[Adding USB LAN adapter] and will be perfect :)
w00t13
Hi all !
I'm new on the board, I've tried Xpenology on a tiny computer based on Intel Chipset 945GC + ICH7 And CPU Intel® Atom 230 with
2GB SO-DIMM DDR2 and x 3.5”SATA II 320 GB HDD (will add another disk soon) but the network chip is poor : 10/100 Mbps LAN on-board
So I managed to get a USB2.0 to Gigabit LAN adapter like this one : USB21000S2.D.jpg
I've tried it on Ubuntu (lastest version) and it was recognized fine, but nothing to do on Xpenology...
After some search I found this, but I dont know how to cross-compile drivers for Xpenology :cry:
http://www.microchip.com/wwwproducts/De ... ct=LAN7500
My question is pretty simple:
TL;DR : Can somebody help me to get this adapter work on Xpenology ?
USB 2.0 was released in April 2000, adding a higher maximum signaling rate of 480 Mbit/s called High Speed whose effective throughput is limited to 35 MB/s or 280 Mbit/s.
If done you would go from 12MB/s to 35MB/s
https://hallard.me/how-to-install-kerne ... 0-dsm-4-1/
http://www.bydavy.com/2012/01/compiling ... y-devices/
http://forum.synology.com/enu/viewtopic ... 27&t=52065
  • 4 weeks later...
di@Prodigy:~$ lspci -v
00:00.0 Host bridge: Intel Corporation 82945G/GZ/P/PL Memory Controller Hub (rev 02)
       Subsystem: Elitegroup Computer Systems Device 2687
       Flags: bus master, fast devsel, latency 0
       Capabilities:
       Kernel driver in use: agpgart-intel
00:02.0 VGA compatible controller: Intel Corporation 82945G/GZ Integrated Graphics Controller (rev 02) (prog-if 00 [VGA controller])
       Flags: bus master, fast devsel, latency 0, IRQ 16
       Memory at fea80000 (32-bit, non-prefetchable) [size=512K]
       I/O ports at ec00 [size=1]
       Memory at d0000000 (32-bit, prefetchable) [size=256M]
       Memory at fea40000 (32-bit, non-prefetchable) [size=256K]
       Expansion ROM at  [disabled]
       Capabilities:
       Kernel driver in use: i915
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 01)
       Flags: bus master, fast devsel, latency 0, IRQ 40
       Memory at fea38000 (64-bit, non-prefetchable) [size=16K]
       Capabilities:
       Kernel driver in use: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 01) (prog-if 00 [Normal decode])
       Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
       I/O behind bridge: 00001000-00001fff
       Memory behind bridge: feb00000-febfffff
       Prefetchable memory behind bridge: 0000000080000000-00000000801fffff
       Capabilities:
       Kernel driver in use: pcieport
00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 01) (prog-if 00 [uHCI])
       Flags: bus master, medium devsel, latency 0, IRQ 23
       I/O ports at e880 [size=2]
       Kernel driver in use: uhci_hcd
00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 01) (prog-if 00 [uHCI])
       Flags: bus master, medium devsel, latency 0, IRQ 19
       I/O ports at e800 [size=2]
00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 01) (prog-if 00 [uHCI])
       Flags: bus master, medium devsel, latency 0, IRQ 18
       I/O ports at e480 [size=2]
00:1d.3 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 (rev 01) (prog-if 00 [uHCI])
       Flags: bus master, medium devsel, latency 0, IRQ 16
       I/O ports at e400 [size=2]
00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 01) (prog-if 20 [EHCI])
       Memory at fea37c00 (32-bit, non-prefetchable) [size=1K]
       Capabilities:
       Kernel driver in use: ehci-pci
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1) (prog-if 01 [subtractive decode])
       Bus: primary=00, secondary=02, subordinate=02, sec-latency=32
       Capabilities:
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
       Capabilities:
       Kernel driver in use: lpc_ich
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01) (prog-if 8a [Master SecP PriP])
       I/O ports at 01f0 [size=1]
       I/O ports at 03f4
       I/O ports at 0170 [size=1]
       I/O ports at 0374
       I/O ports at ffa0 [size=1]
       Kernel driver in use: ata_piix
00:1f.2 IDE interface: Intel Corporation NM10/ICH7 Family SATA Controller [iDE mode] (rev 01) (prog-if 8f [Master SecP SecO PriP PriO])
       Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 19
