1-0:1.0: USB hub found
[Wed Dec 14 13:51:42 2022] hub 1-0:1.0: 6 ports detected
[Wed Dec 14 13:51:42 2022] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 2
[Wed Dec 14 13:51:42 2022] usb usb2: We don't know the algorithms for LPM for th is host, disabling LPM.
[Wed Dec 14 13:51:42 2022] hub 2-0:1.0: USB hub found
[Wed Dec 14 13:51:42 2022] hub 2-0:1.0: 1 port detected
[Wed Dec 14 13:51:42 2022] usbcore: registered new interface driver usb-storage
[Wed Dec 14 13:51:42 2022] VMware PVSCSI driver - version 1.0.5.0-k
[Wed Dec 14 13:51:42 2022] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:0 1:03 EST 2006)
[Wed Dec 14 13:51:42 2022] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
[Wed Dec 14 13:51:42 2022] Fusion MPT base driver 3.04.20
[Wed Dec 14 13:51:42 2022] Copyright (c) 1999-2008 LSI Corporation
[Wed Dec 14 13:51:43 2022] Fusion MPT SPI Host driver 3.04.20
[Wed Dec 14 13:51:43 2022] Fusion MPT misc device (ioctl) driver 3.04.20
[Wed Dec 14 13:51:43 2022] mptctl: Registered with Fusion MPT base driver
[Wed Dec 14 13:51:43 2022] mptctl: /dev/mptctl @ (major,minor=10,220)
[Wed Dec 14 13:51:43 2022] megasas: 06.808.16.00-rc1
[Wed Dec 14 13:51:43 2022] Fusion MPT SAS Host driver 3.04.20
[Wed Dec 14 13:51:43 2022] mpt3sas version 09.102.00.00 loaded
[Wed Dec 14 13:51:43 2022] rtc_cmos 00:00: RTC can wake from S4
[Wed Dec 14 13:51:43 2022] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0
[Wed Dec 14 13:51:43 2022] rtc_cmos 00:00: alarms up to one month, y3k, 242 byte s nvram
[Wed Dec 14 13:51:43 2022] usb 1-2: new high-speed USB device number 2 using xhc i_hcd
[Wed Dec 14 13:51:43 2022] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014.
[Wed Dec 14 13:51:43 2022] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000.
[Wed Dec 14 13:51:43 2022] Adaptec aacraid driver 1.2-1[41010]-ms
[Wed Dec 14 13:51:43 2022] GDT-HA: Storage RAID Controller Driver. Version: 3.05
[Wed Dec 14 13:51:43 2022] RocketRAID 3xxx/4xxx Controller driver v1.10.0
[Wed Dec 14 13:51:43 2022] isci: Intel(R) C600 SAS Controller Driver - version 1 .2.0
[Wed Dec 14 13:51:43 2022] Got empty serial number. Generate serial number from product.
[Wed Dec 14 13:51:43 2022] hub 1-2:1.0: USB hub found
[Wed Dec 14 13:51:43 2022] hub 1-2:1.0: 4 ports detected
[Wed Dec 14 13:51:43 2022] aic94xx: Adaptec aic94xx SAS/SATA driver version 1.0. 3 loaded
[Wed Dec 14 13:51:43 2022] synobios: load, major number 201
[Wed Dec 14 13:51:43 2022] Brand: Synology
[Wed Dec 14 13:51:43 2022] Model: DS-918+
[Wed Dec 14 13:51:43 2022] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Wed Dec 14 13:51:43 2022] synobios cpu_arch proc entry initialized
[Wed Dec 14 13:51:43 2022] synobios crypto_hw proc entry initialized
[Wed Dec 14 13:51:43 2022] synobios syno_platform proc entry initialized
[Wed Dec 14 13:51:43 2022] synobios open /dev/ttyS1 success
[Wed Dec 14 13:51:43 2022] synobios: unload
[Wed Dec 14 13:51:43 2022] md: Autodetecting RAID arrays.
[Wed Dec 14 13:51:43 2022] usb 1-2.1: new high-speed USB device number 3 using x hci_hcd
[Wed Dec 14 13:51:43 2022] md: invalid raid superblock magic on sdb3
[Wed Dec 14 13:51:43 2022] md: sdb3 does not have a valid v0.90 superblock, not importing!
[Wed Dec 14 13:51:43 2022] md: invalid raid superblock magic on sdc3
[Wed Dec 14 13:51:43 2022] md: sdc3 does not have a valid v0.90 superblock, not importing!
[Wed Dec 14 13:51:43 2022] md: Scanned 6 and added 4 devices.
[Wed Dec 14 13:51:43 2022] md: autorun ...
[Wed Dec 14 13:51:43 2022] md: considering sdb1 ...
[Wed Dec 14 13:51:43 2022] md: adding sdb1 ...
[Wed Dec 14 13:51:43 2022] md: sdb2 has different UUID to sdb1
[Wed Dec 14 13:51:43 2022] md: adding sdc1 ...
[Wed Dec 14 13:51:43 2022] md: sdc2 has different UUID to sdb1
[Wed Dec 14 13:51:43 2022] md: created md0
[Wed Dec 14 13:51:43 2022] md: bind<sdc1>
[Wed Dec 14 13:51:43 2022] md: bind<sdb1>
[Wed Dec 14 13:51:43 2022] md: running: <sdb1><sdc1>
[Wed Dec 14 13:51:43 2022] md/raid1:md0: active with 2 out of 16 mirrors
[Wed Dec 14 13:51:43 2022] usb 1-2.1: ep 0x81 - rounding interval to 128 microfr ames, ep desc says 255 microframes
[Wed Dec 14 13:51:43 2022] usb 1-2.1: ep 0x2 - rounding interval to 128 microfra mes, ep desc says 255 microframes
[Wed Dec 14 13:51:43 2022] usb-storage 1-2.1:1.0: USB Mass Storage device detect ed
[Wed Dec 14 13:51:43 2022] scsi host4: usb-storage 1-2.1:1.0
[Wed Dec 14 13:51:43 2022] md0: detected capacity change from 0 to 2549940224
[Wed Dec 14 13:51:43 2022] md: considering sdb2 ...
[Wed Dec 14 13:51:43 2022] md: adding sdb2 ...
[Wed Dec 14 13:51:43 2022] md: adding sdc2 ...
[Wed Dec 14 13:51:43 2022] md: created md1
[Wed Dec 14 13:51:43 2022] md: bind<sdc2>
[Wed Dec 14 13:51:43 2022] md: bind<sdb2>
[Wed Dec 14 13:51:43 2022] md: running: <sdb2><sdc2>
[Wed Dec 14 13:51:43 2022] md/raid1:md1: active with 2 out of 16 mirrors
[Wed Dec 14 13:51:43 2022] md1: detected capacity change from 0 to 2147418112
[Wed Dec 14 13:51:59 2022] Solarflare NET driver v4.0
[Wed Dec 14 13:51:59 2022] e1000: Intel(R) PRO/1000 Network Driver - version 7.3 .21-k8-NAPI
[Wed Dec 14 13:51:59 2022] e1000: Copyright (c) 1999-2006 Intel Corporation.
[Wed Dec 14 13:51:59 2022] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.f ranken.de
[Wed Dec 14 13:51:59 2022] VMware vmxnet3 virtual NIC driver - version 1.4.5.0-k -NAPI
[Wed Dec 14 13:51:59 2022] igbvf: Intel(R) Gigabit Virtual Function Driver - 2.3 .8.2
[Wed Dec 14 13:51:59 2022] igbvf: Copyright (c) 1999-2015 Intel Corporation.
[Wed Dec 14 13:51:59 2022] ixgbevf: Intel(R) 10GbE PCI Express Virtual Function Driver - version 4.11.1
[Wed Dec 14 13:51:59 2022] ixgbevf: Copyright(c) 1999 - 2021 Intel Corporation.
[Wed Dec 14 13:51:59 2022] systemd-udevd[6735]: starting version 204
[Wed Dec 14 13:51:59 2022] usbcore: registered new interface driver ax88179_178a
[Wed Dec 14 13:51:59 2022] usbcore: registered new interface driver asix
[Wed Dec 14 13:51:59 2022] Atheros(R) L2 Ethernet Driver - version 2.2.3
[Wed Dec 14 13:51:59 2022] Copyright (c) 2007 Atheros Corporation.
[Wed Dec 14 13:51:59 2022] bna: QLogic BR-series 10G Ethernet driver - version: 3.2.25.1
[Wed Dec 14 13:51:59 2022] usbcore: registered new interface driver cx82310_eth
[Wed Dec 14 13:51:59 2022] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[Wed Dec 14 13:51:59 2022] e100: Copyright(c) 1999-2006 Intel Corporation
[Wed Dec 14 13:51:59 2022] enic: Cisco VIC Ethernet NIC Driver, ver 2.3.0.20
[Wed Dec 14 13:51:59 2022] usbcore: registered new interface driver MOSCHIP usb- ethernet driver
[Wed Dec 14 13:52:00 2022] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[Wed Dec 14 13:52:00 2022] usbcore: registered new interface driver pegasus
[Wed Dec 14 13:52:00 2022] usbcore: registered new interface driver plusb
[Wed Dec 14 13:52:00 2022] usbcore: registered new interface driver rtl8150
[Wed Dec 14 13:52:00 2022] via_rhine: v1.10-LK1.5.1 2010-10-09 Written by Donald Becker
[Wed Dec 14 13:52:00 2022] usbcore: registered new interface driver r8152
[Wed Dec 14 13:52:00 2022] vxge: Copyright(c) 2002-2010 Exar Corp.
[Wed Dec 14 13:52:00 2022] vxge: Driver version: 2.5.3.22640-k
[Wed Dec 14 13:52:00 2022] usbcore: registered new interface driver aqc111
[Wed Dec 14 13:52:00 2022] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Wed Dec 14 13:52:00 2022] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Wed Dec 14 13:52:00 2022] 9pnet: Installing 9P2000 support
[Wed Dec 14 13:52:00 2022] 9p: Installing v9fs 9p2000 file system support
[Wed Dec 14 13:52:00 2022] 2022-12-14 11:52:1 UTC
[Wed Dec 14 13:52:00 2022] synobios: load, major number 201
[Wed Dec 14 13:52:00 2022] Brand: Synology
[Wed Dec 14 13:52:00 2022] Model: DS-918+
[Wed Dec 14 13:52:00 2022] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Wed Dec 14 13:52:00 2022] synobios cpu_arch proc entry initialized
[Wed Dec 14 13:52:04 2022] r8168: eth0: link up
[Wed Dec 14 13:52:04 2022] EXT4-fs (md4): barriers disabled
[Wed Dec 14 13:52:04 2022] EXT4-fs (md3): barriers disabled
[Wed Dec 14 13:52:05 2022] EXT4-fs (md3): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Wed Dec 14 13:52:05 2022] EXT4-fs (md4): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Wed Dec 14 13:52:05 2022] init: dhcp-client (eth0) main process (8403) killed b y TERM signal
[Wed Dec 14 13:52:07 2022] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) D river
[Wed Dec 14 13:52:07 2022] Warning! ehci_hcd should always be loaded before uhci _hcd and ohci_hcd, not after
[Wed Dec 14 13:52:07 2022] ehci-pci: EHCI PCI platform driver
[Wed Dec 14 13:52:07 2022] uhci_hcd: USB Universal Host Controller Interface dri ver
[Wed Dec 14 13:52:07 2022] usbcore: registered new interface driver usblp
[Wed Dec 14 13:52:07 2022] usbcore: registered new interface driver usbhid
[Wed Dec 14 13:52:07 2022] usbhid: USB HID core driver
[Wed Dec 14 13:52:08 2022] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Wed Dec 14 13:52:08 2022] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Wed Dec 14 13:52:11 2022] FAT-fs (synoboot2): fat_set_state: set=1 process=syno pkicompatsy pid=10545
[Wed Dec 14 13:52:11 2022] FAT-fs (synoboot2): fat_set_state: set=0 process=syno pkicompatsy pid=10545
[Wed Dec 14 13:52:13 2022] ata2.00: configured for UDMA/133
[Wed Dec 14 13:52:13 2022] ata2: EH complete
[Wed Dec 14 13:52:14 2022] ata3.00: configured for UDMA/133
[Wed Dec 14 13:52:14 2022] ata3: EH complete
[Wed Dec 14 13:52:14 2022] iSCSI:target_core_rodsp_server.c:1027:rodsp_server_in it RODSP server started, login_key(086266a3c238).
[Wed Dec 14 13:52:14 2022] Installing knfsd (copyright (C) 1996 okir@monad.swb.d e).
[Sat Jan 7 20:24:30 2023] Loaded X.509 cert 'Synology Kernel Module Signing Cer tification Authority: 600839b5d127e0e11d817a31f0575d323a7c0e28'
[Sat Jan 7 20:24:30 2023] Loaded X.509 cert 'Synology kernel module signing key : 4646ce54489669338118a3b1286da156ac366fa5'
[Sat Jan 7 20:24:30 2023] page_owner is disabled
[Sat Jan 7 20:24:30 2023] AppArmor: AppArmor sha1 policy hashing enabled
[Sat Jan 7 20:24:30 2023] hctosys: unable to open rtc device (rtc0)
[Sat Jan 7 20:24:30 2023] Freeing unused kernel memory: 864K (ffffffff81879000 - ffffffff81951000)
[Sat Jan 7 20:24:30 2023] Write protecting the kernel read-only data: 8192k
[Sat Jan 7 20:24:30 2023] Freeing unused kernel memory: 520K (ffff88000157e000 - ffff880001600000)
[Sat Jan 7 20:24:30 2023] Freeing unused kernel memory: 200K (ffff8800017ce000 - ffff880001800000)
[Sat Jan 7 20:24:30 2023] ACPI: bus type USB registered
[Sat Jan 7 20:24:30 2023] usbcore: registered new interface driver usbfs
[Sat Jan 7 20:24:30 2023] usbcore: registered new interface driver hub
[Sat Jan 7 20:24:30 2023] usbcore: registered new interface driver ethub
[Sat Jan 7 20:24:30 2023] usbcore: registered new device driver usb
[Sat Jan 7 20:24:30 2023] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Drive r
[Sat Jan 7 20:24:30 2023] xhci_hcd 0000:00:14.0: xHCI Host Controller
[Sat Jan 7 20:24:30 2023] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 1
[Sat Jan 7 20:24:30 2023] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci vers ion 0x100 quirks 0x00009010
[Sat Jan 7 20:24:30 2023] xhci_hcd 0000:00:14.0: cache line size of 64 is not s upported
[Sat Jan 7 20:24:30 2023] hub 1-0:1.0: USB hub found
[Sat Jan 7 20:24:30 2023] hub 1-0:1.0: 6 ports detected
[Sat Jan 7 20:24:30 2023] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 2
[Sat Jan 7 20:24:30 2023] usb usb2: We don't know the algorithms for LPM for th is host, disabling LPM.
