adam535 Posted October 9, 2022 #1 Posted October 9, 2022 hello iam trying to use ssd instead of usb to my baremetal , but i faced problem that when it download the dsm it stops at 56% , i think its vid and pid problem , so can any one help me to find my ssd vid and pid? best regards Quote
AuxXxilium Posted October 10, 2022 #2 Posted October 10, 2022 baremetal on ssd don‘t need pid/vid. which builder do you use? arpl or tcrp? which steps do you do? which hardware do you use? Quote
adam535 Posted October 10, 2022 Author #3 Posted October 10, 2022 8 hours ago, AuxXxilium said: baremetal on ssd don‘t need pid/vid. which builder do you use? arpl or tcrp? which steps do you do? which hardware do you use? # # ### !!! WARNING - READ ME !!! ### # # DO NOT edit this file. This file has been generated automatically by the loader generator. # If you were asked to use a pre-made image and asked by someone to edit this file DO NOT do it. The only # supported method of obtaining the loader image is generating it using the loader generator provided. # terminal_output console if serial --unit=0 --speed=115200; then terminal_input --append serial_com0 terminal_output --append serial_com0 fi set default="0" set timeout="5" set timeout_style="menu" if [ -s $prefix/grubenv ]; then load_env --file $prefix/grubenv --skip-sig set has_env="1" if [ -n "${saved_entry}" ]; then set default="${saved_entry}" fi else set has_env="0" echo "WARN: failed to load env. Default choice will NOT be saved!" fi function savedefault { saved_entry="${chosen}" save_env --file $prefix/grubenv saved_entry } insmod usb_keyboard insmod part_msdos insmod ext2 insmod fat insmod linux insmod gzio set gfxmode=auto insmod vbe insmod vga # UEFI insmod efi_gop insmod efi_uga insmod font if loadfont ${prefix}/unicode.pf2 then insmod gfxterm set gfxmode=auto set gfxpayload=keep terminal_output gfxterm fi menuentry 'RedPill DS3622xs v7.1.0-42661 Beta (USB, Verbose)' { savedefault set root=(hd0,msdos1) echo Loading Linux... linux /zImage withefi earlyprintk syno_hw_version=DS3622xs+ console=ttyS0,115200n8 netif_num=5 pid=0x5567 earlycon=uart8250,io,0x3f8,115200n8 syno_port_thaw=1 mac2=001122334455 mac3=001122334455 mac1=e839354e8979 mac4=001122334455 mac5=001122334455 sn=2150SQRABC123 vid=0x0781 elevator=elevator loglevel=15 HddHotplug=1 DiskIdxMap=00 syno_hdd_detect=0 vender_format_version=2 syno_hdd_powerup_seq=0 log_buf_len=32M root=/dev/md0 SataPortMap=1 echo Loading initramfs... initrd /rd.gz /custom.gz echo Starting kernel with USB boot } menuentry 'RedPill DS3622xs v7.1.0-42661 Beta (SATA, Verbose)' { savedefault set root=(hd0,msdos1) echo Loading Linux... linux /zImage withefi earlyprintk syno_hw_version=DS3622xs+ console=ttyS0,115200n8 netif_num=5 pid=0x5567 earlycon=uart8250,io,0x3f8,115200n8 synoboot_satadom=1 syno_port_thaw=1 mac2=001122334455 mac3=001122334455 mac1=e839354e8979 mac4=001122334455 mac5=001122334455 sn=2150SQRABC123 vid=0x0781 elevator=elevator loglevel=15 HddHotplug=1 DiskIdxMap=00 syno_hdd_detect=0 vender_format_version=2 syno_hdd_powerup_seq=0 log_buf_len=32M root=/dev/md0 SataPortMap=1 echo Loading initramfs... initrd /rd.gz /custom.gz echo Starting kernel with SATA boot } i used this grup to install on usb and it worked fine for my baremetal , after a few months i wanted to try it on ssd , because WOL does not seem boot from usb , after i burned this grup to ssd it boot to bootloader but when i try to download the DSM , it stops at 56% any help please to get it on ssd Quote
pocopico Posted October 10, 2022 #4 Posted October 10, 2022 You need to select SATA boot and add the dom_szmax={THESIZEOFYOURSSDINMB} on you linux line Quote
adam535 Posted October 10, 2022 Author #5 Posted October 10, 2022 6 minutes ago, pocopico said: You need to select SATA boot and add the dom_szmax={THESIZEOFYOURSSDINMB} on you linux line Thank you for quick reply Iam new to linux line Could you please edit the line above and post it here , and the vid and pid should it removed or what ? Thank you ⚘️ Quote
adam535 Posted October 10, 2022 Author #6 Posted October 10, 2022 9 minutes ago, pocopico said: You need to select SATA boot and add the dom_szmax={THESIZEOFYOURSSDINMB} on you linux line I use adata su650 120g Quote
