valent0ne Posted December 27, 2018 #1 Posted December 27, 2018 (edited) Hi all, I just built a NAS with the J3455-ITX using the 1.04b loader and the DS918+ image but I have some issues: - the system wont shutdown (the gui is not reachable but the system is still on) - the processor only works @1.5GHz (intead of bursting to 2.3GHz when required) EDIT: tried with DS916+ image with 1.02b loader and now I'm able to shutdown (and the system is way faster w.r.t. DS918+) Edited December 27, 2018 by valent0ne Quote
tamamma Posted August 16, 2019 #2 Posted August 16, 2019 No update to this? I've the same board and I would like to upgrade Quote
valent0ne Posted August 16, 2019 Author #3 Posted August 16, 2019 18 minutes ago, tamamma said: No update to this? I've the same board and I would like to upgrade Nope...I ended up using OpenMediaVault (no issues in this case) Quote
T-REX-XP Posted August 16, 2019 #4 Posted August 16, 2019 Guys, this problem has been solved via modified extra.lzma. please find the solution via forum search. P.S: Shutdown via hardware button should work after installing poweroff package from this forum. Quote
tamamma Posted August 17, 2019 #5 Posted August 17, 2019 On 8/16/2019 at 1:49 PM, T-REX-XP said: Guys, this problem has been solved via modified extra.lzma. please find the solution via forum search. P.S: Shutdown via hardware button should work after installing poweroff package from this forum. Tnx I'm gonna search, i found something just with J4205 at the moment Quote
