trying to install 7.0.1 42218 and it spit this error on the end (sudo: ./build-loader.sh: command not found), trying to install 918+ in a AMD Ryzen 4600H
bspatch does not exist, bringing over from repo
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 10232 100 10232 0 0 9527 0 0:00:01 0:00:01 --:--:-- 9535
Rploader Version : 0.8.0.5
Loader source : https://github.com/pocopico/redpill-load.git Loader Branch : develop
Redpill module source : https://github.com/pocopico/redpill-lkm.git : Redpill module branch : master
Extensions :
Extensions URL :
TOOLKIT_URL : https://sourceforge.net/projects/dsgpl/files/toolkit/DSM7.0/ds.apollolake-7.0.dev.txz/download
TOOLKIT_SHA : d349fa644392d4cfab8191243ee38aaa32bd517208c144678e0c855cb5a619ea
SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology NAS GPL Source/25426branch/apollolake-source/linux-4.4.x.txz/download
SYNOKERNEL_SHA : af815ee065775d2e569fd7176e25c8ba7ee17a03361557975c8e5a4b64230c5b
COMPILE_METHOD : toolkit_dev
TARGET_PLATFORM : apollolake
TARGET_VERSION : 7.0.1
TARGET_REVISION : 42218
REDPILL_LKM_MAKE_TARGET : test-v7
KERNEL_MAJOR : 4
MODULE_ALIAS_FILE : modules.alias.4.json
SYNOMODEL : ds918p_42218
MODEL : DS918+
Local Cache Folder : /mnt/sda3/auxfiles
DATE Internet : 17092022 Local : 17092022
Checking Internet Access -> OK
Checking if a newer version exists on the main repo -> Version is current
Redpill sources already downloaded, pulling latest
Already up to date.
Loader sources already downloaded, pulling latest
fatal: not a git repository (or any of the parent directories): .git
Using static compiled redpill extension
Removing any old redpill.ko modules
Looking for redpill for : ds918p_42218
Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/releases/redpill-4.4.180plus.tgz
Extracting module
Got redpill-linux-v4.4.180+.ko
Manual extension handling,skipping extension auto detection
Starting loader creation
Found tinycore cache folder, linking to home/tc/custom-module
Checking user_config.json : Done
Entering redpill-load directory
Removing bundled exts directories
Cache directory OK
Want to use firmware files from /home/tc/custom-module/*.pat ? [yY/nN] :
y
Processing add_extensions entries found on custom_config.json file :
FAILED : Loader creation failed check the output for any errors
Cruzstein
Extensions :
Extensions URL :
KERNEL_MAJOR : 4
MODEL : DS918+
Already up to date.
Extracting module
Cache directory OK
y
1 answer to this question
