Patrick_Nielsen Posted July 25, 2015 #1 Posted July 25, 2015 hello yestoday i installed xpenology on my computer, boot from 2gb usb and i works great.. but i problem came up it frezze/ loses the connetion.. only a hard rebot can fix it, i dont know how to fix that i bot from USB (not set as primary boot) asus motherboad, intel i3 cpu, 4x3TB wd red in raid. hope som of you can help me find the problem. the log shows InformationSystem 2015/07/25 15:10:06 SYSTEM External disk [uSB Disk 1] is mounted and shared folder [usbshare1] is exported. Warning System 2015/07/25 15:09:59 SYSTEM System booted up from an improper shutdown. Information System 2015/07/25 15:09:57 SYSTEM System started to boot up. Information System 2015/07/25 00:05:24 Patrick Package [Plex Media Server] has been successfully installed.
liukuohao Posted July 25, 2015 #2 Posted July 25, 2015 I suggest you check on your PSU. What kind of PSU you are using, if you using those crappy PSU that uses dual 12v+ rail, pay more to get a stable single 12v+ rail PSU. I am just guessing here. But I may be wrong.[emoji6] Sent from my iPhone using Tapatalk
