USB port considered as internal disk with PCI-e ASMedia 1064 + M2 card for additionnal 30 satas ports on DS918+
Hello,
After several attempts to get all my satas ports to work properly and to preserve my usb ports as an external drive, I decided to write here hoping to find some help !
I have a Xpenology 7.2 DS918+ running a SuperMicro X11SCL-IF motherboard with 4 physical sata ports and a total of 8 USB ports.
I recently updated it to version 7.2 (Model DS918+) by following the tutorial =>
I then added a PCI-e 16x expansion card with 24 sata ports : TISHRIC TSR818 – ASM1812+1064 chip
I also added an NVME M2 card with 6 sata ports : Riser - M.2 to SATA 3.0
This gives me a total of 34 satas ports (yes, I know it's a lot, but I wanted to be able to use all my old disks and not be limited in the future).
As the DS918+ is limited to 16 disks by default, I made the modifications to support my 34 satas ports by rebooting on tinycore build.
To do this, I modified the user_config.json to obtain the following properties:
"synoinfo": {
  "internalportcfg": "0x3FFFFFFFF”,
  "maxdisks": "34",
  "esataportcfg": "0x0",
  "usbportcfg": "0x3FC00000000"
I then ran the command ./rploader.sh satamap
I was surpised by what it displayed because it wasn't very consistent:
For my motherboard with 4 physical ports
Found "00:17.0 Intel Corporation Device a352 (rev 10)" Detected 6 ports/0 drives. Override # of ports or ENTER to accept <6>
6 ports found instead of 4 physical ports. No bad ports. So I declared 4 instead of 6.
For my PCI-e x16 card with 24 physical ports
Found "03:00.0 ASMedia Technology Inc. Device 1064 (rev 02)" Detected 24 ports/0 drives. Bad ports: -139 -138 -137 -136 -133 -132 -131 -130 -129 -128 -127 -126 -125 -124 -123 -122 -121 -120. Override # of ports or ENTER to accept <24>
Found "04:00.0 ASMedia Technology Inc. Device 1064 (rev 02)" Detected 24 ports/1 drives. Bad ports: -115 -114 -113 -112 -109 -108 -107 -106 -105 -104 -103 -102 -101 -100 -99 -98 -97 -96. Override # of ports or ENTER to accept <24>
Found "05:00.0 ASMedia Technology Inc. Device 1064 (rev 02)" Detected 24 ports/0 drives. Bad ports: -91 -90 -89 -88 -85 -84 -83 -82 -81 -80 -79 -78 -77 -76 -75 -74 -73 -72. Override # of ports or ENTER to accept <24>
Found "06:00.0 ASMedia Technology Inc. Device 1064 (rev 02)" Detected 24 ports/0 drives. Bad ports: -67 -66 -65 -64 -61 -60 -59 -58 -57 -56 -55 -54 -53 -52 -51 -50 -49 -48. Override # of ports or ENTER to accept <24>
Found "07:00.0 ASMedia Technology Inc. Device 1064 (rev 02)" Detected 24 ports/0 drives. Bad ports: -43 -42 -41 -40 -37 -36 -35 -34 -33 -32 -31 -30 -29 -28 -27 -26 -25 -24. Override # of ports or ENTER to accept <24>
Found "08:00.0 ASMedia Technology Inc. Device 1064 (rev 02)" Detected 24 ports/0 drives. Bad ports: -19 -18 -17 -16 -13 -12 -11 -10 -9 -8 -7 -6 -5 -4 -3 -2 -1 0. Override # of ports or ENTER to accept <24>
6 times detected with 24 ports on each with 18 bad ports each time. Knowing that I only have one card with 24 physical ports.
I divided 24 by 6 and declared 4 for each.
For my M2 NVME board with 6 physical ports
Found "0e:00.0 ASMedia Technology Inc. Device 1166 (rev 02)" Detected 32 ports/0 drives. Bad ports: 7 8. Override # of ports or ENTER to accept <32>
32 ports detected with 2 bad ports. Knowing that I only have 6 physical ports.
I declared 6 instead of 32.
At the end, I get a warning telling me that there are bad ports, but I apply my config anyway and I get this in my user_config.json.
"extra_cmdline": {
  "SataPortMap": "44444446",
  "DiskIdxMap": "0004080c1014181c"
I boot my system and all my sata slots seem to work (modulo the order of the disk numbers which are not consistent).
I've read that I can redefine the order with sata_remap in extra_cmdline, is this true?
On the other hand, when I plug in an external usb disk, it's detected as an internal device with disk number 17 (whatever USB port I use, I have 8 in total).
And that's the subject of my message.
How can I preserve my usb ports so that it's considered an external and not an internal disk?
It must surely be linked to the wrong ports, but how do I manage them correctly ?
If anyone has the right procedure I'm a taker 🙂
Here's the output of my dmesg command dmesg.txt
Thank you in advance for your contribution
Edited by andgest
Change title
  • andgest changed the title to USB port considered as internal disk with PCI-e ASMedia 1064 + M2 card for additionnal 30 satas ports on DS918+