[Sat Jan 7 20:24:30 2023] hub 2-0:1.0: USB hub found
[Sat Jan 7 20:24:30 2023] hub 2-0:1.0: 1 port detected
[Sat Jan 7 20:24:30 2023] usbcore: registered new interface driver usb-storage
[Sat Jan 7 20:24:30 2023] VMware PVSCSI driver - version 1.0.5.0-k
[Sat Jan 7 20:24:30 2023] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:0 1:03 EST 2006)
[Sat Jan 7 20:24:30 2023] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
[Sat Jan 7 20:24:30 2023] Fusion MPT base driver 3.04.20
[Sat Jan 7 20:24:30 2023] Copyright (c) 1999-2008 LSI Corporation
[Sat Jan 7 20:24:31 2023] Fusion MPT SPI Host driver 3.04.20
[Sat Jan 7 20:24:31 2023] Fusion MPT misc device (ioctl) driver 3.04.20
[Sat Jan 7 20:24:31 2023] mptctl: Registered with Fusion MPT base driver
[Sat Jan 7 20:24:31 2023] mptctl: /dev/mptctl @ (major,minor=10,220)
[Sat Jan 7 20:24:31 2023] megasas: 06.808.16.00-rc1
[Sat Jan 7 20:24:31 2023] Fusion MPT SAS Host driver 3.04.20
[Sat Jan 7 20:24:31 2023] mpt3sas version 09.102.00.00 loaded
[Sat Jan 7 20:24:31 2023] usb 1-2: new high-speed USB device number 2 using xhc i_hcd
[Sat Jan 7 20:24:31 2023] rtc_cmos 00:00: RTC can wake from S4
[Sat Jan 7 20:24:31 2023] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0
[Sat Jan 7 20:24:31 2023] rtc_cmos 00:00: alarms up to one month, y3k, 242 byte s nvram
[Sat Jan 7 20:24:31 2023] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014.
[Sat Jan 7 20:24:31 2023] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000.
[Sat Jan 7 20:24:31 2023] Adaptec aacraid driver 1.2-1[41010]-ms
[Sat Jan 7 20:24:31 2023] GDT-HA: Storage RAID Controller Driver. Version: 3.05
[Sat Jan 7 20:24:31 2023] RocketRAID 3xxx/4xxx Controller driver v1.10.0
[Sat Jan 7 20:24:31 2023] isci: Intel(R) C600 SAS Controller Driver - version 1 .2.0
[Sat Jan 7 20:24:31 2023] Got empty serial number. Generate serial number from product.
[Sat Jan 7 20:24:31 2023] synobios: load, major number 201
[Sat Jan 7 20:24:31 2023] Brand: Synology
[Sat Jan 7 20:24:31 2023] Model: DS-918+
[Sat Jan 7 20:24:31 2023] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Sat Jan 7 20:24:31 2023] synobios cpu_arch proc entry initialized
[Sat Jan 7 20:24:31 2023] synobios crypto_hw proc entry initialized
[Sat Jan 7 20:24:31 2023] synobios syno_platform proc entry initialized
[Sat Jan 7 20:24:31 2023] synobios open /dev/ttyS1 success
[Sat Jan 7 20:24:31 2023] synobios: unload
[Sat Jan 7 20:24:31 2023] md: Autodetecting RAID arrays.
[Sat Jan 7 20:24:31 2023] usb 1-2.1: new high-speed USB device number 3 using x hci_hcd
[Sat Jan 7 20:24:31 2023] md: invalid raid superblock magic on sdb3
[Sat Jan 7 20:24:31 2023] md: sdb3 does not have a valid v0.90 superblock, not importing!
[Sat Jan 7 20:24:31 2023] usb 1-2.1: ep 0x81 - rounding interval to 128 microfr ames, ep desc says 255 microframes
[Sat Jan 7 20:24:31 2023] usb 1-2.1: ep 0x2 - rounding interval to 128 microfra mes, ep desc says 255 microframes
[Sat Jan 7 20:24:31 2023] usb-storage 1-2.1:1.0: USB Mass Storage device detect ed
[Sat Jan 7 20:24:31 2023] scsi host4: usb-storage 1-2.1:1.0
[Sat Jan 7 20:24:31 2023] md: invalid raid superblock magic on sdc3
[Sat Jan 7 20:24:31 2023] md: sdc3 does not have a valid v0.90 superblock, not importing!
[Sat Jan 7 20:24:31 2023] md: Scanned 6 and added 4 devices.
[Sat Jan 7 20:24:31 2023] md: autorun ...
[Sat Jan 7 20:24:31 2023] md: considering sdb1 ...
[Sat Jan 7 20:24:31 2023] md: adding sdb1 ...
[Sat Jan 7 20:24:31 2023] md: sdb2 has different UUID to sdb1
[Sat Jan 7 20:24:31 2023] md: adding sdc1 ...
[Sat Jan 7 20:24:31 2023] md: sdc2 has different UUID to sdb1
[Sat Jan 7 20:24:31 2023] md: created md0
[Sat Jan 7 20:24:31 2023] md: adding sdb2 ...
[Sat Jan 7 20:24:31 2023] md: adding sdc2 ...
[Sat Jan 7 20:24:31 2023] md: created md1
[Sat Jan 7 20:24:31 2023] md: bind<sdc2>
[Sat Jan 7 20:24:31 2023] md: bind<sdb2>
[Sat Jan 7 20:24:31 2023] md: running: <sdb2><sdc2>
[Sat Jan 7 20:24:31 2023] md/raid1:md1: active with 2 out of 16 mirrors
[Sat Jan 7 20:24:31 2023] md1: detected capacity change from 0 to 2147418112
[Sat Jan 7 20:24:31 2023] md: ... autorun DONE.
[Sat Jan 7 20:24:31 2023] random: sfdisk: uninitialized urandom read (16 bytes read, 103 bits of entropy available)
[Sat Jan 7 20:24:31 2023] usb 1-2.4: new high-speed USB device number 4 using x hci_hcd
[Sat Jan 7 20:24:31 2023] random: sfdisk: uninitialized urandom read (16 bytes read, 108 bits of entropy available)
[Sat Jan 7 20:24:31 2023] random: sfdisk: uninitialized urandom read (16 bytes read, 113 bits of entropy available)
[Sat Jan 7 20:24:31 2023] random: sfdisk: uninitialized urandom read (16 bytes read, 119 bits of entropy available)
[Sat Jan 7 20:24:31 2023] random: nonblocking pool is initialized
[Sat Jan 7 20:24:47 2023] Solarflare NET driver v4.0
[Sat Jan 7 20:24:47 2023] e1000: Intel(R) PRO/1000 Network Driver - version 7.3 .21-k8-NAPI
[Sat Jan 7 20:24:47 2023] e1000: Copyright (c) 1999-2006 Intel Corporation.
[Sat Jan 7 20:24:47 2023] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.f ranken.de
[Sat Jan 7 20:24:47 2023] VMware vmxnet3 virtual NIC driver - version 1.4.5.0-k -NAPI
[Sat Jan 7 20:24:47 2023] systemd-udevd[6736]: starting version 204
[Sat Jan 7 20:24:47 2023] igbvf: Intel(R) Gigabit Virtual Function Driver - 2.3 .8.2
[Sat Jan 7 20:24:47 2023] igbvf: Copyright (c) 1999-2015 Intel Corporation.
[Sat Jan 7 20:24:47 2023] ixgbevf: Intel(R) 10GbE PCI Express Virtual Function Driver - version 4.11.1
[Sat Jan 7 20:24:47 2023] ixgbevf: Copyright(c) 1999 - 2021 Intel Corporation.
[Sat Jan 7 20:24:47 2023] usbcore: registered new interface driver ax88179_178a
[Sat Jan 7 20:24:47 2023] usbcore: registered new interface driver asix
[Sat Jan 7 20:24:47 2023] Atheros(R) L2 Ethernet Driver - version 2.2.3
[Sat Jan 7 20:24:47 2023] Copyright (c) 2007 Atheros Corporation.
[Sat Jan 7 20:24:47 2023] bna: QLogic BR-series 10G Ethernet driver - version: 3.2.25.1
[Sat Jan 7 20:24:47 2023] usbcore: registered new interface driver cx82310_eth
[Sat Jan 7 20:24:47 2023] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[Sat Jan 7 20:24:47 2023] e100: Copyright(c) 1999-2006 Intel Corporation
[Sat Jan 7 20:24:47 2023] enic: Cisco VIC Ethernet NIC Driver, ver 2.3.0.20
[Sat Jan 7 20:24:47 2023] usbcore: registered new interface driver MOSCHIP usb- ethernet driver
[Sat Jan 7 20:24:47 2023] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[Sat Jan 7 20:24:47 2023] usbcore: registered new interface driver pegasus
[Sat Jan 7 20:24:47 2023] usbcore: registered new interface driver plusb
[Sat Jan 7 20:24:47 2023] usbcore: registered new interface driver rtl8150
[Sat Jan 7 20:24:47 2023] via_rhine: v1.10-LK1.5.1 2010-10-09 Written by Donald Becker
[Sat Jan 7 20:24:47 2023] usbcore: registered new interface driver r8152
[Sat Jan 7 20:24:47 2023] vxge: Copyright(c) 2002-2010 Exar Corp.
[Sat Jan 7 20:24:47 2023] vxge: Driver version: 2.5.3.22640-k
[Sat Jan 7 20:24:48 2023] usbcore: registered new interface driver aqc111
[Sat Jan 7 20:24:48 2023] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Sat Jan 7 20:24:48 2023] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Sat Jan 7 20:24:48 2023] 9pnet: Installing 9P2000 support
[Sat Jan 7 20:24:48 2023] 9p: Installing v9fs 9p2000 file system support
[Sat Jan 7 20:24:48 2023] 2023-1-7 18:24:49 UTC
[Sat Jan 7 20:24:48 2023] synobios: load, major number 201
[Sat Jan 7 20:24:48 2023] Brand: Synology
[Sat Jan 7 20:24:48 2023] Model: DS-918+
[Sat Jan 7 20:24:48 2023] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Sat Jan 7 20:24:48 2023] synobios cpu_arch proc entry initialized
[Sat Jan 7 20:24:49 2023] Bluetooth: HCI device and connection manager initiali zed
[Sat Jan 7 20:24:49 2023] Bluetooth: HCI socket layer initialized
[Sat Jan 7 20:24:49 2023] Bluetooth: L2CAP socket layer initialized
[Sat Jan 7 20:24:49 2023] Bluetooth: SCO socket layer initialized
[Sat Jan 7 20:24:49 2023] Bluetooth: RFCOMM TTY layer initialized
[Sat Jan 7 20:24:49 2023] Bluetooth: RFCOMM socket layer initialized
[Sat Jan 7 20:24:49 2023] Bluetooth: RFCOMM ver 1.11
[Sat Jan 7 20:24:49 2023] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[Sat Jan 7 20:24:49 2023] Bluetooth: HIDP socket layer initialized
[Sat Jan 7 20:24:49 2023] eth0: 0xffffc90002018000, 08:62:66:a3:c2:38, IRQ 90
[Sat Jan 7 20:24:49 2023] usbcore: registered new interface driver btusb
[Sat Jan 7 20:24:51 2023] md: md4 stopped.
[Sat Jan 7 20:24:51 2023] md: bind<sdc3>
[Sat Jan 7 20:24:51 2023] md/raid1:md4: active with 1 out of 1 mirrors
[Sat Jan 7 20:24:51 2023] md4: detected capacity change from 0 to 3995849261056
[Sat Jan 7 20:24:51 2023] md: md3 stopped.
[Sat Jan 7 20:24:51 2023] md: bind<sdb3>
[Sat Jan 7 20:24:51 2023] md/raid1:md3: active with 1 out of 1 mirrors
[Sat Jan 7 20:24:51 2023] md3: detected capacity change from 0 to 3995849261056
[Sat Jan 7 20:24:52 2023] r8168: eth0: link up
[Sat Jan 7 20:24:53 2023] EXT4-fs (md4): barriers disabled
[Sat Jan 7 20:24:53 2023] EXT4-fs (md3): barriers disabled
[Sat Jan 7 20:24:53 2023] EXT4-fs (md4): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Sat Jan 7 20:24:53 2023] EXT4-fs (md3): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Sat Jan 7 20:24:53 2023] init: dhcp-client (eth0) main process (8582) killed b y TERM signal
[Sat Jan 7 20:24:55 2023] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) D river
[Sat Jan 7 20:24:55 2023] Warning! ehci_hcd should always be loaded before uhci _hcd and ohci_hcd, not after
[Sat Jan 7 20:24:55 2023] ehci-pci: EHCI PCI platform driver
[Sat Jan 7 20:24:55 2023] uhci_hcd: USB Universal Host Controller Interface dri ver
[Sat Jan 7 20:24:55 2023] usbcore: registered new interface driver usblp
[Sat Jan 7 20:24:56 2023] usbcore: registered new interface driver usbhid
[Sat Jan 7 20:24:56 2023] usbhid: USB HID core driver
[Sat Jan 7 20:24:57 2023] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Sat Jan 7 20:24:57 2023] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Sat Jan 7 20:25:00 2023] FAT-fs (synoboot2): fat_set_state: set=1 process=syno pkicompatsy pid=10781
[Sat Jan 7 20:25:00 2023] FAT-fs (synoboot2): fat_set_state: set=0 process=syno pkicompatsy pid=10781
[Sat Jan 7 20:25:02 2023] Installing knfsd (copyright (C) 1996 okir@monad.swb.d e).
