razer1x2 Posted November 28, 2013 Share #1 Posted November 28, 2013 (edited) Hi guys, Yet again, Looking for advice/ help.. I have a N54L microserver in stock config with 3x2tb hdds running 4.3 build successfully natively.. Works pretty well actually Trying to get WOL working but had no luck. Wol is enabled in Bios so that side seems ok but as soon as I try to enable it in the DSM control panel, it refuses it saying it hasnt saved changes to WOL config. I remember reading about making changes to the etho config directly from SSH'ing into the machine but cant seem to find it. - Can someone talk me through the steps I need to do to change this? I can SSH into it ( from Mac terminal ) so that's fine. Just need the cmd line stuff really... Bit of a newbie for cmd line work/ linux in general! Cheers, Ryan ** Edit** Now got Schedule startup/shutdown is playing up! Might have to go back to 4.2 build.... Unless anyone got suggestions?? Edited November 29, 2013 by Guest Link to comment Share on other sites More sharing options...
DHD Posted November 29, 2013 Share #2 Posted November 29, 2013 DSM always says "can not setup WOL", just ignore it and you still can use WOL. Link to comment Share on other sites More sharing options...
razer1x2 Posted November 29, 2013 Author Share #3 Posted November 29, 2013 Yeah mangaged to find the WOL settings for the eth0 config.. WOL working but now cant get scheduled shutdown/startup to work on 4.3? The scheduling accepts the schedule's and saves ( still there even after shutdown! ) but refuses to do anything? Not sure if setting in the modded Bios refusing to let it do it or something in the 4.3 build?? 4.2 was working fine! :S Ry Link to comment Share on other sites More sharing options...
DHD Posted November 29, 2013 Share #4 Posted November 29, 2013 (edited) I use 'advanced power manager' instead. It working like a charm. Edited December 3, 2013 by Guest Link to comment Share on other sites More sharing options...
razer1x2 Posted November 29, 2013 Author Share #5 Posted November 29, 2013 I cant seem to get that to work either?? Tried it last night and didnt want to shut down so not sure where to go now??...... Link to comment Share on other sites More sharing options...
toshas Posted November 30, 2013 Share #6 Posted November 30, 2013 I use 'advanced power manager' instead. It working like a charm. Could you share more details ? Do you mean "Advanced Power Manager for Synology DS" ? http://sourceforge.net/projects/advpowermgr4ds/ Does APM bios reset ? (I know that sheduled poweroff-poweron resets bios on XPEnology) Link to comment Share on other sites More sharing options...
DHD Posted December 3, 2013 Share #7 Posted December 3, 2013 I use 'advanced power manager' instead. It working like a charm. Could you share more details ? Do you mean "Advanced Power Manager for Synology DS" ? http://sourceforge.net/projects/advpowermgr4ds/ Does APM bios reset ? (I know that sheduled poweroff-poweron resets bios on XPEnology) Yes, it's. It's works on my NAS without any problem. Link to comment Share on other sites More sharing options...
toshas Posted December 4, 2013 Share #8 Posted December 4, 2013 You have lucky hw configuration! I got the same bios reset problem (on N40L) that I had before with default Synology scheduler. All work fine with default settings eg loading from usb, wol and etc. But flash memory has limitation on write cycles count (around 1000). And thus every day rewrite is not good. Link to comment Share on other sites More sharing options...
razer1x2 Posted December 4, 2013 Author Share #9 Posted December 4, 2013 My Startup still refuses to work right at all.. Thinking of swapping to the original 4.2 build and use a raspberry pi for VPN and then see if I can get WOL to work on 4.2 as never really tried properly.. Link to comment Share on other sites More sharing options...
Kristallix Posted December 20, 2013 Share #10 Posted December 20, 2013 Just tried Advanced Power Manager on my N54L with DSM 4.3 build 3810 on it. Nicely shut down and booted up at the configured times. But during boot up bios got reset. Does anyone have an idea how to solve these bios resets? Can't find anything unfortunately. Cheers, Rob Link to comment Share on other sites More sharing options...
funk223 Posted March 25, 2014 Share #11 Posted March 25, 2014 Just tried Advanced Power Manager on my N54L with DSM 4.3 build 3810 on it. Nicely shut down and booted up at the configured times. But during boot up bios got reset. Does anyone have an idea how to solve these bios resets? Can't find anything unfortunately. Cheers, Rob So that, the Advanced Power Manager is just based on in stock schedule system, which doesn't help to solve the problem. Need to find which program cleared the bios configurations. That is the hard core of the issue. If they solve the problem, I'd like to donate. Link to comment Share on other sites More sharing options...
tahitibub Posted March 21, 2016 Share #12 Posted March 21, 2016 Hi, You should read that. I hope developers will include the patch in the next XPEnoboot. Regards Link to comment Share on other sites More sharing options...
