albyus Posted July 2, 2016 #1 Posted July 2, 2016 hello everyone, I have 12 slots including 4 busy and I would like to add another disk . I connected as usual , the bios see it ( the number 5 ) but when I access the storage management page of the nas the disc is not present. Any idea why? Thank you thank you !! Alberto
AllGamer Posted July 2, 2016 #2 Posted July 2, 2016 Try another SATA port? Did you try restarting the machine? is the new drive connected to a Backplate? some backplates are not compatible is the new drive connected to a different SATA controller? is the SATA controller using a port multiplier? port multipliers are not compatible
andale Posted July 2, 2016 #3 Posted July 2, 2016 Switch Sata mode from IDE to AHCI and disable the IDE combined mode
albyus Posted July 2, 2016 Author #4 Posted July 2, 2016 Try another SATA port?They are occupied Did you try restarting the machine? yes, of course is the new drive connected to a Backplate? some backplates are not compatible no, are all on the mainboard is the new drive connected to a different SATA controller? no is the SATA controller using a port multiplier? port multipliers are not compatible no
albyus Posted July 2, 2016 Author #5 Posted July 2, 2016 Switch Sata mode from IDE to AHCI and disable the IDE combined mode tomorrow i will try thanks
albyus Posted July 3, 2016 Author #7 Posted July 3, 2016 Switch Sata mode from IDE to AHCI and disable the IDE combined mode GREAT, now it's ok thanks!!!
