USB external hard disks on Xpenology (USB PORT issueHyper-V)
Hi all,
Has anyone been able to connect a USB external hard disk to DSM running on a Hyper-V VM?
I did some reading and the "named pipe" cannot be used as USB port passthrough.
thank you!
you could run ESXi as the hypervisor and Windows as a VM on that, alongside XPE/DSM. (its even possible to run H-V within ESXi/Windows VM if you were 'crazy' enough :smile: ) If you want to keep H-V then this might work to connect the USB HDD on the network and mount the drive with the utility
http://www.amazon.co.uk/dp/B002LB8XFK/r ... 9FMGYGYHQE
Thank you SBV300, I will give the later a try cuz I am afraid my "important data" like photos will get all deleted along the way migrating to ESXi.
Just thinking of that I guess I can attach the USB HD to a computer and mount that as a remote drive in FILE STATION..
thank you!
