colorist Posted January 11, 2023 Share #1 Posted January 11, 2023 Hello. Need help. Successfully upgraded from DSM 6.2.3 DS3615xs to DSM 7.1 DS3622xs+ with TCRP loader. System - Athlon II x2, MB Asus M4A785G, 6GB RAM, 3x4TB WD Red, RAID5. Everything works correctly. Excluding APC bx650ci-rs UPS. The system does not see it. On DSM 6.2.3 everything worked correctly. Tried migrating to DSM 7.1 DS3615 with TCRP loader, also the UPS is not visible in the system. Replaced USB cable - no luck. As far as I understand, you need to include extensions in the loader? Question what? Thanks in advance for the tips. Quote Link to comment Share on other sites More sharing options...
wessu Posted March 31, 2023 Share #2 Posted March 31, 2023 This is what I have with DSM918+. I checked and the UPS was not found but I had VirtualHere package installed and I don't know if it caused an issue or not but I uninstalled it and rebooted and I can see my UPS again. Quote Link to comment Share on other sites More sharing options...
Lestat Posted July 31, 2023 Share #3 Posted July 31, 2023 did you ever solve this problem as i am getting the same thing Quote Link to comment Share on other sites More sharing options...
colorist Posted August 6, 2023 Author Share #4 Posted August 6, 2023 The issue was resolved by replacing the AMD platform with an Intel Xeon E3-1265L v3. Now everything works correctly. Quote Link to comment Share on other sites More sharing options...