       I/O ports at e080 [size=1]
       I/O ports at e000 [size=1]
       I/O ports at dc00 [size=1]
       I/O ports at d880 [size=1]
       I/O ports at d800 [size=1]
       Capabilities:
00:1f.3 SMBus: Intel Corporation NM10/ICH7 Family SMBus Controller (rev 01)
       Flags: medium devsel, IRQ 11
       I/O ports at 0400 [size=2]
01:00.0 Ethernet controller: Qualcomm Atheros Attansic L2 Fast Ethernet (rev a0)
       Subsystem: Elitegroup Computer Systems Device 2048
       Memory at febc0000 (64-bit, non-prefetchable) [size=256K]
       Expansion ROM at feba0000 [disabled] [size=128K]
       Capabilities:
       Kernel driver in use: atl2
Prodigy:~$ lsusb -v
Bus 001 Device 002: ID 0424:7500 Standard Microsystems Corp. LAN7500 Ethernet 10/100/1000 Adapter
Couldn't open device, some information will be missing
Device Descriptor:
 bLength                18
 bDescriptorType         1
 bcdUSB               2.00
 bDeviceClass          255 Vendor Specific Class
 bDeviceSubClass         0
 bDeviceProtocol       255
 bMaxPacketSize0        64
 idVendor           0x0424 Standard Microsystems Corp.
 idProduct          0x7500 LAN7500 Ethernet 10/100/1000 Adapter
 bcdDevice            1.00
 iManufacturer           1
 iProduct                2
 iSerial                 3
 bNumConfigurations      1
 Configuration Descriptor:
   bLength                 9
   bDescriptorType         2
   wTotalLength           39
   bNumInterfaces          1
   bConfigurationValue     1
   iConfiguration          4
   bmAttributes         0xc0
     Self Powered
   MaxPower              100mA
   Interface Descriptor:
     bLength                 9
     bDescriptorType         4
     bInterfaceNumber        0
     bAlternateSetting       0
     bNumEndpoints           3
     bInterfaceClass       255 Vendor Specific Class
     bInterfaceSubClass      0
     bInterfaceProtocol    255
     iInterface              5
     Endpoint Descriptor:
       bLength                 7
       bDescriptorType         5
       bEndpointAddress     0x81  EP 1 IN
       bmAttributes            2
         Transfer Type            Bulk
         Synch Type               None
         Usage Type               Data
       wMaxPacketSize     0x0200  1x 512 bytes
       bInterval               0
       bLength                 7
       bDescriptorType         5
       bEndpointAddress     0x02  EP 2 OUT
       bmAttributes            2
         Transfer Type            Bulk
         Synch Type               None
         Usage Type               Data
       bInterval               0
       bLength                 7
       bDescriptorType         5
       bEndpointAddress     0x83  EP 3 IN
       bmAttributes            3
         Transfer Type            Interrupt
         Synch Type               None
         Usage Type               Data
       wMaxPacketSize     0x0010  1x 16 bytes
       bInterval               1
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
 bLength                18
 bDescriptorType         1
 bcdUSB               2.00
 bDeviceClass            9 Hub
 bDeviceSubClass         0 Unused
 bDeviceProtocol         0 Full speed (or root) hub
 bMaxPacketSize0        64
 idVendor           0x1d6b Linux Foundation
 idProduct          0x0002 2.0 root hub
 bcdDevice            3.16
 iManufacturer           3
 iProduct                2
 iSerial                 1
   bLength                 9
   bDescriptorType         2
   wTotalLength           25
   bNumInterfaces          1
   iConfiguration          0
   bmAttributes         0xe0
     Self Powered
     Remote Wakeup
   MaxPower                0mA
     bLength                 9
     bDescriptorType         4
     bInterfaceNumber        0
     bAlternateSetting       0
     bNumEndpoints           1
     bInterfaceClass         9 Hub
     bInterfaceSubClass      0 Unused
     bInterfaceProtocol      0 Full speed (or root) hub
     iInterface              0
       bLength                 7
       bDescriptorType         5
       bmAttributes            3
         Synch Type               None
         Usage Type               Data
       wMaxPacketSize     0x0004  1x 4 bytes
       bInterval              12
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