[Sat Jan 7 20:25:02 2023] ata2.00: configured for UDMA/133
[Sat Jan 7 20:25:02 2023] ata2: EH complete
[Sat Jan 7 20:25:02 2023] ata3.00: configured for UDMA/133
[Sat Jan 7 20:25:02 2023] ata3: EH complete
[Sat Jan 7 20:25:03 2023] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 stat e recovery directory
[Sat Jan 14 19:14:16 2023] Loaded X.509 cert 'Synology Kernel Module Signing Cer tification Authority: 600839b5d127e0e11d817a31f0575d323a7c0e28'
[Sat Jan 14 19:14:16 2023] Loaded X.509 cert 'Synology kernel module signing key : 4646ce54489669338118a3b1286da156ac366fa5'
[Sat Jan 14 19:14:16 2023] page_owner is disabled
[Sat Jan 14 19:14:16 2023] AppArmor: AppArmor sha1 policy hashing enabled
[Sat Jan 14 19:14:16 2023] hctosys: unable to open rtc device (rtc0)
[Sat Jan 14 19:14:16 2023] Freeing unused kernel memory: 864K (ffffffff81879000 - ffffffff81951000)
[Sat Jan 14 19:14:16 2023] Write protecting the kernel read-only data: 8192k
[Sat Jan 14 19:14:16 2023] Freeing unused kernel memory: 520K (ffff88000157e000 - ffff880001600000)
[Sat Jan 14 19:14:16 2023] Freeing unused kernel memory: 200K (ffff8800017ce000 - ffff880001800000)
[Sat Jan 14 19:14:16 2023] ACPI: bus type USB registered
[Sat Jan 14 19:14:16 2023] usbcore: registered new interface driver usbfs
[Sat Jan 14 19:14:16 2023] usbcore: registered new interface driver hub
[Sat Jan 14 19:14:16 2023] usbcore: registered new interface driver ethub
[Sat Jan 14 19:14:16 2023] usbcore: registered new device driver usb
[Sat Jan 14 19:14:16 2023] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Drive r
[Sat Jan 14 19:14:16 2023] xhci_hcd 0000:00:14.0: xHCI Host Controller
[Sat Jan 14 19:14:16 2023] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 1
[Sat Jan 14 19:14:16 2023] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci vers ion 0x100 quirks 0x00009010
[Sat Jan 14 19:14:16 2023] xhci_hcd 0000:00:14.0: cache line size of 64 is not s upported
[Sat Jan 14 19:14:16 2023] hub 1-0:1.0: USB hub found
[Sat Jan 14 19:14:16 2023] hub 1-0:1.0: 6 ports detected
[Sat Jan 14 19:14:16 2023] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 2
[Sat Jan 14 19:14:16 2023] usb usb2: We don't know the algorithms for LPM for th is host, disabling LPM.
[Sat Jan 14 19:14:16 2023] hub 2-0:1.0: USB hub found
[Sat Jan 14 19:14:16 2023] hub 2-0:1.0: 1 port detected
[Sat Jan 14 19:14:16 2023] usbcore: registered new interface driver usb-storage
[Sat Jan 14 19:14:16 2023] VMware PVSCSI driver - version 1.0.5.0-k
[Sat Jan 14 19:14:16 2023] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:0 1:03 EST 2006)
[Sat Jan 14 19:14:16 2023] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
[Sat Jan 14 19:14:16 2023] Fusion MPT base driver 3.04.20
[Sat Jan 14 19:14:16 2023] Copyright (c) 1999-2008 LSI Corporation
[Sat Jan 14 19:14:16 2023] Fusion MPT SPI Host driver 3.04.20
[Sat Jan 14 19:14:16 2023] Fusion MPT misc device (ioctl) driver 3.04.20
[Sat Jan 14 19:14:16 2023] mptctl: Registered with Fusion MPT base driver
[Sat Jan 14 19:14:16 2023] mptctl: /dev/mptctl @ (major,minor=10,220)
[Sat Jan 14 19:14:16 2023] megasas: 06.808.16.00-rc1
[Sat Jan 14 19:14:16 2023] Fusion MPT SAS Host driver 3.04.20
[Sat Jan 14 19:14:16 2023] mpt3sas version 09.102.00.00 loaded
[Sat Jan 14 19:14:16 2023] usb 1-2: new high-speed USB device number 2 using xhc i_hcd
[Sat Jan 14 19:14:16 2023] rtc_cmos 00:00: RTC can wake from S4
[Sat Jan 14 19:14:16 2023] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0
[Sat Jan 14 19:14:16 2023] rtc_cmos 00:00: alarms up to one month, y3k, 242 byte s nvram
[Sat Jan 14 19:14:16 2023] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014.
[Sat Jan 14 19:14:16 2023] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000.
[Sat Jan 14 19:14:16 2023] Adaptec aacraid driver 1.2-1[41010]-ms
[Sat Jan 14 19:14:17 2023] GDT-HA: Storage RAID Controller Driver. Version: 3.05
[Sat Jan 14 19:14:17 2023] RocketRAID 3xxx/4xxx Controller driver v1.10.0
[Sat Jan 14 19:14:17 2023] isci: Intel(R) C600 SAS Controller Driver - version 1 .2.0
[Sat Jan 14 19:14:17 2023] Got empty serial number. Generate serial number from product.
[Sat Jan 14 19:14:17 2023] synobios: load, major number 201
[Sat Jan 14 19:14:17 2023] Brand: Synology
[Sat Jan 14 19:14:17 2023] Model: DS-918+
[Sat Jan 14 19:14:17 2023] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Sat Jan 14 19:14:17 2023] synobios cpu_arch proc entry initialized
[Sat Jan 14 19:14:17 2023] synobios crypto_hw proc entry initialized
[Sat Jan 14 19:14:17 2023] synobios syno_platform proc entry initialized
[Sat Jan 14 19:14:17 2023] synobios open /dev/ttyS1 success
[Sat Jan 14 19:14:17 2023] synobios: unload
[Sat Jan 14 19:14:17 2023] md: Autodetecting RAID arrays.
[Sat Jan 14 19:14:17 2023] usb 1-2.1: new high-speed USB device number 3 using x hci_hcd
[Sat Jan 14 19:14:17 2023] md: invalid raid superblock magic on sdb3
[Sat Jan 14 19:14:17 2023] md: sdb3 does not have a valid v0.90 superblock, not importing!
[Sat Jan 14 19:14:17 2023] md: invalid raid superblock magic on sdc3
[Sat Jan 14 19:14:17 2023] md: sdc3 does not have a valid v0.90 superblock, not importing!
[Sat Jan 14 19:14:17 2023] md: Scanned 6 and added 4 devices.
[Sat Jan 14 19:14:17 2023] md: autorun ...
[Sat Jan 14 19:14:17 2023] md: considering sdb1 ...
[Sat Jan 14 19:14:17 2023] md: adding sdb1 ...
[Sat Jan 14 19:14:17 2023] md: sdb2 has different UUID to sdb1
[Sat Jan 14 19:14:17 2023] md: adding sdc1 ...
[Sat Jan 14 19:14:17 2023] md: sdc2 has different UUID to sdb1
[Sat Jan 14 19:14:17 2023] md: created md0
[Sat Jan 14 19:14:17 2023] md: bind<sdc1>
[Sat Jan 14 19:14:17 2023] md: bind<sdb1>
[Sat Jan 14 19:14:17 2023] md: running: <sdb1><sdc1>
[Sat Jan 14 19:14:17 2023] md/raid1:md0: active with 2 out of 16 mirrors
[Sat Jan 14 19:14:17 2023] usb 1-2.1: ep 0x81 - rounding interval to 128 microfr ames, ep desc says 255 microframes
[Sat Jan 14 19:14:17 2023] usb 1-2.1: ep 0x2 - rounding interval to 128 microfra mes, ep desc says 255 microframes
[Sat Jan 14 19:14:17 2023] usb-storage 1-2.1:1.0: USB Mass Storage device detect ed
[Sat Jan 14 19:14:17 2023] scsi host4: usb-storage 1-2.1:1.0
[Sat Jan 14 19:14:17 2023] md0: detected capacity change from 0 to 2549940224
[Sat Jan 14 19:14:17 2023] md: considering sdb2 ...
[Sat Jan 14 19:14:17 2023] md: adding sdb2 ...
[Sat Jan 14 19:14:17 2023] md: adding sdc2 ...
[Sat Jan 14 19:14:17 2023] md: created md1
[Sat Jan 14 19:14:17 2023] md: bind<sdc2>
[Sat Jan 14 19:14:17 2023] md: bind<sdb2>
[Sat Jan 14 19:14:17 2023] md: running: <sdb2><sdc2>
[Sat Jan 14 19:14:17 2023] md/raid1:md1: active with 2 out of 16 mirrors
[Sat Jan 14 19:14:17 2023] md1: detected capacity change from 0 to 2147418112
[Sat Jan 14 19:14:33 2023] QLogic/NetXen Network Driver v4.0.82
[Sat Jan 14 19:14:33 2023] Solarflare NET driver v4.0
[Sat Jan 14 19:14:33 2023] e1000: Intel(R) PRO/1000 Network Driver - version 7.3 .21-k8-NAPI
[Sat Jan 14 19:14:33 2023] e1000: Copyright (c) 1999-2006 Intel Corporation.
[Sat Jan 14 19:14:33 2023] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.f ranken.de
[Sat Jan 14 19:14:33 2023] VMware vmxnet3 virtual NIC driver - version 1.4.5.0-k -NAPI
[Sat Jan 14 19:14:33 2023] igbvf: Intel(R) Gigabit Virtual Function Driver - 2.3 .8.2
[Sat Jan 14 19:14:33 2023] igbvf: Copyright (c) 1999-2015 Intel Corporation.
[Sat Jan 14 19:14:33 2023] ixgbevf: Intel(R) 10GbE PCI Express Virtual Function Driver - version 4.11.1
[Sat Jan 14 19:14:33 2023] ixgbevf: Copyright(c) 1999 - 2021 Intel Corporation.
[Sat Jan 14 19:14:33 2023] usbcore: registered new interface driver ax88179_178a
[Sat Jan 14 19:14:33 2023] usbcore: registered new interface driver asix
[Sat Jan 14 19:14:33 2023] Atheros(R) L2 Ethernet Driver - version 2.2.3
[Sat Jan 14 19:14:33 2023] Copyright (c) 2007 Atheros Corporation.
[Sat Jan 14 19:14:33 2023] bna: QLogic BR-series 10G Ethernet driver - version: 3.2.25.1
[Sat Jan 14 19:14:33 2023] usbcore: registered new interface driver cx82310_eth
[Sat Jan 14 19:14:34 2023] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[Sat Jan 14 19:14:34 2023] e100: Copyright(c) 1999-2006 Intel Corporation
[Sat Jan 14 19:14:34 2023] enic: Cisco VIC Ethernet NIC Driver, ver 2.3.0.20
[Sat Jan 14 19:14:34 2023] usbcore: registered new interface driver MOSCHIP usb- ethernet driver
[Sat Jan 14 19:14:34 2023] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[Sat Jan 14 19:14:34 2023] usbcore: registered new interface driver pegasus
[Sat Jan 14 19:14:34 2023] usbcore: registered new interface driver plusb
[Sat Jan 14 19:14:34 2023] usbcore: registered new interface driver rtl8150
[Sat Jan 14 19:14:34 2023] via_rhine: v1.10-LK1.5.1 2010-10-09 Written by Donald Becker
[Sat Jan 14 19:14:34 2023] usbcore: registered new interface driver r8152
[Sat Jan 14 19:14:34 2023] vxge: Copyright(c) 2002-2010 Exar Corp.
[Sat Jan 14 19:14:34 2023] vxge: Driver version: 2.5.3.22640-k
[Sat Jan 14 19:14:34 2023] usbcore: registered new interface driver aqc111
[Sat Jan 14 19:14:34 2023] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Sat Jan 14 19:14:34 2023] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Sat Jan 14 19:14:34 2023] 9pnet: Installing 9P2000 support
[Sat Jan 14 19:14:34 2023] 9p: Installing v9fs 9p2000 file system support
[Sat Jan 14 19:14:34 2023] 2023-1-14 17:14:34 UTC
[Sat Jan 14 19:14:34 2023] synobios: load, major number 201
[Sat Jan 14 19:14:34 2023] Brand: Synology
[Sat Jan 14 19:14:34 2023] Model: DS-918+
[Sat Jan 14 19:14:34 2023] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Sat Jan 14 19:14:34 2023] synobios cpu_arch proc entry initialized
[Sat Jan 14 19:14:38 2023] r8168: eth0: link up
[Sat Jan 14 19:14:38 2023] EXT4-fs (md3): barriers disabled
[Sat Jan 14 19:14:38 2023] EXT4-fs (md4): barriers disabled
[Sat Jan 14 19:14:38 2023] EXT4-fs (md3): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Sat Jan 14 19:14:39 2023] EXT4-fs (md4): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Sat Jan 14 19:14:39 2023] init: dhcp-client (eth0) main process (8386) killed b y TERM signal
[Sat Jan 14 19:14:41 2023] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) D river
[Sat Jan 14 19:14:41 2023] Warning! ehci_hcd should always be loaded before uhci _hcd and ohci_hcd, not after
[Sat Jan 14 19:14:41 2023] ehci-pci: EHCI PCI platform driver
[Sat Jan 14 19:14:41 2023] uhci_hcd: USB Universal Host Controller Interface dri ver
[Sat Jan 14 19:14:41 2023] usbcore: registered new interface driver usblp
[Sat Jan 14 19:14:41 2023] usbcore: registered new interface driver usbhid
[Sat Jan 14 19:14:41 2023] usbhid: USB HID core driver
[Sat Jan 14 19:14:42 2023] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Sat Jan 14 19:14:42 2023] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Sat Jan 14 19:14:47 2023] iSCSI:target_core_rodsp_server.c:1027:rodsp_server_in it RODSP server started, login_key(086266a3c238).
[Sat Jan 14 19:14:47 2023] iSCSI:extent_pool.c:766:ep_init syno_extent_pool succ essfully initialized
[Sat Jan 14 19:14:47 2023] iSCSI:target_core_device.c:617:se_dev_align_max_secto rs Rounding down aligned max_sectors from 4294967295 to 4294967288
[Sat Jan 14 19:14:47 2023] iSCSI:target_core_lunbackup.c:361:init_io_buffer_head 512 buffers allocated, total 2097152 bytes successfully
[Sat Jan 14 19:14:47 2023] iSCSI:target_core_file.c:146:fd_attach_hba RODSP plug in for fileio is enabled.
