frank_zero Posted March 6, 2013 Share #1 Posted March 6, 2013 hello, I want to install on esxi 5.1 but can anyone tell me hou to do theat? Frank Quote Link to comment Share on other sites More sharing options...
patmtp35 Posted March 6, 2013 Share #2 Posted March 6, 2013 DSM 4.1 working like a charm on my esxi5.1 => viewtopic.php?f=2&t=514 Quote Link to comment Share on other sites More sharing options...
jukolaut Posted March 10, 2013 Share #3 Posted March 10, 2013 After some hours of hacking I now have fully working ESXi 5.1 virtual machine setup with DS 4.2 (3202). To get PVSCSI and VMXNET3 working a new kernel needs to be compiled. To make matters worse, scsi drives are not supported at all. So some steps need to be done: scsi disk support must be added to drivers/scsi/sd.c so that they are marked as SYNO_DISK_SATA instead of SYNO_DISK_UNKNOWN disks must be marked as system disks so that the md will autodetect the system raid partition (gd->systemDisk = 1) having ata as well as scsi disks will not work. quick workaround is to disable sata support from the kernel. this has the added benefit of hiding the boot disk partitions if sata is disabled some important symbols are not compiled in and synobios.ko module will not load, causing scemd to halt the system implement dummy synobios kernel module that keeps scemd happy Performance seems to be excellent, quite possibly due to paravirtualized drivers. S.M.A.R.T. is not working, but that was expected. Some things are still in todo-list: compile in open-vm-tools to keep esxi from nagging about installing tools clean up kernel from unneeded device drivers, also clean modules from hd image try to get scemd not to constantly poll SYNOIO_SET_DISK_LED and SYNOIO_GET_EUNIT_TYPE investigate if using stock kernel is possible with dummy synobios and CONFIG_EXT4_FS_SYNO_ACL Quote Link to comment Share on other sites More sharing options...
doedels Posted March 11, 2013 Share #4 Posted March 11, 2013 Great work jukolaut, can you share your work so far? Quote Link to comment Share on other sites More sharing options...
DAPBENJAMIN Posted March 11, 2013 Share #5 Posted March 11, 2013 Hi, I second that. I would love to get the version you are working on please. Regards, Darren Quote Link to comment Share on other sites More sharing options...
jukolaut Posted March 11, 2013 Share #6 Posted March 11, 2013 Ok, do you need sources or binaries? The binaries are here(v2): http://yadi.sk/d/fTRkFMyU3D8Yc This is based on odie82544's DS3612xs_3202-Repack images, so thanks for those! Only the kernel, modules and linuxrc.syno are modified so far. The archive contains both the .pat file for installation and .vmdk file for boot. Create the virtual machine to esxi and add hardware: IDE controller with single harddisk (vmdk file in archive). Boot from this. PVSCSI controller and raw harddisks or vmdk files for data. I've tested with 3 disks so far. VMXNET3 network. Only single interface in bridged mode is tested so far. MAC address can be anything. Follow the installation instructions elsewhere in this forum to install the pat file. I wouldn't use this for anything else than evaluation yet. Quote Link to comment Share on other sites More sharing options...
doedels Posted March 12, 2013 Share #7 Posted March 12, 2013 Many thanks Jukolaut! Quote Link to comment Share on other sites More sharing options...
pbjr Posted March 12, 2013 Share #8 Posted March 12, 2013 jukolaut, thank you for sharing your work. Much appreciated! I'm going to try this weekend. Quote Link to comment Share on other sites More sharing options...
ric_hochet Posted March 12, 2013 Share #9 Posted March 12, 2013 Great work jukolaut The installation was done without any difficulty on ESXI 5.1. But performance don't be very high: only 5MB/s with CIFS (same performance as DSM 4.1) In comparaison, FreeNas (aka Nas4free) transfers speed are about 25MB/s in the same environment. I use Microserver N40L for this tests. Have you an idea why is it so slow ? Quote Link to comment Share on other sites More sharing options...
