After much messing around I finally managed to get DS3617xs up and running quite nicely on some 8 year old hardware. I have setup Docker on it and I am trying to configure the port mapping on Docker. I found an article that allows me to do what I want...
"The config file is a json file at the location ‘ /var/lib/docker/containers/container-id/config.v2.json"
But when I PuTTY into the PC and go to /var/lib there is no docker folder to be found. Which suggests that there is another file sub system I need to be in to find this file location.
I am not that great with Linux so I am asking if someone could please give me a complete path to this fie from root.
Bad Wolf 0
TIA.
2 answers to this question