[Sat Jan 14 19:14:47 2023] iSCSI:target_core_file.c:153:fd_attach_hba ODX Token Manager is enabled.
[Sat Jan 14 19:14:47 2023] iSCSI:target_core_multi_file.c:91:fd_attach_hba RODSP plugin for multifile is enabled.
[Sat Jan 14 19:14:47 2023] iSCSI:target_core_ep.c:786:ep_attach_hba RODSP plugin for epio is enabled.
[Mon Jan 23 14:56:18 2023] Loaded X.509 cert 'Synology Kernel Module Signing Cer tification Authority: 600839b5d127e0e11d817a31f0575d323a7c0e28'
[Mon Jan 23 14:56:18 2023] Loaded X.509 cert 'Synology kernel module signing key : 4646ce54489669338118a3b1286da156ac366fa5'
[Mon Jan 23 14:56:18 2023] page_owner is disabled
[Mon Jan 23 14:56:18 2023] AppArmor: AppArmor sha1 policy hashing enabled
[Mon Jan 23 14:56:18 2023] hctosys: unable to open rtc device (rtc0)
[Mon Jan 23 14:56:18 2023] Freeing unused kernel memory: 864K (ffffffff81879000 - ffffffff81951000)
[Mon Jan 23 14:56:18 2023] Write protecting the kernel read-only data: 8192k
[Mon Jan 23 14:56:18 2023] Freeing unused kernel memory: 520K (ffff88000157e000 - ffff880001600000)
[Mon Jan 23 14:56:18 2023] Freeing unused kernel memory: 200K (ffff8800017ce000 - ffff880001800000)
[Mon Jan 23 14:56:18 2023] ACPI: bus type USB registered
[Mon Jan 23 14:56:18 2023] usbcore: registered new interface driver usbfs
[Mon Jan 23 14:56:18 2023] usbcore: registered new interface driver hub
[Mon Jan 23 14:56:18 2023] usbcore: registered new interface driver ethub
[Mon Jan 23 14:56:18 2023] usbcore: registered new device driver usb
[Mon Jan 23 14:56:18 2023] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Drive r
[Mon Jan 23 14:56:18 2023] xhci_hcd 0000:00:14.0: xHCI Host Controller
[Mon Jan 23 14:56:18 2023] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 1
[Mon Jan 23 14:56:18 2023] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci vers ion 0x100 quirks 0x00009010
[Mon Jan 23 14:56:18 2023] xhci_hcd 0000:00:14.0: cache line size of 64 is not s upported
[Mon Jan 23 14:56:18 2023] hub 1-0:1.0: USB hub found
[Mon Jan 23 14:56:18 2023] hub 1-0:1.0: 6 ports detected
[Mon Jan 23 14:56:18 2023] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 2
[Mon Jan 23 14:56:18 2023] usb usb2: We don't know the algorithms for LPM for th is host, disabling LPM.
[Mon Jan 23 14:56:18 2023] hub 2-0:1.0: USB hub found
[Mon Jan 23 14:56:18 2023] hub 2-0:1.0: 1 port detected
[Mon Jan 23 14:56:18 2023] usbcore: registered new interface driver usb-storage
[Mon Jan 23 14:56:18 2023] VMware PVSCSI driver - version 1.0.5.0-k
[Mon Jan 23 14:56:18 2023] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:0 1:03 EST 2006)
[Mon Jan 23 14:56:18 2023] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
[Mon Jan 23 14:56:18 2023] Fusion MPT base driver 3.04.20
[Mon Jan 23 14:56:18 2023] Copyright (c) 1999-2008 LSI Corporation
[Mon Jan 23 14:56:18 2023] Fusion MPT SPI Host driver 3.04.20
[Mon Jan 23 14:56:18 2023] Fusion MPT misc device (ioctl) driver 3.04.20
[Mon Jan 23 14:56:18 2023] mptctl: Registered with Fusion MPT base driver
[Mon Jan 23 14:56:18 2023] mptctl: /dev/mptctl @ (major,minor=10,220)
[Mon Jan 23 14:56:18 2023] megasas: 06.808.16.00-rc1
[Mon Jan 23 14:56:18 2023] Fusion MPT SAS Host driver 3.04.20
[Mon Jan 23 14:56:18 2023] mpt3sas version 09.102.00.00 loaded
[Mon Jan 23 14:56:18 2023] usb 1-2: new high-speed USB device number 2 using xhc i_hcd
[Mon Jan 23 14:56:18 2023] rtc_cmos 00:00: RTC can wake from S4
[Mon Jan 23 14:56:18 2023] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0
[Mon Jan 23 14:56:18 2023] rtc_cmos 00:00: alarms up to one month, y3k, 242 byte s nvram
[Mon Jan 23 14:56:18 2023] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014.
[Mon Jan 23 14:56:19 2023] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000.
[Mon Jan 23 14:56:19 2023] Adaptec aacraid driver 1.2-1[41010]-ms
[Mon Jan 23 14:56:19 2023] GDT-HA: Storage RAID Controller Driver. Version: 3.05
[Mon Jan 23 14:56:19 2023] RocketRAID 3xxx/4xxx Controller driver v1.10.0
[Mon Jan 23 14:56:19 2023] isci: Intel(R) C600 SAS Controller Driver - version 1 .2.0
[Mon Jan 23 14:56:19 2023] Got empty serial number. Generate serial number from product.
[Mon Jan 23 14:56:19 2023] synobios: load, major number 201
[Mon Jan 23 14:56:19 2023] Brand: Synology
[Mon Jan 23 14:56:19 2023] Model: DS-918+
[Mon Jan 23 14:56:19 2023] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Mon Jan 23 14:56:19 2023] synobios cpu_arch proc entry initialized
[Mon Jan 23 14:56:19 2023] synobios crypto_hw proc entry initialized
[Mon Jan 23 14:56:19 2023] synobios syno_platform proc entry initialized
[Mon Jan 23 14:56:19 2023] synobios open /dev/ttyS1 success
[Mon Jan 23 14:56:19 2023] synobios: unload
[Mon Jan 23 14:56:19 2023] md: Autodetecting RAID arrays.
[Mon Jan 23 14:56:19 2023] usb 1-2.1: new high-speed USB device number 3 using x hci_hcd
[Mon Jan 23 14:56:19 2023] md: invalid raid superblock magic on sdb3
[Mon Jan 23 14:56:19 2023] md: sdb3 does not have a valid v0.90 superblock, not importing!
[Mon Jan 23 14:56:19 2023] usb 1-2.1: ep 0x81 - rounding interval to 128 microfr ames, ep desc says 255 microframes
[Mon Jan 23 14:56:19 2023] usb 1-2.1: ep 0x2 - rounding interval to 128 microfra mes, ep desc says 255 microframes
[Mon Jan 23 14:56:19 2023] usb-storage 1-2.1:1.0: USB Mass Storage device detect ed
[Mon Jan 23 14:56:19 2023] scsi host4: usb-storage 1-2.1:1.0
[Mon Jan 23 14:56:19 2023] md: invalid raid superblock magic on sdc3
[Mon Jan 23 14:56:19 2023] md: sdc3 does not have a valid v0.90 superblock, not importing!
[Mon Jan 23 14:56:19 2023] md: Scanned 6 and added 4 devices.
[Mon Jan 23 14:56:19 2023] md: autorun ...
[Mon Jan 23 14:56:19 2023] md: considering sdb1 ...
[Mon Jan 23 14:56:19 2023] md: adding sdb1 ...
[Mon Jan 23 14:56:19 2023] md: sdb2 has different UUID to sdb1
[Mon Jan 23 14:56:19 2023] md: adding sdc1 ...
[Mon Jan 23 14:56:19 2023] md: sdc2 has different UUID to sdb1
[Mon Jan 23 14:56:19 2023] md: created md0
[Mon Jan 23 14:56:35 2023] QLogic/NetXen Network Driver v4.0.82
[Mon Jan 23 14:56:35 2023] Solarflare NET driver v4.0
[Mon Jan 23 14:56:35 2023] e1000: Intel(R) PRO/1000 Network Driver - version 7.3 .21-k8-NAPI
[Mon Jan 23 14:56:35 2023] e1000: Copyright (c) 1999-2006 Intel Corporation.
[Mon Jan 23 14:56:35 2023] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.f ranken.de
[Mon Jan 23 14:56:35 2023] VMware vmxnet3 virtual NIC driver - version 1.4.5.0-k -NAPI
[Mon Jan 23 14:56:35 2023] igbvf: Intel(R) Gigabit Virtual Function Driver - 2.3 .8.2
[Mon Jan 23 14:56:35 2023] igbvf: Copyright (c) 1999-2015 Intel Corporation.
[Mon Jan 23 14:56:35 2023] ixgbevf: Intel(R) 10GbE PCI Express Virtual Function Driver - version 4.11.1
[Mon Jan 23 14:56:35 2023] ixgbevf: Copyright(c) 1999 - 2021 Intel Corporation.
[Mon Jan 23 14:56:36 2023] usbcore: registered new interface driver ax88179_178a
[Mon Jan 23 14:56:36 2023] usbcore: registered new interface driver asix
[Mon Jan 23 14:56:36 2023] Atheros(R) L2 Ethernet Driver - version 2.2.3
[Mon Jan 23 14:56:36 2023] Copyright (c) 2007 Atheros Corporation.
[Mon Jan 23 14:56:36 2023] bna: QLogic BR-series 10G Ethernet driver - version: 3.2.25.1
[Mon Jan 23 14:56:36 2023] usbcore: registered new interface driver cx82310_eth
[Mon Jan 23 14:56:36 2023] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[Mon Jan 23 14:56:36 2023] e100: Copyright(c) 1999-2006 Intel Corporation
[Mon Jan 23 14:56:36 2023] enic: Cisco VIC Ethernet NIC Driver, ver 2.3.0.20
[Mon Jan 23 14:56:36 2023] usbcore: registered new interface driver MOSCHIP usb- ethernet driver
[Mon Jan 23 14:56:36 2023] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[Mon Jan 23 14:56:36 2023] usbcore: registered new interface driver pegasus
[Mon Jan 23 14:56:36 2023] usbcore: registered new interface driver plusb
[Mon Jan 23 14:56:36 2023] usbcore: registered new interface driver rtl8150
[Mon Jan 23 14:56:36 2023] via_rhine: v1.10-LK1.5.1 2010-10-09 Written by Donald Becker
[Mon Jan 23 14:56:36 2023] usbcore: registered new interface driver r8152
[Mon Jan 23 14:56:36 2023] vxge: Copyright(c) 2002-2010 Exar Corp.
[Mon Jan 23 14:56:36 2023] vxge: Driver version: 2.5.3.22640-k
[Mon Jan 23 14:56:36 2023] usbcore: registered new interface driver aqc111
[Mon Jan 23 14:56:36 2023] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Mon Jan 23 14:56:36 2023] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Mon Jan 23 14:56:36 2023] 9pnet: Installing 9P2000 support
[Mon Jan 23 14:56:36 2023] 9p: Installing v9fs 9p2000 file system support
[Mon Jan 23 14:56:36 2023] 2023-1-23 12:56:37 UTC
[Mon Jan 23 14:56:36 2023] synobios: load, major number 201
[Mon Jan 23 14:56:36 2023] Brand: Synology
[Mon Jan 23 14:56:36 2023] Model: DS-918+
[Mon Jan 23 14:56:36 2023] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Mon Jan 23 14:56:36 2023] synobios cpu_arch proc entry initialized
[Mon Jan 23 14:56:41 2023] EXT4-fs (md4): barriers disabled
[Mon Jan 23 14:56:41 2023] EXT4-fs (md3): barriers disabled
[Mon Jan 23 14:56:41 2023] EXT4-fs (md4): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Mon Jan 23 14:56:41 2023] EXT4-fs (md3): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Mon Jan 23 14:56:41 2023] r8168: eth0: link up
[Mon Jan 23 14:56:43 2023] init: dhcp-client (eth0) main process (8347) killed b y TERM signal
[Mon Jan 23 14:56:43 2023] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) D river
[Mon Jan 23 14:56:43 2023] Warning! ehci_hcd should always be loaded before uhci _hcd and ohci_hcd, not after
[Mon Jan 23 14:56:43 2023] ehci-pci: EHCI PCI platform driver
[Mon Jan 23 14:56:43 2023] uhci_hcd: USB Universal Host Controller Interface dri ver
[Mon Jan 23 14:56:43 2023] usbcore: registered new interface driver usblp
[Mon Jan 23 14:56:44 2023] usbcore: registered new interface driver usbhid
[Mon Jan 23 14:56:44 2023] usbhid: USB HID core driver
[Mon Jan 23 14:56:45 2023] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Mon Jan 23 14:56:45 2023] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Mon Jan 23 14:56:48 2023] FAT-fs (synoboot2): fat_set_state: set=1 process=syno pkicompatsy pid=10581
[Mon Jan 23 14:56:48 2023] FAT-fs (synoboot2): fat_set_state: set=0 process=syno pkicompatsy pid=10581
[Mon Jan 23 14:56:49 2023] Installing knfsd (copyright (C) 1996 okir@monad.swb.d e).
[Mon Jan 23 14:56:50 2023] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 stat e recovery directory
[Mon Jan 23 14:56:50 2023] NFSD: starting 90-second grace period (net ffffffff81 862d80)
[Mon Jan 23 14:56:50 2023] iSCSI:target_core_rodsp_server.c:1027:rodsp_server_in it RODSP server started, login_key(086266a3c238).
