glenncol Posted April 23, 2014 Share #1 Posted April 23, 2014 Hi all I have been running a HPN54L on Xpenology ( Trantor version) installed from a USB stick as per instructions at the time, i recently went through the install process for gnoBoot to upgrade to DSM 5.0 with a new USB stick taking the old out. The install went well but i decided to go back to the earlier version so i swapped out the USB sticks to the old one and rebooted only to find i was still on DSM 5.0. Does the operating system install to the HD and you are booting from the HD? or is the OP on the memory stick and you are booting from there? Link to comment Share on other sites More sharing options...
buck_danny Posted April 23, 2014 Share #2 Posted April 23, 2014 The Usb is used only for booting linux in a configuration looking close of a synology empty hardware, the DM system is installed on each of the hard disk in the system. Link to comment Share on other sites More sharing options...
htpcdude Posted April 23, 2014 Share #3 Posted April 23, 2014 Follow viewtopic.php?f=2&t=1086&p=8501&hilit=downgrade+to+4.2#p8501 to re-install your older DSM version from Trantor Link to comment Share on other sites More sharing options...
glenncol Posted April 25, 2014 Author Share #4 Posted April 25, 2014 Thanks heaps guys Link to comment Share on other sites More sharing options...
