Problem by Installation from pat file (Network?)
Hi @ all.
I have a Board mini itx ASUS PRIME 4005 with a celeron n4005 and an RTL8111 NIC. I create an stick with bromolow-7.1.0 42218 for ds3615xs. I have see the image building was used the driver for NIC RTL8168. The building from stick was finished without any error. I can boot from stick an i find my synology with the Assistant. Then if i will install the *pat with the assistant and this program is running. But after the message "Applying network setting" the network is note ok. i lost the connection to synology and the installation was stopped.
If you have any idea what i can do? Is this a problem with the network driver? The same board is running with jun's 6.2.3-25426 and all works fine.
sorry for my english, thanks in advance and best regards
Edited by Lediesh2k
  • 4 weeks later...