[Mon Jan 23 14:56:50 2023] iSCSI:extent_pool.c:766:ep_init syno_extent_pool succ essfully initialized
[Mon Jan 23 14:56:50 2023] iSCSI:target_core_device.c:617:se_dev_align_max_secto rs Rounding down aligned max_sectors from 4294967295 to 4294967288
[Tue Jan 24 11:32:07 2023] Loaded X.509 cert 'Synology Kernel Module Signing Cer tification Authority: 600839b5d127e0e11d817a31f0575d323a7c0e28'
[Tue Jan 24 11:32:07 2023] Loaded X.509 cert 'Synology kernel module signing key : 4646ce54489669338118a3b1286da156ac366fa5'
[Tue Jan 24 11:32:07 2023] page_owner is disabled
[Tue Jan 24 11:32:07 2023] AppArmor: AppArmor sha1 policy hashing enabled
[Tue Jan 24 11:32:07 2023] hctosys: unable to open rtc device (rtc0)
[Tue Jan 24 11:32:07 2023] Freeing unused kernel memory: 864K (ffffffff81879000 - ffffffff81951000)
[Tue Jan 24 11:32:07 2023] Write protecting the kernel read-only data: 8192k
[Tue Jan 24 11:32:07 2023] Freeing unused kernel memory: 520K (ffff88000157e000 - ffff880001600000)
[Tue Jan 24 11:32:07 2023] Freeing unused kernel memory: 200K (ffff8800017ce000 - ffff880001800000)
[Tue Jan 24 11:32:07 2023] ACPI: bus type USB registered
[Tue Jan 24 11:32:07 2023] usbcore: registered new interface driver usbfs
[Tue Jan 24 11:32:07 2023] usbcore: registered new interface driver hub
[Tue Jan 24 11:32:07 2023] usbcore: registered new interface driver ethub
[Tue Jan 24 11:32:07 2023] usbcore: registered new device driver usb
[Tue Jan 24 11:32:07 2023] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Drive r
[Tue Jan 24 11:32:07 2023] xhci_hcd 0000:00:14.0: xHCI Host Controller
[Tue Jan 24 11:32:07 2023] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 1
[Tue Jan 24 11:32:07 2023] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci vers ion 0x100 quirks 0x00009010
[Tue Jan 24 11:32:07 2023] xhci_hcd 0000:00:14.0: cache line size of 64 is not s upported
[Tue Jan 24 11:32:07 2023] hub 1-0:1.0: USB hub found
[Tue Jan 24 11:32:07 2023] hub 1-0:1.0: 6 ports detected
[Tue Jan 24 11:32:07 2023] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 2
[Tue Jan 24 11:32:07 2023] usb usb2: We don't know the algorithms for LPM for th is host, disabling LPM.
[Tue Jan 24 11:32:07 2023] hub 2-0:1.0: USB hub found
[Tue Jan 24 11:32:07 2023] hub 2-0:1.0: 1 port detected
[Tue Jan 24 11:32:07 2023] usbcore: registered new interface driver usb-storage
[Tue Jan 24 11:32:07 2023] VMware PVSCSI driver - version 1.0.5.0-k
[Tue Jan 24 11:32:07 2023] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:0 1:03 EST 2006)
[Tue Jan 24 11:32:07 2023] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
[Tue Jan 24 11:32:07 2023] Fusion MPT base driver 3.04.20
[Tue Jan 24 11:32:07 2023] Copyright (c) 1999-2008 LSI Corporation
[Tue Jan 24 11:32:08 2023] Fusion MPT SPI Host driver 3.04.20
[Tue Jan 24 11:32:08 2023] Fusion MPT misc device (ioctl) driver 3.04.20
[Tue Jan 24 11:32:08 2023] mptctl: Registered with Fusion MPT base driver
[Tue Jan 24 11:32:08 2023] mptctl: /dev/mptctl @ (major,minor=10,220)
[Tue Jan 24 11:32:08 2023] megasas: 06.808.16.00-rc1
[Tue Jan 24 11:32:08 2023] Fusion MPT SAS Host driver 3.04.20
[Tue Jan 24 11:32:08 2023] mpt3sas version 09.102.00.00 loaded
[Tue Jan 24 11:32:08 2023] usb 1-2: new high-speed USB device number 2 using xhc i_hcd
[Tue Jan 24 11:32:08 2023] rtc_cmos 00:00: RTC can wake from S4
[Tue Jan 24 11:32:08 2023] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0
[Tue Jan 24 11:32:08 2023] rtc_cmos 00:00: alarms up to one month, y3k, 242 byte s nvram
[Tue Jan 24 11:32:08 2023] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014.
[Tue Jan 24 11:32:08 2023] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000.
[Tue Jan 24 11:32:08 2023] Adaptec aacraid driver 1.2-1[41010]-ms
[Tue Jan 24 11:32:08 2023] GDT-HA: Storage RAID Controller Driver. Version: 3.05
[Tue Jan 24 11:32:08 2023] RocketRAID 3xxx/4xxx Controller driver v1.10.0
[Tue Jan 24 11:32:08 2023] isci: Intel(R) C600 SAS Controller Driver - version 1 .2.0
[Tue Jan 24 11:32:08 2023] Got empty serial number. Generate serial number from product.
[Tue Jan 24 11:32:08 2023] synobios: load, major number 201
[Tue Jan 24 11:32:08 2023] Brand: Synology
[Tue Jan 24 11:32:08 2023] Model: DS-918+
[Tue Jan 24 11:32:08 2023] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Tue Jan 24 11:32:08 2023] synobios cpu_arch proc entry initialized
[Tue Jan 24 11:32:08 2023] synobios crypto_hw proc entry initialized
[Tue Jan 24 11:32:08 2023] synobios syno_platform proc entry initialized
[Tue Jan 24 11:32:08 2023] synobios open /dev/ttyS1 success
[Tue Jan 24 11:32:08 2023] synobios: unload
[Tue Jan 24 11:32:08 2023] md: Autodetecting RAID arrays.
[Tue Jan 24 11:32:08 2023] usb 1-2.1: new high-speed USB device number 3 using x hci_hcd
[Tue Jan 24 11:32:08 2023] md: invalid raid superblock magic on sdb3
[Tue Jan 24 11:32:08 2023] md: sdb3 does not have a valid v0.90 superblock, not importing!
[Tue Jan 24 11:32:08 2023] usb 1-2.1: ep 0x81 - rounding interval to 128 microfr ames, ep desc says 255 microframes
[Tue Jan 24 11:32:08 2023] usb 1-2.1: ep 0x2 - rounding interval to 128 microfra mes, ep desc says 255 microframes
[Tue Jan 24 11:32:08 2023] usb-storage 1-2.1:1.0: USB Mass Storage device detect ed
[Tue Jan 24 11:32:08 2023] scsi host4: usb-storage 1-2.1:1.0
[Tue Jan 24 11:32:08 2023] md: invalid raid superblock magic on sdc3
[Tue Jan 24 11:32:08 2023] md: sdc3 does not have a valid v0.90 superblock, not importing!
[Tue Jan 24 11:32:08 2023] md: Scanned 6 and added 4 devices.
[Tue Jan 24 11:32:08 2023] md: autorun ...
[Tue Jan 24 11:32:08 2023] md: considering sdb1 ...
[Tue Jan 24 11:32:08 2023] md: adding sdb1 ...
[Tue Jan 24 11:32:08 2023] md: sdb2 has different UUID to sdb1
[Tue Jan 24 11:32:08 2023] md: adding sdc1 ...
[Tue Jan 24 11:32:08 2023] md: sdc2 has different UUID to sdb1
[Tue Jan 24 11:32:08 2023] md: created md0
[Tue Jan 24 11:32:24 2023] Solarflare NET driver v4.0
[Tue Jan 24 11:32:24 2023] e1000: Intel(R) PRO/1000 Network Driver - version 7.3 .21-k8-NAPI
[Tue Jan 24 11:32:24 2023] e1000: Copyright (c) 1999-2006 Intel Corporation.
[Tue Jan 24 11:32:24 2023] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.f ranken.de
[Tue Jan 24 11:32:24 2023] VMware vmxnet3 virtual NIC driver - version 1.4.5.0-k -NAPI
[Tue Jan 24 11:32:24 2023] systemd-udevd[6710]: starting version 204
[Tue Jan 24 11:32:24 2023] igbvf: Intel(R) Gigabit Virtual Function Driver - 2.3 .8.2
[Tue Jan 24 11:32:24 2023] igbvf: Copyright (c) 1999-2015 Intel Corporation.
[Tue Jan 24 11:32:24 2023] ixgbevf: Intel(R) 10GbE PCI Express Virtual Function Driver - version 4.11.1
[Tue Jan 24 11:32:24 2023] ixgbevf: Copyright(c) 1999 - 2021 Intel Corporation.
[Tue Jan 24 11:32:24 2023] usbcore: registered new interface driver ax88179_178a
[Tue Jan 24 11:32:24 2023] usbcore: registered new interface driver asix
[Tue Jan 24 11:32:24 2023] Atheros(R) L2 Ethernet Driver - version 2.2.3
[Tue Jan 24 11:32:24 2023] Copyright (c) 2007 Atheros Corporation.
[Tue Jan 24 11:32:24 2023] bna: QLogic BR-series 10G Ethernet driver - version: 3.2.25.1
[Tue Jan 24 11:32:24 2023] usbcore: registered new interface driver cx82310_eth
[Tue Jan 24 11:32:24 2023] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[Tue Jan 24 11:32:24 2023] e100: Copyright(c) 1999-2006 Intel Corporation
[Tue Jan 24 11:32:24 2023] enic: Cisco VIC Ethernet NIC Driver, ver 2.3.0.20
[Tue Jan 24 11:32:24 2023] usbcore: registered new interface driver MOSCHIP usb- ethernet driver
[Tue Jan 24 11:32:24 2023] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[Tue Jan 24 11:32:24 2023] usbcore: registered new interface driver pegasus
[Tue Jan 24 11:32:24 2023] usbcore: registered new interface driver plusb
[Tue Jan 24 11:32:24 2023] usbcore: registered new interface driver rtl8150
[Tue Jan 24 11:32:25 2023] via_rhine: v1.10-LK1.5.1 2010-10-09 Written by Donald Becker
[Tue Jan 24 11:32:25 2023] usbcore: registered new interface driver r8152
[Tue Jan 24 11:32:25 2023] vxge: Copyright(c) 2002-2010 Exar Corp.
[Tue Jan 24 11:32:25 2023] vxge: Driver version: 2.5.3.22640-k
[Tue Jan 24 11:32:25 2023] usbcore: registered new interface driver aqc111
[Tue Jan 24 11:32:25 2023] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Tue Jan 24 11:32:25 2023] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Tue Jan 24 11:32:25 2023] 9pnet: Installing 9P2000 support
[Tue Jan 24 11:32:25 2023] 9p: Installing v9fs 9p2000 file system support
[Tue Jan 24 11:32:25 2023] 2023-1-24 9:32:25 UTC
[Tue Jan 24 11:32:25 2023] synobios: load, major number 201
[Tue Jan 24 11:32:25 2023] Brand: Synology
[Tue Jan 24 11:32:25 2023] Model: DS-918+
[Tue Jan 24 11:32:25 2023] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Tue Jan 24 11:32:25 2023] synobios cpu_arch proc entry initialized
[Tue Jan 24 11:32:29 2023] r8168: eth0: link up
[Tue Jan 24 11:32:29 2023] EXT4-fs (md4): barriers disabled
[Tue Jan 24 11:32:29 2023] EXT4-fs (md3): barriers disabled
[Tue Jan 24 11:32:30 2023] EXT4-fs (md4): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Tue Jan 24 11:32:30 2023] EXT4-fs (md3): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Tue Jan 24 11:32:30 2023] init: dhcp-client (eth0) main process (8340) killed b y TERM signal
[Tue Jan 24 11:32:32 2023] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) D river
[Tue Jan 24 11:32:32 2023] Warning! ehci_hcd should always be loaded before uhci _hcd and ohci_hcd, not after
[Tue Jan 24 11:32:32 2023] ehci-pci: EHCI PCI platform driver
[Tue Jan 24 11:32:32 2023] uhci_hcd: USB Universal Host Controller Interface dri ver
[Tue Jan 24 11:32:32 2023] usbcore: registered new interface driver usblp
[Tue Jan 24 11:32:32 2023] usbcore: registered new interface driver usbhid
[Tue Jan 24 11:32:32 2023] usbhid: USB HID core driver
[Tue Jan 24 11:32:33 2023] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Tue Jan 24 11:32:33 2023] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Tue Jan 24 11:32:37 2023] FAT-fs (synoboot2): fat_set_state: set=1 process=syno pkicompatsy pid=10574
[Tue Jan 24 11:32:37 2023] FAT-fs (synoboot2): fat_set_state: set=0 process=syno pkicompatsy pid=10574
[Tue Jan 24 11:32:39 2023] Installing knfsd (copyright (C) 1996 okir@monad.swb.d e).
[Tue Jan 24 11:32:39 2023] ata2.00: configured for UDMA/133
[Tue Jan 24 11:32:39 2023] ata2: EH complete
[Tue Jan 24 11:32:39 2023] iSCSI:target_core_rodsp_server.c:1027:rodsp_server_in it RODSP server started, login_key(086266a3c238).
[Tue Jan 24 11:32:39 2023] iSCSI:extent_pool.c:766:ep_init syno_extent_pool succ essfully initialized
[Tue Jan 24 11:32:39 2023] iSCSI:target_core_device.c:617:se_dev_align_max_secto rs Rounding down aligned max_sectors from 4294967295 to 4294967288
[Tue Jan 31 14:10:38 2023] Loaded X.509 cert 'Synology Kernel Module Signing Cer tification Authority: 600839b5d127e0e11d817a31f0575d323a7c0e28'
[Tue Jan 31 14:10:38 2023] Loaded X.509 cert 'Synology kernel module signing key : 4646ce54489669338118a3b1286da156ac366fa5'
[Tue Jan 31 14:10:38 2023] page_owner is disabled
[Tue Jan 31 14:10:38 2023] AppArmor: AppArmor sha1 policy hashing enabled
[Tue Jan 31 14:10:38 2023] hctosys: unable to open rtc device (rtc0)
[Tue Jan 31 14:10:38 2023] Freeing unused kernel memory: 864K (ffffffff81879000 - ffffffff81951000)
[Tue Jan 31 14:10:38 2023] Write protecting the kernel read-only data: 8192k
[Tue Jan 31 14:10:38 2023] Freeing unused kernel memory: 520K (ffff88000157e000 - ffff880001600000)
[Tue Jan 31 14:10:38 2023] Freeing unused kernel memory: 200K (ffff8800017ce000 - ffff880001800000)
[Tue Jan 31 14:10:38 2023] ACPI: bus type USB registered
[Tue Jan 31 14:10:38 2023] usbcore: registered new interface driver usbfs
[Tue Jan 31 14:10:38 2023] usbcore: registered new interface driver hub
[Tue Jan 31 14:10:38 2023] usbcore: registered new interface driver ethub
[Tue Jan 31 14:10:38 2023] usbcore: registered new device driver usb
[Tue Jan 31 14:10:38 2023] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Drive r
[Tue Jan 31 14:10:38 2023] xhci_hcd 0000:00:14.0: xHCI Host Controller
[Tue Jan 31 14:10:38 2023] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 1
[Tue Jan 31 14:10:38 2023] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci vers ion 0x100 quirks 0x00009010
[Tue Jan 31 14:10:38 2023] xhci_hcd 0000:00:14.0: cache line size of 64 is not s upported
[Tue Jan 31 14:10:38 2023] hub 1-0:1.0: USB hub found
[Tue Jan 31 14:10:38 2023] hub 1-0:1.0: 6 ports detected
[Tue Jan 31 14:10:38 2023] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 2
[Tue Jan 31 14:10:38 2023] usb usb2: We don't know the algorithms for LPM for th is host, disabling LPM.
