slushy Posted March 13 Share #1 Posted March 13 (edited) Hello everyone, Wondering if any one has similar issue or it's just me. I've tried many different options, but seems none of that helps. I would apprechate your suggestions and help. Details below: I'm having an issue with my Xpenology DSM 7.2 64570 installed on ESXi. I have used Redpill loader, setup went fine, activated AME codecs. VideoStation started to work all fine, I can watch the movies etc. But... There is one problem with TMDB plugin, which seems to be not working correctly. I've supplied the API key (same as used on my real DS918+) but I cannot get plugin to work on Xpenology. My observations do far: - tried different OS - DSM 7.0, 7.1, 7.2, different Xpenology loaders DS918+, DS920+ - after supplying API key in VideoStation > Settings > TheMovie Database > Edit > Test Connection - it does show connection successful. - Unfortunately from previous view (Video Info Plugin) testing connection fails with a message "Connection fails". - Tried internet recommendations about static DNS settings or preffering IPv4 addresses in resolution but none of that works. - started reviewing logs on my own and found that there are some access denied in script execution, which is responsible for getting data from TMDB. " /var/log/bash_err.log:84353:" -> (23505)"/bin/bash -p /var/packages/VideoStation/target/plugins/syno_themoviedb/loader.sh --type movie --lang enu --input {"title":"Poufne lekcje perskiego (2020)"} /var/log/bash_err.log:84354:" -> (23507)"/bin/bash -p /var/packages/VideoStation/target/plugins/syno_themoviedb/loader.sh --type movie --lang enu --input {"title":"Poufne lekcje perskiego (2020)"} /var/log/bash_err.log:84355:" ] /var/packages/VideoStation/target/plugins/syno_themoviedb/loader.sh: line 8: /sbin/sed: Permission denied /var/log/bash_err.log:84356:2024-03-12T21:21:44+01:00 SynologyMedia bash[23512]: BASH_ERR: report_error [ (23509)"/bin/bash -p /var/packages/VideoStation/target/plugins/syno_themoviedb/loader.sh --type movie --lang enu --input {"title":"Poufne lekcje perskiego (2020)"} " Edited March 13 by slushy More details addition Quote Link to comment Share on other sites More sharing options...
dj_nsk Posted March 17 Share #2 Posted March 17 В 13.03.2024 в 18:49, slushy сказал: - Unfortunately from previous view (Video Info Plugin) testing connection fails with a message "Connection fails". check by SSH: nslookup api.themoviedb.org do you see some like this? ... Name: api.themoviedb.org Address: 13.227.219.100 Name: api.themoviedb.org Address: 13.227.219.32 Name: api.themoviedb.org Address: 13.227.219.43 ... Quote Link to comment Share on other sites More sharing options...
