Problems with AI in Moments DSM 6.2
Shade
Good day.
Motherboard: ASRock Z390M-ITX / AC
Prots: Intel Core i3-8100
Downloader: DS918 + v1.04b
There are problems with the Moments application, it does not recognize people and topics. Just hanging a sign "Detection 105 photos" and nothing happens. There is no load on CPU.
The log /var/log/synophoto.log has the following:
2019-07-06T12:42:36+03:00 awesome synoscgi_SYNO.Photo.Setting.User_2_set[2792]: /source/synophoto/src/webapi/module/Photo/Setting/user_setting.cpp:309 User admin(1026) enable ConceptDetection
2019-07-06T12:43:09+03:00 awesome synophoto-task-center: /source/synophoto/src/daemon/task-center/queue/thumb_sender_queue.cpp:125 ThumbSenderQueue Consuming, type = assessment, count = 105
2019-07-06T12:43:16+03:00 awesome synoscgi_SYNO.Photo.Index_2_reindex[3817]: /source/synophoto/src/webapi/lib/index/index.cpp:58 User admin(1026) trigger reindex: all [/var/services/homes/admin/Drive/Moments/]
2019-07-06T12:44:20+03:00 awesome synophoto-task-center: /source/synophoto/src/daemon/task-center/queue/thumb_sender_queue.cpp:125 ThumbSenderQueue Consuming, type = concept, count = 105
2019-07-06T12:45:20+03:00 awesome synophoto-concept: /source/synophoto-plugin-detection/src/detection/plugin.cpp:21 detection plugin init
2019-07-06T12:45:21+03:00 awesome synophoto-concept: uncaught thread task exception /source/synophoto/src/daemon/plugin/plugin_worker.cpp:102 plugin init failed: /var/packages/SynologyMoments/target/usr/lib/libsynophoto-plugin-detection.so
2019-07-06T12:45:21+03:00 awesome synophoto-concept: /source/synophoto-plugin-detection/src/detection/plugin.cpp:21 detection plugin init
Could anybody help with this problem?
Edited by Shade
  • 3 weeks later...
I also had this problem, make sure that the number of cores your Xpenology host is has available,  matches (or is greater than) the number of cores the device you are emulating would have.
So if you emulating a DS3615, make sure your setup has the number or CPU cores that a real DS3615 would have (or more). If you are emulating a DSX3617, make sure your CPU has the amount of cores that are equal to or greater than a real . DSX3617.
  • 1 year later...
@Shade can share your system configuration? I have a J1800-based board running DS918+, so the actual hardware falls short of what it's emulating. Not getting anything in People and Subjects no matter what I tried. Just wondering if anyone else in similar hardware deficit situation like me had better luck. Thanks!
