Acidmank 0 Posted July 22, 2020 Share Posted July 22, 2020 Hi All. I would like to add a small LCD or Character display to the front of my case that displays the Nas stats. Maybe and IP address, free space status etc. I was thinking this could be powered / driven from usb and installed into a 5.1/4 bay Anyone know how i would achieve this? or even where to start? Quote Link to post Share on other sites
flyride 452 Posted July 22, 2020 Share Posted July 22, 2020 Something like this, write scripts to push data to USB? http://www.yoctopuce.com/EN/products/usb-displays/yocto-display Quote Link to post Share on other sites
Acidmank 0 Posted July 22, 2020 Author Share Posted July 22, 2020 2 hours ago, flyride said: Something like this, write scripts to push data to USB? http://www.yoctopuce.com/EN/products/usb-displays/yocto-display Basically yes. I believe there are many usb character / graphic displays that should do the trick. Many questions need answering how can i read the info? how can i address the usb port? how do i send the data to the device? Quote Link to post Share on other sites
flyride 452 Posted July 22, 2020 Share Posted July 22, 2020 You're asking a lot of general questions that need your own research. Suffice it to say that it is all possible. USB devices are addressable in Linux via /dev To get you started: df will show you space stats. ifconfig will show you IP address information. You're going to need to learn some Linux shell scripting, and some utilities. I suggest spending some time learning grep, awk, cut in particular. Quote Link to post Share on other sites
Acidmank 0 Posted July 22, 2020 Author Share Posted July 22, 2020 (edited) 5 hours ago, flyride said: You're asking a lot of general questions that need your own research. Suffice it to say that it is all possible. USB devices are addressable in Linux via /dev To get you started: df will show you space stats. ifconfig will show you IP address information. You're going to need to learn some Linux shell scripting, and some utilities. I suggest spending some time learning grep, awk, cut in particular. Im not afraid of learning and diving in. I just need a place to start Thanks for the insights. Edited July 22, 2020 by Acidmank Quote Link to post Share on other sites
