volume size not correct
patricknooijen
Please tell us if the expanding works, I had to do it manually using: http://idmedia.no/general/expand-volume ... esnt-want/
Initialization took about 8-10mins
Expansion started and has been running about 20 hours as of this post and so far at 25.68% System continues to work without issue and expansion is consistent in progress.
I have had issues in the past on an 4.3 system where expansion completed but volume size did not change. Only another 60hpurs to go before we see? (indeed NeoID you helped me to correct that, thanks again)
