I hope this appropriate place to post this.
I bought this pcie sata 10 port card, and https://a.co/d/avmkXxp and in description way down it says it "supports" port multipliers. not sure if that mean THIS item is port multiplier or not.
my point is that I have been struggling with my 7.1 install and want to know
A: If this card should present a problem
B: If this card is not good, can you recommend an alternative in same price range?
Are LSI cards supported by this redpill installation method? could you recommend one?
Edited by Captainfingerbang
