jpbaril Posted June 30, 2015 Share #1 Posted June 30, 2015 (edited) Hi, I have Xpenology in a virtualized environment with Proxmox (KVM). I would like to use my USB audio DAC (my Mac reports it as a 2704 Burr-Brown from TI) with Audio Station. How can I do? Thank you Edited July 1, 2015 by Guest Link to comment Share on other sites More sharing options...
jpbaril Posted June 30, 2015 Author Share #2 Posted June 30, 2015 A follow up to myself. I tried to assign a USB device to my Xpenology vm using the following command. qm set 100 -usb0 host=08bb:2704 After rebooting the vm and trying to play a song, I indeed got sound out. BUT... The sound level was very low and very noisy. Worse, when Audio Station tried to play second song in queue, Diskstation webui and ssh got unresponsive. I tried to unplug the DAC and reboot the vm, but it made the host unresponsive too! I had to push and hold the power button of the machine. So it works, but no. What's wrong? I wish I could at least test it on a bare metal setup to see if Xpenology could indeed use that DAC correctly. Link to comment Share on other sites More sharing options...
jpbaril Posted July 4, 2015 Author Share #3 Posted July 4, 2015 I managed to temporarily reinstall in a bare-metal setup. The audio output with the USB DAC works correctly. So it is the virtualization that makes it not work correctly, but I'm sure there is a way. I just don't know how. Link to comment Share on other sites More sharing options...
brantje Posted September 10, 2015 Share #4 Posted September 10, 2015 I managed to temporarily reinstall in a bare-metal setup. The audio output with the USB DAC works correctly. So it is the virtualization that makes it not work correctly, but I'm sure there is a way. I just don't know how. What DAC did you use? Link to comment Share on other sites More sharing options...
jpbaril Posted September 10, 2015 Author Share #5 Posted September 10, 2015 Looks like that: http://www.ebay.com/itm/MUSE-192Khz-Coa ... 0011.m1850 Link to comment Share on other sites More sharing options...