[Tue Jan 31 14:10:38 2023] hub 2-0:1.0: USB hub found
[Tue Jan 31 14:10:38 2023] hub 2-0:1.0: 1 port detected
[Tue Jan 31 14:10:38 2023] usbcore: registered new interface driver usb-storage
[Tue Jan 31 14:10:38 2023] VMware PVSCSI driver - version 1.0.5.0-k
[Tue Jan 31 14:10:38 2023] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:0 1:03 EST 2006)
[Tue Jan 31 14:10:38 2023] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
[Tue Jan 31 14:10:38 2023] Fusion MPT base driver 3.04.20
[Tue Jan 31 14:10:38 2023] Copyright (c) 1999-2008 LSI Corporation
[Tue Jan 31 14:10:38 2023] Fusion MPT SPI Host driver 3.04.20
[Tue Jan 31 14:10:38 2023] Fusion MPT misc device (ioctl) driver 3.04.20
[Tue Jan 31 14:10:38 2023] mptctl: Registered with Fusion MPT base driver
[Tue Jan 31 14:10:38 2023] mptctl: /dev/mptctl @ (major,minor=10,220)
[Tue Jan 31 14:10:38 2023] megasas: 06.808.16.00-rc1
[Tue Jan 31 14:10:38 2023] Fusion MPT SAS Host driver 3.04.20
[Tue Jan 31 14:10:38 2023] mpt3sas version 09.102.00.00 loaded
[Tue Jan 31 14:10:38 2023] usb 1-2: new high-speed USB device number 2 using xhc i_hcd
[Tue Jan 31 14:10:38 2023] rtc_cmos 00:00: RTC can wake from S4
[Tue Jan 31 14:10:38 2023] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0
[Tue Jan 31 14:10:38 2023] rtc_cmos 00:00: alarms up to one month, y3k, 242 byte s nvram
[Tue Jan 31 14:10:38 2023] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014.
[Tue Jan 31 14:10:38 2023] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000.
[Tue Jan 31 14:10:38 2023] Adaptec aacraid driver 1.2-1[41010]-ms
[Tue Jan 31 14:10:39 2023] GDT-HA: Storage RAID Controller Driver. Version: 3.05
[Tue Jan 31 14:10:39 2023] RocketRAID 3xxx/4xxx Controller driver v1.10.0
[Tue Jan 31 14:10:39 2023] isci: Intel(R) C600 SAS Controller Driver - version 1 .2.0
[Tue Jan 31 14:10:39 2023] Got empty serial number. Generate serial number from product.
[Tue Jan 31 14:10:39 2023] synobios: load, major number 201
[Tue Jan 31 14:10:39 2023] Brand: Synology
[Tue Jan 31 14:10:39 2023] Model: DS-918+
[Tue Jan 31 14:10:39 2023] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Tue Jan 31 14:10:39 2023] synobios cpu_arch proc entry initialized
[Tue Jan 31 14:10:39 2023] synobios crypto_hw proc entry initialized
[Tue Jan 31 14:10:39 2023] synobios syno_platform proc entry initialized
[Tue Jan 31 14:10:39 2023] synobios open /dev/ttyS1 success
[Tue Jan 31 14:10:39 2023] synobios: unload
[Tue Jan 31 14:10:39 2023] md: Autodetecting RAID arrays.
[Tue Jan 31 14:10:39 2023] usb 1-2.1: new high-speed USB device number 3 using x hci_hcd
[Tue Jan 31 14:10:39 2023] md: invalid raid superblock magic on sdb3
[Tue Jan 31 14:10:39 2023] md: sdb3 does not have a valid v0.90 superblock, not importing!
[Tue Jan 31 14:10:39 2023] md: invalid raid superblock magic on sdc3
[Tue Jan 31 14:10:39 2023] md: sdc3 does not have a valid v0.90 superblock, not importing!
[Tue Jan 31 14:10:39 2023] md: Scanned 6 and added 4 devices.
[Tue Jan 31 14:10:39 2023] md: autorun ...
[Tue Jan 31 14:10:39 2023] md: considering sdb1 ...
[Tue Jan 31 14:10:39 2023] md: adding sdb1 ...
[Tue Jan 31 14:10:39 2023] md: sdb2 has different UUID to sdb1
[Tue Jan 31 14:10:39 2023] md: adding sdc1 ...
[Tue Jan 31 14:10:39 2023] md: sdc2 has different UUID to sdb1
[Tue Jan 31 14:10:39 2023] md: created md0
[Tue Jan 31 14:10:39 2023] md: bind<sdc1>
[Tue Jan 31 14:10:39 2023] md: bind<sdb1>
[Tue Jan 31 14:10:39 2023] md: running: <sdb1><sdc1>
[Tue Jan 31 14:10:39 2023] md/raid1:md0: active with 2 out of 16 mirrors
[Tue Jan 31 14:10:39 2023] usb 1-2.1: ep 0x81 - rounding interval to 128 microfr ames, ep desc says 255 microframes
[Tue Jan 31 14:10:39 2023] usb 1-2.1: ep 0x2 - rounding interval to 128 microfra mes, ep desc says 255 microframes
[Tue Jan 31 14:10:39 2023] usb-storage 1-2.1:1.0: USB Mass Storage device detect ed
[Tue Jan 31 14:10:39 2023] scsi host4: usb-storage 1-2.1:1.0
[Tue Jan 31 14:10:39 2023] md0: detected capacity change from 0 to 2549940224
[Tue Jan 31 14:10:39 2023] md: considering sdb2 ...
[Tue Jan 31 14:10:39 2023] md: adding sdb2 ...
[Tue Jan 31 14:10:39 2023] md: adding sdc2 ...
[Tue Jan 31 14:10:39 2023] md: created md1
[Tue Jan 31 14:10:39 2023] md: bind<sdc2>
[Tue Jan 31 14:10:39 2023] md: bind<sdb2>
[Tue Jan 31 14:10:39 2023] md: running: <sdb2><sdc2>
[Tue Jan 31 14:10:39 2023] md/raid1:md1: active with 2 out of 16 mirrors
[Tue Jan 31 14:10:39 2023] md1: detected capacity change from 0 to 2147418112
[Tue Jan 31 14:10:56 2023] QLogic/NetXen Network Driver v4.0.82
[Tue Jan 31 14:10:56 2023] Solarflare NET driver v4.0
[Tue Jan 31 14:10:56 2023] e1000: Intel(R) PRO/1000 Network Driver - version 7.3 .21-k8-NAPI
[Tue Jan 31 14:10:56 2023] e1000: Copyright (c) 1999-2006 Intel Corporation.
[Tue Jan 31 14:10:56 2023] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.f ranken.de
[Tue Jan 31 14:10:56 2023] VMware vmxnet3 virtual NIC driver - version 1.4.5.0-k -NAPI
[Tue Jan 31 14:10:56 2023] igbvf: Intel(R) Gigabit Virtual Function Driver - 2.3 .8.2
[Tue Jan 31 14:10:56 2023] igbvf: Copyright (c) 1999-2015 Intel Corporation.
[Tue Jan 31 14:10:56 2023] ixgbevf: Intel(R) 10GbE PCI Express Virtual Function Driver - version 4.11.1
[Tue Jan 31 14:10:56 2023] ixgbevf: Copyright(c) 1999 - 2021 Intel Corporation.
[Tue Jan 31 14:10:56 2023] usbcore: registered new interface driver ax88179_178a
[Tue Jan 31 14:10:56 2023] usbcore: registered new interface driver asix
[Tue Jan 31 14:10:56 2023] Atheros(R) L2 Ethernet Driver - version 2.2.3
[Tue Jan 31 14:10:56 2023] Copyright (c) 2007 Atheros Corporation.
[Tue Jan 31 14:10:56 2023] bna: QLogic BR-series 10G Ethernet driver - version: 3.2.25.1
[Tue Jan 31 14:10:56 2023] usbcore: registered new interface driver cx82310_eth
[Tue Jan 31 14:10:56 2023] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[Tue Jan 31 14:10:56 2023] e100: Copyright(c) 1999-2006 Intel Corporation
[Tue Jan 31 14:10:56 2023] enic: Cisco VIC Ethernet NIC Driver, ver 2.3.0.20
[Tue Jan 31 14:10:56 2023] usbcore: registered new interface driver MOSCHIP usb- ethernet driver
[Tue Jan 31 14:10:56 2023] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[Tue Jan 31 14:10:56 2023] usbcore: registered new interface driver pegasus
[Tue Jan 31 14:10:56 2023] usbcore: registered new interface driver plusb
[Tue Jan 31 14:10:56 2023] usbcore: registered new interface driver rtl8150
[Tue Jan 31 14:10:56 2023] via_rhine: v1.10-LK1.5.1 2010-10-09 Written by Donald Becker
[Tue Jan 31 14:10:56 2023] usbcore: registered new interface driver r8152
[Tue Jan 31 14:10:56 2023] vxge: Copyright(c) 2002-2010 Exar Corp.
[Tue Jan 31 14:10:56 2023] vxge: Driver version: 2.5.3.22640-k
[Tue Jan 31 14:10:56 2023] usbcore: registered new interface driver aqc111
[Tue Jan 31 14:10:56 2023] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Tue Jan 31 14:10:56 2023] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Tue Jan 31 14:10:56 2023] 9pnet: Installing 9P2000 support
[Tue Jan 31 14:10:57 2023] 9p: Installing v9fs 9p2000 file system support
[Tue Jan 31 14:10:57 2023] 2023-1-31 12:10:58 UTC
[Tue Jan 31 14:10:57 2023] synobios: load, major number 201
[Tue Jan 31 14:10:57 2023] Brand: Synology
[Tue Jan 31 14:10:57 2023] Model: DS-918+
[Tue Jan 31 14:10:57 2023] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Tue Jan 31 14:10:57 2023] synobios cpu_arch proc entry initialized
[Tue Jan 31 14:11:02 2023] EXT4-fs (md3): recovery complete
[Tue Jan 31 14:11:02 2023] EXT4-fs (md3): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Tue Jan 31 14:11:02 2023] EXT4-fs (md4): recovery complete
[Tue Jan 31 14:11:02 2023] EXT4-fs (md4): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Tue Jan 31 14:11:02 2023] init: dhcp-client (eth0) main process (8364) killed b y TERM signal
[Tue Jan 31 14:11:03 2023] init: system-profile-tuning main process (9066) termi nated with status 255
[Tue Jan 31 14:11:04 2023] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) D river
[Tue Jan 31 14:11:04 2023] Warning! ehci_hcd should always be loaded before uhci _hcd and ohci_hcd, not after
[Tue Jan 31 14:11:04 2023] ehci-pci: EHCI PCI platform driver
[Tue Jan 31 14:11:04 2023] uhci_hcd: USB Universal Host Controller Interface dri ver
[Tue Jan 31 14:11:04 2023] usbcore: registered new interface driver usblp
[Tue Jan 31 14:11:04 2023] usbcore: registered new interface driver usbhid
[Tue Jan 31 14:11:04 2023] usbhid: USB HID core driver
[Tue Jan 31 14:11:06 2023] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Tue Jan 31 14:11:06 2023] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Tue Jan 31 14:11:10 2023] FAT-fs (synoboot2): fat_set_state: set=1 process=syno pkicompatsy pid=10603
[Tue Jan 31 14:11:10 2023] FAT-fs (synoboot2): fat_set_state: set=0 process=syno pkicompatsy pid=10603
[Tue Jan 31 14:11:11 2023] Installing knfsd (copyright (C) 1996 okir@monad.swb.d e).
[Tue Jan 31 14:11:11 2023] iSCSI:target_core_rodsp_server.c:1027:rodsp_server_in it RODSP server started, login_key(086266a3c238).
[Tue Jan 31 14:11:11 2023] iSCSI:extent_pool.c:766:ep_init syno_extent_pool succ essfully initialized
[Tue Jan 31 14:11:11 2023] iSCSI:target_core_device.c:617:se_dev_align_max_secto rs Rounding down aligned max_sectors from 4294967295 to 4294967288
[Tue Jan 31 14:11:11 2023] iSCSI:target_core_lunbackup.c:361:init_io_buffer_head 512 buffers allocated, total 2097152 bytes successfully
[Tue Jan 31 14:11:12 2023] iSCSI:target_core_file.c:146:fd_attach_hba RODSP plug in for fileio is enabled.
