iormangund 0 · ID: 1 Posted February 5, 2015 Hi, Just finished building a new xpenology server but cannot get the port multiplier card working. Was hoping someone might have a suggestion for how to get it working? Hardware (though most is probably not necessary, including for thoroughness): Lycom ST-172A SATA III-6Gbps 1-to-5 Port Multiplier [the offending item, http://www.lycom.com.tw/ST-172A.htm] Startech 2 Port PCIE Controller Card ASRock Q1900-ITX 2GB Ram Silstertone DS380 4x1tb HDD (for testing etc, will be putting 8-12 drives from 6tb to 8tb each in the end) The motherboard SATA 3 ports are ASMedia 1061 Port Multiplier compatible ports and work fine with ubuntu, issue only occurs with xpenology. Nanoboot with xpenology 5.0x doesn't register the PM card at all, with XPenoboot and 5.1x the first HDD on the PM card works. From what I can tell the PM card uses JMicron JMB575A chipset (card appears identical to Startech PM card which uses that chip http://uk.startech.com/HDD/Adapters/~ST521PMINT). I have scoured the forum and google looking for a solution, the best I have come up with is viewtopic.php?f=2&t=1361&start=350#p12685 but it seems unclear if that is not implemented in 5.x or if that was only for 4.2? Any help would be appreciated. Share this post Link to post Share on other sites
iormangund 0 · ID: 2 Posted February 8, 2015 Let me ask a slightly different question then, has anyone got an internal port multiplier card working with Xpenology? Share this post Link to post Share on other sites
sbv3000 61 · ID: 3 Posted February 8, 2015 I tried a jmicron port multiplier and found that xpenology only sees the drive on channel 1. I think this is because the jmicron drivers installed are for the basic 2/4 channel SATA controllers. I've successfully built a few 12 drive xpenology boxes using this 4 port add on card http://www.amazon.co.uk/gp/product/B00A ... ge_o00_s00 and some SIL 3114/3214 cards Share this post Link to post Share on other sites
iormangund 0 · ID: 4 Posted February 8, 2015 Due to the motherboard I am using only having one PCIE 2.0 x1 this seemed the best way to get 8 sata ports without losing too much speed (2 onboard @ 300mb/s + 1 onboard @ 600mb/s + port multiplier using 3 ports @ 200mb/s + 2 pcie @ 250mb/s) also giving me support for 2 more 2.5inch hdd if needed in the future. This is working on the fact that I will be using 6tb nas drives which seem to be around 180-240mb/s in benchmarks. If there is no support for port multiplier cards I guess the only other choice is to ditch the PM card and 2x sata card and just use the one you suggested to get 8 ports, albeit 4 of those at only 125mb/s (if my assumption of 500mb/s pcie x1 bandwidth divided by 4 is correct, and I know the sata speed numbers aren't as high as that in real use). Share this post Link to post Share on other sites
