hathaer1 Posted April 10, 2016 #1 Posted April 10, 2016 Hi, I have an HP Proliant that I installed DSM 5.2 on a while ago. Everything has been running smoothly until tonight, when I tried to log on it loaded up the web assistant saying "Welcome back, we've detected that the hard drives of your current Ds3615xs had been moved from a previous DS3615xs, and installing a newer version of DSM is required before continuing". Has anyone ever encountered this? I'm not sure how to proceed as I don't want to loose all my data and setup. I can't get into the web interface to back anything up. Thanks.
sbv3000 Posted April 10, 2016 #2 Posted April 10, 2016 use Syno assistant to find out the DSM version running - your box might have automatically updates to DSM 6 and so you will need to downgrade, there are threads on the forum about how to do that
hathaer1 Posted April 10, 2016 Author #3 Posted April 10, 2016 Thanks, It says its firmware 5.2-5592 and DSM 6.0-7321. I'll look for a thread on downgrading. Cheers.
hathaer1 Posted April 10, 2016 Author #4 Posted April 10, 2016 Thanks for pointing me in the right direction, got it fixed now.
