Hello all,
I have a small problem, everytime the dsm shuts down because of overheating hardware, anyone knows the files i need to edit to prevent this from happening.
*edit*
I have found some info on the net to disable the temperature shutdown, but after changing that the machine shutsdown with a powerfailure, i try and find the cause and post the steps i took later.
Ok i changed the settings in scemd.xml in /usr/syno/et and etc.default
After this the workstation doesn't shutdown with a temperature error anymore but it shutsdown with a power failure.
I think it is not the dsm that is shutting it down now but the bios from the unit itself.
