Hi I am using Dell r510 as my device. With DSM 6.2.4  with jun loader ds 3618 xs , the main problem is that the lan or Ethernet port are not picking up by the system
I was using next cloud on unraid previously on system the lan port was picking up fin
The same problem accord when I use redpill to run Nas
  • 10 months later...
You need to add the extra.lzma to the loader to pick up the NICs on the r510. OR add a supported NIC to use.  I have it working on 1 r510 actually having the same issue trying to get up and running on the 2nd. Download links are expired.
