N40L OpenVPN issue
MrDwight
Hi all!
Did a fresh install of DSM 6.2.3-25426 Update 3 with JUN'S LOADER v1.03b - DS3615xs on N40L
All seems to be working, but while connected to OpenVPN (connect) can't access NAS and other LAN devices.
While using OpenVPN GUI I can access NAS and other LAN devices. Any ideas?
PC (windows, mac) and phone are connected to OpenVPN.
N36L is the VPN server.
So, when I'm connected to VPN on either PC, MAC or phone (remotely, over 4G etc.) I can't connect to local network (where the N36L is) can't connect to NAS's IP either.
Access local LAN is ticked in OpenVPN server.
The workaround was to use OpenVPN GUI on PC, homebrew installed open VPN on mac. I think I managed to mess something up...
But as there was no workaround for the phone,
I did another fresh install on another machine and now everything works as it should. :)
Thank for your input @bearcat
Same usecase as I have for my setup, and if I remember correct, I had the same problem the first time I set it up ;-)
Was it a line to edit in the .ovpn file ? don't remember right now.
Using the OpenVPN GUI/Apps on PC's and Android phone/tablet with no problem now :-)
On 4/9/2021 at 3:11 PM, MrDwight said:
Same issue again
How did you sort it out the last time?
I'm using the same config file on different clients, with the DNS pointing to my (PiHole) "local" DNS on my LAN.
And the default gateway pointing to my LAN's default gateway.
Last time I did a fresh install on another machine, so I did not figure it out :) With the new machine everything worked fine at first, but then failed to connect to Synology LAN again. Maybe I need to edit something in vpnconfig file... dunno
