Pucko Posted January 25, 2022 #1 Posted January 25, 2022 Hello. I try to install xpenology on my HP Microserver Gen 8 I use the DS3615xs 6.1 Jun's Mod V1.02b.img The installation gose fine and it want to reboot. , but when I reboot, I can't connect to it over the network. What Have I missed. Quote
0 Dfds Posted January 25, 2022 #2 Posted January 25, 2022 If you’re doing a fresh install I would recommend DSM 6.2.3 with jun’s 1.03b loader Quote
0 Pucko Posted January 25, 2022 Author #3 Posted January 25, 2022 I tried taht first. Same problem. Tried both DS3615 and DS3617 Installation goes fine. after reboot , cant find the machine. It don't connect to the network Quote
0 Dfds Posted January 25, 2022 #4 Posted January 25, 2022 As it’s a gen8 you can access the serial console via ILO so that you can monitor the boot process. Quote
0 Pucko Posted January 25, 2022 Author #5 Posted January 25, 2022 It is not so much to monitor. It reboot, gets to grup, I select the top option (not the re-install) It shows up the "screen will stop updating shortly" and the go to find.synology page. Thats all Quote
0 Dfds Posted January 25, 2022 #6 Posted January 25, 2022 From memory you need to ssh into the ILO console then type vsp to see the virtual serial port Quote
Pucko
Hello.
What Have I missed.
5 answers to this question
