Need help rebuilding SHR
Hackerjac
I have a 6 disk SHR 1 running on Xpenology 5.2 5967 update 2, motherboard, Asrock c2750d4i
i disconnectet it last night, caurse i needed to replace the BNC chip, but in the struggle to replace it i pulled off one of the sata cabels, diden't noticed it before after i had turned it on again, so it warned me that my volume was either crashed or degraded, i then found out of the disk was disconnectet, turned of the server and plugged the sata in again, rebooted, hoping everything would work, well it diden't.
I then went to repair the volume using the disk that i reconnectet, it went on for almost 24 hours, and told me it was done, but my volume is still crashed and i can acces any files on the server
Anyone have some very good ideas about how to save this volume