[Tue Jan 31 19:49:15 2023] Loaded X.509 cert 'Synology Kernel Module Signing Cer tification Authority: 600839b5d127e0e11d817a31f0575d323a7c0e28'
[Tue Jan 31 19:49:15 2023] Loaded X.509 cert 'Synology kernel module signing key : 4646ce54489669338118a3b1286da156ac366fa5'
[Tue Jan 31 19:49:15 2023] page_owner is disabled
[Tue Jan 31 19:49:15 2023] AppArmor: AppArmor sha1 policy hashing enabled
[Tue Jan 31 19:49:15 2023] hctosys: unable to open rtc device (rtc0)
[Tue Jan 31 19:49:15 2023] Freeing unused kernel memory: 864K (ffffffff81879000 - ffffffff81951000)
[Tue Jan 31 19:49:15 2023] Write protecting the kernel read-only data: 8192k
[Tue Jan 31 19:49:15 2023] Freeing unused kernel memory: 520K (ffff88000157e000 - ffff880001600000)
[Tue Jan 31 19:49:15 2023] Freeing unused kernel memory: 200K (ffff8800017ce000 - ffff880001800000)
[Tue Jan 31 19:49:15 2023] ACPI: bus type USB registered
[Tue Jan 31 19:49:15 2023] usbcore: registered new interface driver usbfs
[Tue Jan 31 19:49:15 2023] usbcore: registered new interface driver hub
[Tue Jan 31 19:49:15 2023] usbcore: registered new interface driver ethub
[Tue Jan 31 19:49:15 2023] usbcore: registered new device driver usb
[Tue Jan 31 19:49:15 2023] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Drive r
[Tue Jan 31 19:49:15 2023] xhci_hcd 0000:00:14.0: xHCI Host Controller
[Tue Jan 31 19:49:15 2023] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 1
[Tue Jan 31 19:49:15 2023] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci vers ion 0x100 quirks 0x00009010
[Tue Jan 31 19:49:15 2023] xhci_hcd 0000:00:14.0: cache line size of 64 is not s upported
[Tue Jan 31 19:49:15 2023] hub 1-0:1.0: USB hub found
[Tue Jan 31 19:49:15 2023] hub 1-0:1.0: 6 ports detected
[Tue Jan 31 19:49:15 2023] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 2
[Tue Jan 31 19:49:15 2023] usb usb2: We don't know the algorithms for LPM for th is host, disabling LPM.
[Tue Jan 31 19:49:15 2023] hub 2-0:1.0: USB hub found
[Tue Jan 31 19:49:15 2023] hub 2-0:1.0: 1 port detected
[Tue Jan 31 19:49:15 2023] usbcore: registered new interface driver usb-storage
[Tue Jan 31 19:49:15 2023] VMware PVSCSI driver - version 1.0.5.0-k
[Tue Jan 31 19:49:15 2023] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:0 1:03 EST 2006)
[Tue Jan 31 19:49:15 2023] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
[Tue Jan 31 19:49:15 2023] Fusion MPT base driver 3.04.20
[Tue Jan 31 19:49:15 2023] Copyright (c) 1999-2008 LSI Corporation
[Tue Jan 31 19:49:16 2023] Fusion MPT SPI Host driver 3.04.20
[Tue Jan 31 19:49:16 2023] Fusion MPT misc device (ioctl) driver 3.04.20
[Tue Jan 31 19:49:16 2023] mptctl: Registered with Fusion MPT base driver
[Tue Jan 31 19:49:16 2023] mptctl: /dev/mptctl @ (major,minor=10,220)
[Tue Jan 31 19:49:16 2023] megasas: 06.808.16.00-rc1
[Tue Jan 31 19:49:16 2023] Fusion MPT SAS Host driver 3.04.20
[Tue Jan 31 19:49:16 2023] mpt3sas version 09.102.00.00 loaded
[Tue Jan 31 19:49:16 2023] usb 1-2: new high-speed USB device number 2 using xhc i_hcd
[Tue Jan 31 19:49:16 2023] rtc_cmos 00:00: RTC can wake from S4
[Tue Jan 31 19:49:16 2023] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0
[Tue Jan 31 19:49:16 2023] rtc_cmos 00:00: alarms up to one month, y3k, 242 byte s nvram
[Tue Jan 31 19:49:16 2023] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014.
[Tue Jan 31 19:49:16 2023] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000.
[Tue Jan 31 19:49:16 2023] Adaptec aacraid driver 1.2-1[41010]-ms
[Tue Jan 31 19:49:16 2023] GDT-HA: Storage RAID Controller Driver. Version: 3.05
[Tue Jan 31 19:49:16 2023] RocketRAID 3xxx/4xxx Controller driver v1.10.0
[Tue Jan 31 19:49:16 2023] isci: Intel(R) C600 SAS Controller Driver - version 1 .2.0
[Tue Jan 31 19:49:16 2023] Got empty serial number. Generate serial number from product.
[Tue Jan 31 19:49:16 2023] synobios: load, major number 201
[Tue Jan 31 19:49:16 2023] Brand: Synology
[Tue Jan 31 19:49:16 2023] Model: DS-918+
[Tue Jan 31 19:49:16 2023] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Tue Jan 31 19:49:16 2023] synobios cpu_arch proc entry initialized
[Tue Jan 31 19:49:16 2023] synobios crypto_hw proc entry initialized
[Tue Jan 31 19:49:16 2023] synobios syno_platform proc entry initialized
[Tue Jan 31 19:49:16 2023] synobios open /dev/ttyS1 success
[Tue Jan 31 19:49:16 2023] synobios: unload
[Tue Jan 31 19:49:16 2023] md: Autodetecting RAID arrays.
[Tue Jan 31 19:49:16 2023] usb 1-2.1: new high-speed USB device number 3 using x hci_hcd
[Tue Jan 31 19:49:16 2023] md: invalid raid superblock magic on sdb3
[Tue Jan 31 19:49:16 2023] md: sdb3 does not have a valid v0.90 superblock, not importing!
[Tue Jan 31 19:49:16 2023] md: invalid raid superblock magic on sdc3
[Tue Jan 31 19:49:16 2023] md: sdc3 does not have a valid v0.90 superblock, not importing!
[Tue Jan 31 19:49:16 2023] md: Scanned 6 and added 4 devices.
[Tue Jan 31 19:49:16 2023] md: autorun ...
[Tue Jan 31 19:49:16 2023] md: considering sdb1 ...
[Tue Jan 31 19:49:16 2023] md: adding sdb1 ...
[Tue Jan 31 19:49:16 2023] md: sdb2 has different UUID to sdb1
[Tue Jan 31 19:49:16 2023] md: adding sdc1 ...
[Tue Jan 31 19:49:16 2023] md: sdc2 has different UUID to sdb1
[Tue Jan 31 19:49:16 2023] md: created md0
[Tue Jan 31 19:49:16 2023] md: bind<sdc1>
[Tue Jan 31 19:49:16 2023] md: bind<sdb1>
[Tue Jan 31 19:49:16 2023] md: running: <sdb1><sdc1>
[Tue Jan 31 19:49:16 2023] md/raid1:md0: active with 2 out of 16 mirrors
[Tue Jan 31 19:49:16 2023] usb 1-2.1: ep 0x81 - rounding interval to 128 microfr ames, ep desc says 255 microframes
[Tue Jan 31 19:49:16 2023] usb 1-2.1: ep 0x2 - rounding interval to 128 microfra mes, ep desc says 255 microframes
[Tue Jan 31 19:49:16 2023] usb-storage 1-2.1:1.0: USB Mass Storage device detect ed
[Tue Jan 31 19:49:16 2023] scsi host4: usb-storage 1-2.1:1.0
[Tue Jan 31 19:49:16 2023] md0: detected capacity change from 0 to 2549940224
[Tue Jan 31 19:49:16 2023] md: considering sdb2 ...
[Tue Jan 31 19:49:16 2023] md: adding sdb2 ...
[Tue Jan 31 19:49:16 2023] md: adding sdc2 ...
[Tue Jan 31 19:49:16 2023] md: created md1
[Tue Jan 31 19:49:16 2023] md: bind<sdc2>
[Tue Jan 31 19:49:16 2023] md: bind<sdb2>
[Tue Jan 31 19:49:16 2023] md: running: <sdb2><sdc2>
[Tue Jan 31 19:49:16 2023] md/raid1:md1: active with 2 out of 16 mirrors
[Tue Jan 31 19:49:16 2023] md1: detected capacity change from 0 to 2147418112
[Tue Jan 31 19:49:33 2023] QLogic/NetXen Network Driver v4.0.82
[Tue Jan 31 19:49:33 2023] Solarflare NET driver v4.0
[Tue Jan 31 19:49:33 2023] e1000: Intel(R) PRO/1000 Network Driver - version 7.3 .21-k8-NAPI
[Tue Jan 31 19:49:33 2023] e1000: Copyright (c) 1999-2006 Intel Corporation.
[Tue Jan 31 19:49:33 2023] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.f ranken.de
[Tue Jan 31 19:49:33 2023] VMware vmxnet3 virtual NIC driver - version 1.4.5.0-k -NAPI
[Tue Jan 31 19:49:33 2023] igbvf: Intel(R) Gigabit Virtual Function Driver - 2.3 .8.2
[Tue Jan 31 19:49:33 2023] igbvf: Copyright (c) 1999-2015 Intel Corporation.
[Tue Jan 31 19:49:33 2023] ixgbevf: Intel(R) 10GbE PCI Express Virtual Function Driver - version 4.11.1
[Tue Jan 31 19:49:33 2023] ixgbevf: Copyright(c) 1999 - 2021 Intel Corporation.
[Tue Jan 31 19:49:33 2023] usbcore: registered new interface driver ax88179_178a
[Tue Jan 31 19:49:33 2023] usbcore: registered new interface driver asix
[Tue Jan 31 19:49:33 2023] Atheros(R) L2 Ethernet Driver - version 2.2.3
[Tue Jan 31 19:49:33 2023] Copyright (c) 2007 Atheros Corporation.
[Tue Jan 31 19:49:33 2023] bna: QLogic BR-series 10G Ethernet driver - version: 3.2.25.1
[Tue Jan 31 19:49:33 2023] usbcore: registered new interface driver cx82310_eth
[Tue Jan 31 19:49:33 2023] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[Tue Jan 31 19:49:33 2023] e100: Copyright(c) 1999-2006 Intel Corporation
[Tue Jan 31 19:49:33 2023] enic: Cisco VIC Ethernet NIC Driver, ver 2.3.0.20
[Tue Jan 31 19:49:33 2023] usbcore: registered new interface driver MOSCHIP usb- ethernet driver
[Tue Jan 31 19:49:33 2023] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[Tue Jan 31 19:49:33 2023] usbcore: registered new interface driver pegasus
[Tue Jan 31 19:49:33 2023] usbcore: registered new interface driver plusb
[Tue Jan 31 19:49:33 2023] usbcore: registered new interface driver rtl8150
[Tue Jan 31 19:49:33 2023] via_rhine: v1.10-LK1.5.1 2010-10-09 Written by Donald Becker
[Tue Jan 31 19:49:34 2023] usbcore: registered new interface driver r8152
[Tue Jan 31 19:49:34 2023] vxge: Copyright(c) 2002-2010 Exar Corp.
[Tue Jan 31 19:49:34 2023] vxge: Driver version: 2.5.3.22640-k
[Tue Jan 31 19:49:34 2023] usbcore: registered new interface driver aqc111
[Tue Jan 31 19:49:34 2023] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Tue Jan 31 19:49:34 2023] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Tue Jan 31 19:49:34 2023] 9pnet: Installing 9P2000 support
[Tue Jan 31 19:49:34 2023] 9p: Installing v9fs 9p2000 file system support
[Tue Jan 31 19:49:34 2023] 2023-1-31 17:49:35 UTC
[Tue Jan 31 19:49:34 2023] synobios: load, major number 201
[Tue Jan 31 19:49:34 2023] Brand: Synology
[Tue Jan 31 19:49:34 2023] Model: DS-918+
[Tue Jan 31 19:49:34 2023] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Tue Jan 31 19:49:34 2023] synobios cpu_arch proc entry initialized
[Tue Jan 31 19:49:38 2023] EXT4-fs (md3): recovery complete
[Tue Jan 31 19:49:38 2023] EXT4-fs (md3): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Tue Jan 31 19:49:39 2023] init: dhcp-client (eth0) main process (8316) killed b y TERM signal
[Tue Jan 31 19:49:39 2023] EXT4-fs (md4): 1 orphan inode deleted
[Tue Jan 31 19:49:39 2023] EXT4-fs (md4): recovery complete
[Tue Jan 31 19:49:39 2023] EXT4-fs (md4): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Tue Jan 31 19:49:42 2023] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) D river
[Tue Jan 31 19:49:42 2023] Warning! ehci_hcd should always be loaded before uhci _hcd and ohci_hcd, not after
[Tue Jan 31 19:49:42 2023] ehci-pci: EHCI PCI platform driver
[Tue Jan 31 19:49:42 2023] uhci_hcd: USB Universal Host Controller Interface dri ver
[Tue Jan 31 19:49:42 2023] usbcore: registered new interface driver usblp
[Tue Jan 31 19:49:42 2023] usbcore: registered new interface driver usbhid
[Tue Jan 31 19:49:42 2023] usbhid: USB HID core driver
[Tue Jan 31 19:49:43 2023] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Tue Jan 31 19:49:43 2023] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Tue Jan 31 19:49:47 2023] FAT-fs (synoboot2): fat_set_state: set=1 process=syno pkicompatsy pid=10560
[Tue Jan 31 19:49:47 2023] FAT-fs (synoboot2): fat_set_state: set=0 process=syno pkicompatsy pid=10560
[Tue Jan 31 19:49:49 2023] ata2.00: configured for UDMA/133
[Tue Jan 31 19:49:49 2023] ata2: EH complete
[Tue Jan 31 19:49:49 2023] Installing knfsd (copyright (C) 1996 okir@monad.swb.d e).
[Tue Jan 31 19:49:49 2023] ata3.00: configured for UDMA/133
[Tue Jan 31 19:49:49 2023] ata3: EH complete
[Tue Jan 31 19:49:49 2023] iSCSI:target_core_rodsp_server.c:1027:rodsp_server_in it RODSP server started, login_key(086266a3c238).
