Blexxx Posted February 3, 2024 #1 Posted February 3, 2024 Hi all! It's my first topic in this forum and I'm not very sure that this is the right subplace but I here is my question: I can't create a volume on a HP Gen10 with a H240 controller card and 4x2TB SAS drives. The system see the disks but no way to create a volume, after a couple of seconds, a message shows that the volume can not be created. But on the original motherboard controller, I have no problem to create another Raid volumen with SATA disks.... My Xpenology is 7.2.1 ds3622xs+. Thx for watching and BIG THX to all community Quote
Blexxx Posted February 4, 2024 Author #2 Posted February 4, 2024 I answer myself: after all, the problem probably was on disks, after changing all 4 disks with SATA ones, the volume was build with no problem (actually is building it right now). My suspects are that the SAS ones have the original structure from the original server I've taken from, and Xpenology did not mount them properly. Quote
