Problem with 12400F & Gigabyte B660M DSH3 AX DDR4
Refer
Hello, I am trying to install the DSM on the following computer:
Intel Core i5-12400F 4.4GHz
Corsair Vengeance LPX DDR4 3200 PC4-25600 16GB 2X8GB CL16 Black
Aerocool CS-105 USB 3.0 Black/Red with Window
Crucial SSD 1GB
2 SATA 2TB
Gigabyte GeForce GTX 970 Gaming G1 WindForce OC 4GB GDDR5
I have tried with the arl, arc and redpill loaders, loading the r8125 module, since my integrated network card is a Realtek 8125BC 2.5GB, the fact is that with all the loaders, when DSM is loaded it crashes, I cannot find the DSM from find.synology.com or from the wizard.
It has only worked for me once, with an "arpl" loader that failed yesterday, I put the same loader today and it found it, the installation started, it detected the hard drives and the formatting crashed, after more than half an hour, I reset, I tried those disks again in Windows and I had made 3 partitions, one of 8GB, one of 2GB and the remaining unallocated space.
After that successful connection, it has not worked again in any way.
You know that it may be due?
Edited by Refer
Excuse my lack of understanding, I suppose the problem may come from the generation 12 E-cores, the problem is that I don't know how to disable them on my motherboard.
Regarding the loaders, I have tried arc, arpl and redpill and none of them have solved the problem.
Edited by Refer