 bLength                18
 bDescriptorType         1
 bcdUSB               1.10
 bDeviceClass            9 Hub
 bMaxPacketSize0        64
 idProduct          0x0001 1.1 root hub
 bcdDevice            3.16
 iManufacturer           3
 iProduct                2
 iSerial                 1
   bLength                 9
   bDescriptorType         2
   wTotalLength           25
   bNumInterfaces          1
   iConfiguration          0
   bmAttributes         0xe0
     Self Powered
     Remote Wakeup
   MaxPower                0mA
     bLength                 9
     bDescriptorType         4
     bInterfaceNumber        0
     bAlternateSetting       0
     bNumEndpoints           1
     iInterface              0
       bLength                 7
       bDescriptorType         5
       bmAttributes            3
         Synch Type               None
         Usage Type               Data
       wMaxPacketSize     0x0002  1x 2 bytes
       bInterval             255
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
 bLength                18
 bDescriptorType         1
 bcdUSB               1.10
 bDeviceClass            9 Hub
 bMaxPacketSize0        64
 bcdDevice            3.16
 iManufacturer           3
 iProduct                2
 iSerial                 1
   bLength                 9
   bDescriptorType         2
   wTotalLength           25
   bNumInterfaces          1
   iConfiguration          0
   bmAttributes         0xe0
     Self Powered
     Remote Wakeup
   MaxPower                0mA
     bLength                 9
     bDescriptorType         4
     bInterfaceNumber        0
     bAlternateSetting       0
     bNumEndpoints           1
     iInterface              0
       bLength                 7
       bDescriptorType         5
       bmAttributes            3
         Synch Type               None
         Usage Type               Data
       bInterval             255
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
 bLength                18
 bDescriptorType         1
 bcdUSB               1.10
 bDeviceClass            9 Hub
 bMaxPacketSize0        64
 bcdDevice            3.16
 iManufacturer           3
 iProduct                2
 iSerial                 1
   bLength                 9
   bDescriptorType         2
   wTotalLength           25
   bNumInterfaces          1
   iConfiguration          0
   bmAttributes         0xe0
     Self Powered
     Remote Wakeup
   MaxPower                0mA
     bLength                 9
     bDescriptorType         4
     bInterfaceNumber        0
     bAlternateSetting       0
     bNumEndpoints           1
     iInterface              0
       bLength                 7
       bDescriptorType         5
       bmAttributes            3
         Synch Type               None
         Usage Type               Data
       bInterval             255
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
 bLength                18
 bDescriptorType         1
 bcdUSB               1.10
 bDeviceClass            9 Hub
 bMaxPacketSize0        64
 bcdDevice            3.16
 iManufacturer           3
 iProduct                2
 iSerial                 1
   bLength                 9
   bDescriptorType         2
   wTotalLength           25
   bNumInterfaces          1
   iConfiguration          0
   bmAttributes         0xe0
     Self Powered
     Remote Wakeup
   MaxPower                0mA
     bLength                 9
     bDescriptorType         4
     bInterfaceNumber        0
     bAlternateSetting       0
     bNumEndpoints           1
     iInterface              0
       bLength                 7
       bDescriptorType         5
       bmAttributes            3
         Synch Type               None
         Usage Type               Data
       bInterval             255
mehdi@Prodigy:~$
Also under xpenology i've tried to load smsc7500.ko module compiled from synology sources, driver loaded successfully ans adpter get recognized but i think bug somewhere cause non working ethernet
Your adapter is handle by smsc7500 driver.
I don't think it's included this why it's not working.
If I find some time this week I will try to build it.
Im aware smsc75xx driver isnt included ans should be cross compiled
  • 2 months later...
