Azarok Posted August 9, 2023 #1 Posted August 9, 2023 Hi All Before I buy any hardware for the PC on which I intend to install xpenology, I have a few questions. I saw in the same article that other users validate the updates on their baremetal system, so I wouldn't ask which hardware is better. However, I'm seeking for a machine that is power cost-effective. I noticed that some users are using xpenology on devices like the HP Prodesk G4 (I might choose combo/machine like this one) which depending on the model may have two or three sata ports. Will a PCI-E to SATA 3.0 Controller Card with 4 ports work in such a machine? I'm considering installing four disk (maybe 10TB). Do they provide enough redundancy? Additionally, I would primarily use this machine as a storage solution; I might install nextcloud, qtorrent, and other programmes, but nothing really special. Will an i3 suffice or do I need at least an i5 for that? Thank you in advance for your help and feel free to make any suggestions that would help me achieve my goal. Quote
dj_nsk Posted August 11, 2023 #2 Posted August 11, 2023 В 09.08.2023 в 22:03, Azarok сказал: Will a PCI-E to SATA 3.0 Controller Card with 4 ports work in such a machine? most likely yes (I don't think the BIOS will interfere with such use, but it will be necessary to choose the right controller) В 09.08.2023 в 22:03, Azarok сказал: Do they provide enough redundancy? yes (use SHR-1) В 09.08.2023 в 22:03, Azarok сказал: Will an i3 suffice or do I need at least an i5 for that? yes Quote
