I had Xpenonlogy running perfectly fine in a ESXI6 VM. A colleague accidentally tried to upgrade to DSM 6 via Synology which of course is not compatible. The system now boots ok but into the old 5.2-5644. The poblem is when booting it assigns a totally random (public) IP address not from our normal internal IP range, so the Synology Assistant cannot find the machine.
Is there a way to reset the network IP for the Synology when its booting?
