i unpluged my hdd from motherboard and reconnected it to every sata in the mother and every time it keeps telling me this
error , but every time the numbers of sata ports change
Can you please open a browser to http://<yourip>:7681 and login with user root and no password ?
The please execute :
lspci -nnqk
fdisk -l |grep Disk |grep sd
cat /proc/cmdline
 grep -E "maxdisks|portcfg" /etc/synoinfo.conf
and post here the output masking your serial ?
Edited by pocopico
lspci -nnqk
cat /proc/cmdline
1 minute ago, pocopico said:
OK, what loader are you using ?
You need to set the vid:pid of your USB disk correctly, then of course fix the SataPortMap. I would change to SataPortMap=1 and move up until you find the right one.
could you kinldly show me how to do SataPortMap  , iam using DS3622xs+_7.1-42661 loader
Yes,
you may test with reboot and while at GRUB select your boot option (USB) and press "E"
use your arrow keys to go down to the line that starts with linux and go to the SataPortMap= and change that to 1
then press F10
19 hours ago, pocopico said:
If this does not work, i suggest you also change in the same way the HddHotPlug from 0 to 1
Thank you so much , after modifying SataPortMap to 1 and HddHotPlug to 1 it works so fine
No it works after i modified HddHotPlug , before i modify it the installatiom went 56% and tells me there is error with dsm version , after i modified HddHotPlug it the installation completed so fine
Hi. I'm having a similar issue. I've used these commands to build but when i try to upload the .pat it fails at 47% every time. I've tried various sataportmap settings and enabled hotswap without success.
./rploader.sh update now
./rploader.sh fullupgrade now
./rploader.sh serialgen DS3622xs+
./rploader.sh identifyusb now
./rploader.sh satamap now
./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/pocopico/redpill-load/raw/develop/redpill-virtio/rpext-index.json
./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/pocopico/redpill-load/raw/develop/redpill-acpid/rpext-index.json
./rploader.sh build broadwellnk-7.1.0-42661