[Fri Feb 3 19:10:18 2023] Loaded X.509 cert 'Synology Kernel Module Signing Cer tification Authority: 600839b5d127e0e11d817a31f0575d323a7c0e28'
[Fri Feb 3 19:10:18 2023] Loaded X.509 cert 'Synology kernel module signing key : 4646ce54489669338118a3b1286da156ac366fa5'
[Fri Feb 3 19:10:18 2023] page_owner is disabled
[Fri Feb 3 19:10:18 2023] AppArmor: AppArmor sha1 policy hashing enabled
[Fri Feb 3 19:10:18 2023] hctosys: unable to open rtc device (rtc0)
[Fri Feb 3 19:10:18 2023] Freeing unused kernel memory: 864K (ffffffff81879000 - ffffffff81951000)
[Fri Feb 3 19:10:18 2023] Write protecting the kernel read-only data: 8192k
[Fri Feb 3 19:10:18 2023] Freeing unused kernel memory: 520K (ffff88000157e000 - ffff880001600000)
[Fri Feb 3 19:10:18 2023] Freeing unused kernel memory: 200K (ffff8800017ce000 - ffff880001800000)
[Fri Feb 3 19:10:18 2023] ACPI: bus type USB registered
[Fri Feb 3 19:10:18 2023] usbcore: registered new interface driver usbfs
[Fri Feb 3 19:10:18 2023] usbcore: registered new interface driver hub
[Fri Feb 3 19:10:18 2023] usbcore: registered new interface driver ethub
[Fri Feb 3 19:10:18 2023] usbcore: registered new device driver usb
[Fri Feb 3 19:10:18 2023] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Drive r
[Fri Feb 3 19:10:18 2023] xhci_hcd 0000:00:14.0: xHCI Host Controller
[Fri Feb 3 19:10:18 2023] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 1
[Fri Feb 3 19:10:18 2023] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci vers ion 0x100 quirks 0x00009010
[Fri Feb 3 19:10:18 2023] xhci_hcd 0000:00:14.0: cache line size of 64 is not s upported
[Fri Feb 3 19:10:18 2023] hub 1-0:1.0: USB hub found
[Fri Feb 3 19:10:18 2023] hub 1-0:1.0: 6 ports detected
[Fri Feb 3 19:10:18 2023] xhci_hcd 0000:00:14.0: new USB bus registered, assign ed bus number 2
[Fri Feb 3 19:10:18 2023] usb usb2: We don't know the algorithms for LPM for th is host, disabling LPM.
[Fri Feb 3 19:10:18 2023] hub 2-0:1.0: USB hub found
[Fri Feb 3 19:10:18 2023] hub 2-0:1.0: 1 port detected
[Fri Feb 3 19:10:18 2023] usbcore: registered new interface driver usb-storage
[Fri Feb 3 19:10:18 2023] VMware PVSCSI driver - version 1.0.5.0-k
[Fri Feb 3 19:10:18 2023] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:0 1:03 EST 2006)
[Fri Feb 3 19:10:18 2023] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
[Fri Feb 3 19:10:18 2023] Fusion MPT base driver 3.04.20
[Fri Feb 3 19:10:18 2023] Copyright (c) 1999-2008 LSI Corporation
[Fri Feb 3 19:10:18 2023] Fusion MPT SPI Host driver 3.04.20
[Fri Feb 3 19:10:18 2023] Fusion MPT misc device (ioctl) driver 3.04.20
[Fri Feb 3 19:10:18 2023] mptctl: Registered with Fusion MPT base driver
[Fri Feb 3 19:10:18 2023] mptctl: /dev/mptctl @ (major,minor=10,220)
[Fri Feb 3 19:10:18 2023] megasas: 06.808.16.00-rc1
[Fri Feb 3 19:10:18 2023] Fusion MPT SAS Host driver 3.04.20
[Fri Feb 3 19:10:18 2023] mpt3sas version 09.102.00.00 loaded
[Fri Feb 3 19:10:18 2023] usb 1-2: new high-speed USB device number 2 using xhc i_hcd
[Fri Feb 3 19:10:18 2023] rtc_cmos 00:00: RTC can wake from S4
[Fri Feb 3 19:10:18 2023] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0
[Fri Feb 3 19:10:18 2023] rtc_cmos 00:00: alarms up to one month, y3k, 242 byte s nvram
[Fri Feb 3 19:10:18 2023] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014.
[Fri Feb 3 19:10:19 2023] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000.
[Fri Feb 3 19:10:19 2023] Adaptec aacraid driver 1.2-1[41010]-ms
[Fri Feb 3 19:10:19 2023] GDT-HA: Storage RAID Controller Driver. Version: 3.05
[Fri Feb 3 19:10:19 2023] RocketRAID 3xxx/4xxx Controller driver v1.10.0
[Fri Feb 3 19:10:19 2023] isci: Intel(R) C600 SAS Controller Driver - version 1 .2.0
[Fri Feb 3 19:10:19 2023] Got empty serial number. Generate serial number from product.
[Fri Feb 3 19:10:19 2023] synobios: load, major number 201
[Fri Feb 3 19:10:19 2023] Brand: Synology
[Fri Feb 3 19:10:19 2023] Model: DS-918+
[Fri Feb 3 19:10:19 2023] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Fri Feb 3 19:10:19 2023] synobios cpu_arch proc entry initialized
[Fri Feb 3 19:10:19 2023] synobios crypto_hw proc entry initialized
[Fri Feb 3 19:10:19 2023] synobios syno_platform proc entry initialized
[Fri Feb 3 19:10:19 2023] synobios open /dev/ttyS1 success
[Fri Feb 3 19:10:19 2023] synobios: unload
[Fri Feb 3 19:10:19 2023] md: Autodetecting RAID arrays.
[Fri Feb 3 19:10:19 2023] usb 1-2.1: new high-speed USB device number 3 using x hci_hcd
[Fri Feb 3 19:10:19 2023] md: invalid raid superblock magic on sdb3
[Fri Feb 3 19:10:19 2023] md: sdb3 does not have a valid v0.90 superblock, not importing!
[Fri Feb 3 19:10:19 2023] md: invalid raid superblock magic on sdc3
[Fri Feb 3 19:10:19 2023] md: sdc3 does not have a valid v0.90 superblock, not importing!
[Fri Feb 3 19:10:19 2023] md: Scanned 6 and added 4 devices.
[Fri Feb 3 19:10:19 2023] md: autorun ...
[Fri Feb 3 19:10:19 2023] md: considering sdb1 ...
[Fri Feb 3 19:10:19 2023] md: adding sdb1 ...
[Fri Feb 3 19:10:19 2023] md: sdb2 has different UUID to sdb1
[Fri Feb 3 19:10:19 2023] md: adding sdc1 ...
[Fri Feb 3 19:10:19 2023] md: sdc2 has different UUID to sdb1
[Fri Feb 3 19:10:19 2023] md: created md0
[Fri Feb 3 19:10:19 2023] md: bind<sdc1>
[Fri Feb 3 19:10:19 2023] md: bind<sdb1>
[Fri Feb 3 19:10:19 2023] md: running: <sdb1><sdc1>
[Fri Feb 3 19:10:19 2023] md/raid1:md0: active with 2 out of 16 mirrors
[Fri Feb 3 19:10:19 2023] usb 1-2.1: ep 0x81 - rounding interval to 128 microfr ames, ep desc says 255 microframes
[Fri Feb 3 19:10:19 2023] usb 1-2.1: ep 0x2 - rounding interval to 128 microfra mes, ep desc says 255 microframes
[Fri Feb 3 19:10:19 2023] usb-storage 1-2.1:1.0: USB Mass Storage device detect ed
[Fri Feb 3 19:10:19 2023] scsi host4: usb-storage 1-2.1:1.0
[Fri Feb 3 19:10:19 2023] md0: detected capacity change from 0 to 2549940224
[Fri Feb 3 19:10:19 2023] md: considering sdb2 ...
[Fri Feb 3 19:10:19 2023] md: adding sdb2 ...
[Fri Feb 3 19:10:19 2023] md: adding sdc2 ...
[Fri Feb 3 19:10:19 2023] md: created md1
[Fri Feb 3 19:10:19 2023] md: bind<sdc2>
[Fri Feb 3 19:10:19 2023] md: bind<sdb2>
[Fri Feb 3 19:10:19 2023] md: running: <sdb2><sdc2>
[Fri Feb 3 19:10:19 2023] md/raid1:md1: active with 2 out of 16 mirrors
[Fri Feb 3 19:10:19 2023] md1: detected capacity change from 0 to 2147418112
[Fri Feb 3 19:10:36 2023] QLogic/NetXen Network Driver v4.0.82
[Fri Feb 3 19:10:36 2023] Solarflare NET driver v4.0
[Fri Feb 3 19:10:36 2023] e1000: Intel(R) PRO/1000 Network Driver - version 7.3 .21-k8-NAPI
[Fri Feb 3 19:10:36 2023] e1000: Copyright (c) 1999-2006 Intel Corporation.
[Fri Feb 3 19:10:36 2023] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.f ranken.de
[Fri Feb 3 19:10:36 2023] VMware vmxnet3 virtual NIC driver - version 1.4.5.0-k -NAPI
[Fri Feb 3 19:10:36 2023] igbvf: Intel(R) Gigabit Virtual Function Driver - 2.3 .8.2
[Fri Feb 3 19:10:36 2023] igbvf: Copyright (c) 1999-2015 Intel Corporation.
[Fri Feb 3 19:10:36 2023] ixgbevf: Intel(R) 10GbE PCI Express Virtual Function Driver - version 4.11.1
[Fri Feb 3 19:10:36 2023] ixgbevf: Copyright(c) 1999 - 2021 Intel Corporation.
[Fri Feb 3 19:10:36 2023] usbcore: registered new interface driver ax88179_178a
[Fri Feb 3 19:10:36 2023] usbcore: registered new interface driver asix
[Fri Feb 3 19:10:36 2023] Atheros(R) L2 Ethernet Driver - version 2.2.3
[Fri Feb 3 19:10:36 2023] Copyright (c) 2007 Atheros Corporation.
[Fri Feb 3 19:10:36 2023] bna: QLogic BR-series 10G Ethernet driver - version: 3.2.25.1
[Fri Feb 3 19:10:36 2023] usbcore: registered new interface driver cx82310_eth
[Fri Feb 3 19:10:36 2023] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[Fri Feb 3 19:10:36 2023] e100: Copyright(c) 1999-2006 Intel Corporation
[Fri Feb 3 19:10:36 2023] enic: Cisco VIC Ethernet NIC Driver, ver 2.3.0.20
[Fri Feb 3 19:10:36 2023] usbcore: registered new interface driver MOSCHIP usb- ethernet driver
[Fri Feb 3 19:10:36 2023] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[Fri Feb 3 19:10:36 2023] usbcore: registered new interface driver pegasus
[Fri Feb 3 19:10:36 2023] usbcore: registered new interface driver plusb
[Fri Feb 3 19:10:36 2023] usbcore: registered new interface driver rtl8150
[Fri Feb 3 19:10:36 2023] via_rhine: v1.10-LK1.5.1 2010-10-09 Written by Donald Becker
[Fri Feb 3 19:10:36 2023] usbcore: registered new interface driver r8152
[Fri Feb 3 19:10:36 2023] vxge: Copyright(c) 2002-2010 Exar Corp.
[Fri Feb 3 19:10:36 2023] vxge: Driver version: 2.5.3.22640-k
[Fri Feb 3 19:10:36 2023] usbcore: registered new interface driver aqc111
[Fri Feb 3 19:10:36 2023] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Fri Feb 3 19:10:36 2023] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Fri Feb 3 19:10:37 2023] 9pnet: Installing 9P2000 support
[Fri Feb 3 19:10:37 2023] 9p: Installing v9fs 9p2000 file system support
[Fri Feb 3 19:10:37 2023] 2023-2-3 17:10:38 UTC
[Fri Feb 3 19:10:37 2023] synobios: load, major number 201
[Fri Feb 3 19:10:37 2023] Brand: Synology
[Fri Feb 3 19:10:37 2023] Model: DS-918+
[Fri Feb 3 19:10:37 2023] This is default settings: set group disks wakeup numb er to 1, spinup time deno 1
[Fri Feb 3 19:10:37 2023] synobios cpu_arch proc entry initialized
[Fri Feb 3 19:10:42 2023] init: dhcp-client (eth0) main process (8384) killed b y TERM signal
[Fri Feb 3 19:10:42 2023] EXT4-fs (md4): 4 orphan inodes deleted
[Fri Feb 3 19:10:42 2023] EXT4-fs (md4): recovery complete
[Fri Feb 3 19:10:42 2023] EXT4-fs (md4): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Fri Feb 3 19:10:43 2023] EXT4-fs (md3): recovery complete
[Fri Feb 3 19:10:43 2023] EXT4-fs (md3): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,da ta=writeback
[Fri Feb 3 19:10:45 2023] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) D river
[Fri Feb 3 19:10:45 2023] Warning! ehci_hcd should always be loaded before uhci _hcd and ohci_hcd, not after
[Fri Feb 3 19:10:45 2023] ehci-pci: EHCI PCI platform driver
[Fri Feb 3 19:10:45 2023] uhci_hcd: USB Universal Host Controller Interface dri ver
[Fri Feb 3 19:10:45 2023] usbcore: registered new interface driver usblp
[Fri Feb 3 19:10:45 2023] usbcore: registered new interface driver usbhid
[Fri Feb 3 19:10:45 2023] usbhid: USB HID core driver
[Fri Feb 3 19:10:46 2023] virtio_balloon: Unknown symbol balloon_page_dequeue ( err 0)
[Fri Feb 3 19:10:46 2023] virtio_balloon: Unknown symbol balloon_page_enqueue ( err 0)
[Fri Feb 3 19:10:50 2023] FAT-fs (synoboot2): fat_set_state: set=1 process=syno pkicompatsy pid=10659
[Fri Feb 3 19:10:50 2023] FAT-fs (synoboot2): fat_set_state: set=0 process=syno pkicompatsy pid=10659
[Fri Feb 3 19:10:50 2023] Installing knfsd (copyright (C) 1996 okir@monad.swb.d e).
[Fri Feb 3 19:10:51 2023] iSCSI:target_core_rodsp_server.c:1027:rodsp_server_in it RODSP server started, login_key(086266a3c238).
[Fri Feb 3 19:10:51 2023] iSCSI:extent_pool.c:766:ep_init syno_extent_pool succ essfully initialized
[Fri Feb 3 19:10:51 2023] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 stat e recovery directory
[Fri Feb 3 19:10:51 2023] iSCSI:target_core_device.c:617:se_dev_align_max_secto rs Rounding down aligned max_sectors from 4294967295 to 4294967288
[Fri Feb 3 19:10:51 2023] iSCSI:target_core_lunbackup.c:361:init_io_buffer_head 512 buffers allocated, total 2097152 bytes successfully
I would be grateful if anyone can help me.
Edited by bojidar13Link to comment
1 answer to this question