AuxXxilium Posted October 10, 2022 #7 Posted October 10, 2022 1 minute ago, adam535 said: Thank you for quick reply Iam new to linux line Could you please edit the line above and post it here , and the vid and pid should it removed or what ? Thank you ⚘️ VId/PID are not in boot line with SATA Boot Quote
adam535 Posted October 10, 2022 Author #8 Posted October 10, 2022 5 minutes ago, AuxXxilium said: VId/PID are not in boot line with SATA Boot Could you please tell me how to add add the dom_szmax={THESIZEOFYOURSSDINMB} on you linux line i use adata su650 120g could you please edit the grup above and post it here ? Thank you Quote
pocopico Posted October 10, 2022 #9 Posted October 10, 2022 (edited) menuentry 'RedPill DS3622xs v7.1.0-42661 Beta (SATA, Verbose)' { savedefault set root=(hd0,msdos1) echo Loading Linux... linux /zImage withefi earlyprintk syno_hw_version=DS3622xs+ console=ttyS0,115200n8 netif_num=5 pid=0x5567 earlycon=uart8250,io,0x3f8,115200n8 synoboot_satadom=1 syno_port_thaw=1 mac2=001122334455 mac3=001122334455 mac1=e839354e8979 mac4=001122334455 mac5=001122334455 sn=2150SQRABC123 vid=0x0781 elevator=elevator loglevel=15 HddHotplug=1 DiskIdxMap=00 syno_hdd_detect=0 vender_format_version=2 syno_hdd_powerup_seq=0 log_buf_len=32M root=/dev/md0 SataPortMap=1 domsz_max=122880 echo Loading initramfs... initrd /rd.gz /custom.gz echo Starting kernel with SATA boot } Edited October 10, 2022 by pocopico Quote
adam535 Posted October 10, 2022 Author #10 Posted October 10, 2022 2 minutes ago, pocopico said: linux /zImage withefi earlyprintk syno_hw_version=DS3622xs+ console=ttyS0,115200n8 netif_num=5 pid=0x5567 earlycon=uart8250,io,0x3f8,115200n8 synoboot_satadom=1 syno_port_thaw=1 mac2=001122334455 mac3=001122334455 mac1=e839354e8979 mac4=001122334455 mac5=001122334455 sn=2150SQRABC123 vid=0x0781 elevator=elevator loglevel=15 HddHotplug=1 DiskIdxMap=00 syno_hdd_detect=0 vender_format_version=2 syno_hdd_powerup_seq=0 log_buf_len=32M root=/dev/md0 SataPortMap=1 domsz_max=122880 Thank you Should i remove vid and pid , or just use it like you post it? Quote
pocopico Posted October 10, 2022 #11 Posted October 10, 2022 1 minute ago, adam535 said: Thank you Should i remove vid and pid , or just use it like you post it? VID and PID is not used when you select SATA boot. Its will try to match a SATA disk instead to be used as synoboot device. So NO USB should be connected and the above should be set on GRUB Quote
adam535 Posted October 10, 2022 Author #12 Posted October 10, 2022 19 minutes ago, adam535 said: 17 minutes ago, pocopico said: VID and PID is not used when you select SATA boot. Its will try to match a SATA disk instead to be used as synoboot device. So NO USB should be connected and the above should be set on GRUB i used the line you wrote and i faced this issue Quote
pocopico Posted October 10, 2022 #13 Posted October 10, 2022 (edited) I suggest you use TCRP withfriend or ARPL. Both should make it easier for you. Another thing to ask is why you are wasting an entire SSD just for the loader ? It will not make things easier or faster or more reliable. Edited October 10, 2022 by pocopico Quote
adam535 Posted October 10, 2022 Author #14 Posted October 10, 2022 54 minutes ago, pocopico said: I suggest you use TCRP withfriend or ARPL. Both should make it easier for you. Another thing to ask is why you are wasting an entire SSD just for the loader ? It will not make things easier or faster or more reliable. I use ssd , because when i try to wake on lan , the baremetal turn on , but it does not boot from the usb 1 Quote
Godzilla Posted April 18, 2023 #15 Posted April 18, 2023 Greetings, I understand that you are trying to install DSM 7. Assuming that you already know how to get the VID number and the PID of your SSD, from putty when you have to register the identification (PID-VID) of the SSD, instead of using the identification write "vi user_config.json" without the quotes of course, once in the editor press the "INSERT" key and then with the arrow keys of your keyboard go to the PID and the VID and change the four numbers that are after 0x, to save and exit press the "Esc" key, then ":" (two points), then W and then Q and that's it you can continue with the following commands, good luck. Quote
