Hi!
I moved my ESXi installation to another PC. ESXi itself works fine. I also can boot into TC. Trying to boot into DSM gives me the following messages on serial:
[H[J[1;1Herror: file `/boot/grub/i386-pc/efi_gop.mod' not found.
error: file `/boot/grub/i386-pc/efi_uga.mod' not found.
error: file `/boot/grub/unicode.pf2' not found.
[?25l[m[H[J[1;1H[2;30HGNU GRUB  version 2.06
[m[4;2H+----------------------------------------------------------------------------+[5;2H|[5;79H|[6;2H|[6;79H|[7;2H|[7;79H|[8;2H|[8;79H|[9;2H|[9;79H|[10;2H|[10;79H|[11;2H|[11;79H|[12;2H|[12;79H|[13;2H|[13;79H|[14;2H|[14;79H|[15;2H|[15;79H|[16;2H|[16;79H|[17;2H+----------------------------------------------------------------------------+[m[18;2H[19;2H[m     Use the ^ and v keys to select which entry is highlighted.
      Press enter to boot the selected OS, `e' to edit the commands
      before booting or `c' for a command-line.                           [5;80H [m[5;3H RedPill DVA3221 v7.1.0-42661 Beta (USB, Verbose)                           [m[5;78H[m[7m[6;3H*RedPill DVA3221 v7.1.0-42661 Beta (SATA, Verbose)                          [m[6;78H[m[m[7;3H Tiny Core Image Build                                                      [m[7;78H[m[m[8;3H        [m[8;78H[m[m[9;3H        [m[9;78H[m[m[10;3H        [m[10;78H[m[m[11;3H        [m[11;78H[m[m[12;3H        [m[12;78H[m[m[13;3H        [m[13;78H[m[m[14;3H        [m[14;78H[m[m[15;3H        [m[15;78H[m[m[16;3H        [m[16;78H[m[16;80H [6;78H[22;1H   The highlighted entry will be executed automatically in 5s.                 [6;78H[22;1H   The highlighted entry will be executed automatically in 4s.                 [6;78H[22;1H   The highlighted entry will be executed automatically in 3s.                 [6;78H[22;1H   The highlighted entry will be executed automatically in 2s.                 [6;78H[22;1H   The highlighted entry will be executed automatically in 1s.                 [6;78H[22;1H   The highlighted entry will be executed automatically in 0s.                 [6;78H[?25h[H[J[1;1H[H[J[1;1H  Booting `RedPill DVA3221 v7.1.0-42661 Beta (SATA, Verbose)'
Loading Linux...
Loading initramfs...
Starting kernel with SATA boot
I tried to rebuild the loader with no success (same result). Can someone please help me?
Edited by error403
It appears the errors are not related to the VM not working. But after "Starting kernel with SATA boot" (reading serial) just nothing seems to be happening. The VM however isn't crashing, and I also don't get a kernel panic. I have no idea about how to debug this...
