tale Posted June 19, 2023 Share #1 Posted June 19, 2023 Hello I am new to this, I hope to express myself well. English by google. I use an Acer Aspire ES15 (i5-4200u, 4GBDDR3) laptop I managed to install without any problem a DS3622X+ with DSM 7.1-42661 update 1. I think everything works well except WOL. In DSM (Control Panel>General>Power Recovery) I can mark the WOL box but when I click on apply this it is unmarked. There always indicates "out-of-Band". I have manually modified the /etc/synoinfo.conf file. I have changed the line eth0_wol_options="d" to eth0_wol_options="g" But WOL doesnt work. Any idea? Quote Link to comment Share on other sites More sharing options...
pocopico Posted June 19, 2023 Share #2 Posted June 19, 2023 (edited) Which loader are you using ? Maybe you can check : https://github.com/pocopico/tcrp-addons/blob/main/wol/releases/install.sh to get an idea about how to set it up. You will most probable need ethtool binary https://github.com/pocopico/tcrp-addons/raw/main/wol/releases/ethtool Edited June 19, 2023 by pocopico Quote Link to comment Share on other sites More sharing options...
tale Posted June 20, 2023 Author Share #3 Posted June 20, 2023 Hi. Thank you for your guidance but my clumsiness is perhaps beyond my expectations. I need a little more help until I am clear. Laptop is AcerAspire ES15 with RTL8168/8111 PCI-E Gigabit Ethernet NIC For the installation I have followed the instructions of https://aventuratecnologica.com/convertir-pc-en-servidor-casero-nas-synology/ and used tinycore-redpill-uefi.v0.8.0.5.img. Then, after generating and booting with the usb, in the console: tc / P@ssw0rd ./rploader.sh update ./rploader.sh fullupgrade ./rploader.sh identifyusb ./rploader.sh serialgen DS3622xs+ ./rploader.sh build broadwellnk-7.1.0-42661 exitcheck.sh reboot And everything ok, except WOL. Ufff. Now, my doubts Can I upgrade an installation without losing data? Maybe by booting the system from "Tiny Core Image Build" and using console/terminal with tc --- P@ssw0rd? But what commands or script? Maybe it's easier to start from the beginning losing the current configuration and data? Yes, I'm a bit hard-headed. Maybe age... But thanks a lot for everything. Quote Link to comment Share on other sites More sharing options...