jukolaut Posted March 12, 2013 Share #10 Posted March 12, 2013 But performance don't be very high: only 5MB/s with CIFS (same performance as DSM 4.1) In comparaison, FreeNas (aka Nas4free) transfers speed are about 25MB/s in the same environment. Well, thats bad! I'm not able to offer much support but can you tell about your setup: how many disks do you use for data? raw or vmdk? In esxi, does it show high cpu usage even when idle? Quote Link to comment Share on other sites More sharing options...
patmtp35 Posted March 12, 2013 Share #11 Posted March 12, 2013 just have it test but there is something strange , i generate a MAC adress but it seems it kept the same as my DSM4.1 vm did you have some idea ? Quote Link to comment Share on other sites More sharing options...
ric_hochet Posted March 12, 2013 Share #12 Posted March 12, 2013 But performance don't be very high: only 5MB/s with CIFS (same performance as DSM 4.1) In comparaison, FreeNas (aka Nas4free) transfers speed are about 25MB/s in the same environment. Well, thats bad! I'm not able to offer much support but can you tell about your setup: how many disks do you use for data? raw or vmdk? In esxi, does it show high cpu usage even when idle? I found the problem: it was made by my multiple tests on this VM. vSphere Client told me to consolidate my snapshots (even if i had no more snapshot); After consolidate, transfers speed is identical to freenas ! Quote Link to comment Share on other sites More sharing options...
Tuatara Posted March 14, 2013 Share #13 Posted March 14, 2013 I wouldn't use this for anything else than evaluation yet. I haven't yet installed it, but I will shortly on ESXi 5.1. I have an older (slow) consumer Synology myself and use FreeNAS for personal large data storage. I'm hoping to be able to use 10 drives (Raw Device Mapping) in a SHR-2 (two drive data redundancy) combination under ESXi. Do you know if your version will support this many (physical pass-through PVSCSI) drives? (FYI: Awesome Raid Calculator: http://www.synology.com/support/RAID_ca ... hp?lang=us). It would be great if I'm able to combine everything and leave FreeNAS behind. As I also support many businesses which are using Synology; to also have a virtual development & deployment testing environment before deploying the actual Synology hardware would be incredible. Cheers & Thanks for all your work. Quote Link to comment Share on other sites More sharing options...
devastator Posted March 16, 2013 Share #14 Posted March 16, 2013 Ok, do you need sources or binaries?Create the virtual machine to esxi and add hardware: IDE controller with single harddisk (vmdk file in archive). Boot from this. PVSCSI controller and raw harddisks or vmdk files for data. I've tested with 3 disks so far. VMXNET3 network. Only single interface in bridged mode is tested so far. MAC address can be anything. Could you explain how to do this with no real disks ? I store my data on a Unraid VM, but want to use the synology because of the apps to view the pictures etc ... Quote Link to comment Share on other sites More sharing options...
ema Posted March 18, 2013 Share #15 Posted March 18, 2013 After some hours of hacking I now have fully working ESXi 5.1 virtual machine setup with DS 4.2 (3202).... [*]investigate if using stock kernel is possible with dummy synobios and CONFIG_EXT4_FS_SYNO_ACL Hi jukolaut, thanks for you work! I'm doing some test on esx5.0 with high availability... vm1: syn1, 3 x vmxnet3 nic (edited grub.conf, each nic with different mac), 500gb vmdk, HA plugin (active) vm2: syn2, 3 x vmxnet3 nic (edited grub.conf, each nic with different mac), 500gb vmdk, HA plugin (passive) When i setup HA cluster, vm1 return an error If I look at vm1 console, I can see this: After some times vm1 fail to ceate HA cluster. Any suggestion? Thanks! ema Quote Link to comment Share on other sites More sharing options...
devastator Posted March 19, 2013 Share #16 Posted March 19, 2013 Can somebody plz help me to get 'Package Center' running ? Quote Link to comment Share on other sites More sharing options...
patmtp35 Posted March 19, 2013 Share #17 Posted March 19, 2013 hi emma where can i found grub.conf ? did you modify it with wincsp and wm on ? Quote Link to comment Share on other sites More sharing options...
