I've run into a problem when trying to mount a .pat file using OSFMount on a Windows 7 PC.
At first, whenever I try to mount the file, I get an error related to driver signing and that the file is unsigned
At first, I tried to disable driver signing by disabling it in the F8 boot options, which did not work.
Then I tried to disable driver signing in an elevated command prompt using:
"bcdedit.exe /set nointegritychecks on", which did not work either.
I then installed the KB3033929 hot fix as mentioned here.
After installing that hot fix, I could mount the drive but now, whenever I try to access the drive I get an error stating "F:\ is not accessible. The parameter is incorrect."
I'd appreciate it if anyone can give me an idea on what is causing this problem.
Gerhardt
Hi.
Cheers.
Edited by Gerhardt2 answers to this question
