Hello,
Anyone else having problems with Xpenology reading any external hard drives through USB or a UPS through usb. I followed Synology guide to make sure the hard drives or USB drives was in a format that it readable and still nothing. I don't know if it might be a driver issue or not any help would be greatly appreciated at least if can get me going in the right direction with troubleshooting it.
The box I am running it on is a Freenas mini basically decided to try something else when freenas 10 went to crap.
https://www.ixsystems.com/freenas-mini/
Thanks for your time
2 answers to this question
Depending on your hardware setup, USB ports, SATA ports, drives etc you might need to edit the synoinfo.conf file to match your configuration. You might need to edit the hex values, there are lots of posts about about this.
Okay thanks I am pretty sure I saw that on another site when doing research on it
Answer this question...