ema Posted March 19, 2013 Share #18 Posted March 19, 2013 hi emma where can i found grub.conf ? did you modify it with wincsp and wm on ? Hi! I mounted vmdk in another linux vm and I edited the grub.conf. 1) turn off xpenology vm 2) in another linux vm add the vmdk 3) start linux vm and mount vmdk, for example mount /dev/sda1 /mnt/hd 4) edit grub.conf, you can found it on /mnt/hd/boot/grub/grub.conf 5) refer to this post for editing grub.conf http://xpenology.com/forum/viewtopic.php?f=2&t=55#p284 6) shutdown linux vm 7) restart xpenology vm Ciao ema Quote Link to comment Share on other sites More sharing options...
devastator Posted March 19, 2013 Share #19 Posted March 19, 2013 Can somebody plz help me to get 'Package Center' running ? Anybody? Or another way to install photo station ? Quote Link to comment Share on other sites More sharing options...
jakkes Posted March 19, 2013 Share #20 Posted March 19, 2013 Thanks!!! I installed it, and works great!! I tried to change the mac adres in de ESX host, but that didn't work...., is it possible to change it somewhere, somehow? Quote Link to comment Share on other sites More sharing options...
patmtp35 Posted March 19, 2013 Share #21 Posted March 19, 2013 thanks ema will try tomorow ! Quote Link to comment Share on other sites More sharing options...
synolo Posted March 25, 2013 Share #22 Posted March 25, 2013 Ok, do you need sources or binaries? The binaries are here(v2): http://yadi.sk/d/fTRkFMyU3D8Yc This is based on odie82544's DS3612xs_3202-Repack images, so thanks for those! Only the kernel, modules and linuxrc.syno are modified so far. The archive contains both the .pat file for installation and .vmdk file for boot. Create the virtual machine to esxi and add hardware: IDE controller with single harddisk (vmdk file in archive). Boot from this. PVSCSI controller and raw harddisks or vmdk files for data. I've tested with 3 disks so far. VMXNET3 network. Only single interface in bridged mode is tested so far. MAC address can be anything. Follow the installation instructions elsewhere in this forum to install the pat file. I wouldn't use this for anything else than evaluation yet. Thanks for Upload, but can you upload in other share provider? hier is 64k download limit, it means I need about 7 hour to download. Quote Link to comment Share on other sites More sharing options...
fl0w Posted March 26, 2013 Share #23 Posted March 26, 2013 Ok, do you need sources or binaries? The binaries are here(v2): http://yadi.sk/d/fTRkFMyU3D8Yc This is based on odie82544's DS3612xs_3202-Repack images, so thanks for those! Only the kernel, modules and linuxrc.syno are modified so far. The archive contains both the .pat file for installation and .vmdk file for boot. Create the virtual machine to esxi and add hardware: IDE controller with single harddisk (vmdk file in archive). Boot from this. PVSCSI controller and raw harddisks or vmdk files for data. I've tested with 3 disks so far. VMXNET3 network. Only single interface in bridged mode is tested so far. MAC address can be anything. Follow the installation instructions elsewhere in this forum to install the pat file. I wouldn't use this for anything else than evaluation yet. Thanks for Upload, but can you upload in other share provider? hier is 64k download limit, it means I need about 7 hour to download. Sign up on Yandex Disk you'll be able to download at full bandwidth, and it's free. Quote Link to comment Share on other sites More sharing options...
patmtp35 Posted March 29, 2013 Share #24 Posted March 29, 2013 (edited) hi! my expenology seems to have some errors on start , as i have a message in dsm history and logo on the right is orange. so where can i found log of start process ? Edited March 30, 2013 by Guest Quote Link to comment Share on other sites More sharing options...
jukolaut Posted March 29, 2013 Share #25 Posted March 29, 2013 After some times vm1 fail to ceate HA cluster. Any suggestion? Thanks! ema I don't see any problem in the screenshot. The SYNOIO_ -messages are normal. Try looking at the system logs from the web console. I don't have a HA setup myself so I have no idea if that works or not, sorry Quote Link to comment Share on other sites More sharing options...
