SMART read causing Hibernation issues
jitesh_88
Hi Guys,
i have installed XPEnology Version 5 update 5 on my ESXi box. I am using RDM for my data hard drives.
i am aware that smart is not functional in this version of XPEnology, however it is causing hibernation issues and my disks do not sleep/standby.
they wake up soon after entering hibernation.
there is nothing in the /var/log/messages escept that the smart is not able to read disk values on sda,sdb and sdc my 3 disks respectively.
is anyone else facing this problem ?
is there any workaround for it ?
scemd.log
May 2 22:27:24 DS3615xs scemd: AtaSmartRawValueGet(65) read value /dev/sda fail
May 2 22:27:24 DS3615xs scemd: AtaSmartRawValueGet(65) read value /dev/sdb fail
May 2 22:27:24 DS3615xs scemd: AtaSmartRawValueGet(65) read value /dev/sdc fail
May 2 22:27:34 DS3615xs scemd: event_disk_hibernation_handler.c:24 Fail to set disk to standby
May 2 22:27:34 DS3615xs scemd: event_disk_hibernation_handler.c:32 The internal disks wake up from hibernation.
May 2 23:29:45 DS3615xs scemd: AtaSmartRawValueGet(65) read value /dev/sda fail
May 2 23:29:45 DS3615xs scemd: AtaSmartRawValueGet(65) read value /dev/sdb fail
May 2 23:29:45 DS3615xs scemd: AtaSmartRawValueGet(65) read value /dev/sdc fail
May 2 23:29:55 DS3615xs scemd: event_disk_hibernation_handler.c:24 Fail to set disk to standby
May 2 23:29:55 DS3615xs scemd: event_disk_hibernation_handler.c:32 The internal disks wake up from hibernation.
May 2 23:48:42 DS3615xs scemd: AtaSmartRawValueGet(65) read value /dev/sda fail
May 2 23:48:42 DS3615xs scemd: AtaSmartRawValueGet(65) read value /dev/sdb fail
May 2 23:48:42 DS3615xs scemd: AtaSmartRawValueGet(65) read value /dev/sdc fail
May 2 23:48:52 DS3615xs scemd: event_disk_hibernation_handler.c:24 Fail to set disk to standby
May 2 23:48:52 DS3615xs scemd: event_disk_hibernation_handler.c:32 The internal disks wake up from hibernation.
May 2 23:59:33 DS3615xs scemd: AtaSmartRawValueGet(65) read value /dev/sda fail
May 2 23:59:33 DS3615xs scemd: AtaSmartRawValueGet(65) read value /dev/sdb fail
May 2 23:59:33 DS3615xs scemd: AtaSmartRawValueGet(65) read value /dev/sdc fail
May 2 23:59:43 DS3615xs scemd: event_disk_hibernation_handler.c:24 Fail to set disk to standby
May 2 23:59:43 DS3615xs scemd: event_disk_hibernation_handler.c:32 The internal disks wake up from hibernation.
/var/log/messages
May 2 23:33:57 DS3615xs upnpd: (upnpd.c:269) no rule to add.
May 2 23:34:01 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sda fail
May 2 23:34:01 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sda fail
May 2 23:34:01 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sdb fail
May 2 23:34:01 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sdb fail
May 2 23:34:01 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sdc fail
May 2 23:34:01 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sdc fail
May 2 23:34:02 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sda fail
May 2 23:34:02 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sda fail
May 2 23:34:02 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sdb fail
May 2 23:34:02 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sdb fail
May 2 23:34:02 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sdc fail
May 2 23:34:02 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sdc fail
May 2 23:34:02 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sda fail
May 2 23:34:02 DS3615xs SystemInfo.cgi: SmartFirmAndSerialRead(156) AtaSmartFirmAndSerialRead fail
May 2 23:34:02 DS3615xs SystemInfo.cgi: disk_lib.cpp:417 SmartFirmAndSerialRead failed
May 2 23:34:02 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sdb fail
May 2 23:34:02 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sdc fail
May 2 23:35:03 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sda fail
May 2 23:35:03 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sda fail
May 2 23:35:03 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sdb fail
May 2 23:35:03 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sdb fail
May 2 23:35:03 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sdc fail
May 2 23:35:03 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sdc fail
May 2 23:35:03 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sda fail
May 2 23:35:03 DS3615xs SystemInfo.cgi: SmartFirmAndSerialRead(156) AtaSmartFirmAndSerialRead fail
May 2 23:35:03 DS3615xs SystemInfo.cgi: disk_lib.cpp:417 SmartFirmAndSerialRead failed
May 2 23:35:03 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sdb fail
May 2 23:35:03 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sdc fail
May 2 23:36:04 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sda fail
May 2 23:36:04 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sda fail
May 2 23:36:04 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sdb fail
May 2 23:36:04 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sdb fail
May 2 23:36:04 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sdc fail
May 2 23:36:04 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sdc fail
May 2 23:36:04 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sda fail
May 2 23:36:04 DS3615xs SystemInfo.cgi: SmartFirmAndSerialRead(156) AtaSmartFirmAndSerialRead fail
May 2 23:36:04 DS3615xs SystemInfo.cgi: disk_lib.cpp:417 SmartFirmAndSerialRead failed
May 2 23:36:04 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sdb fail
May 2 23:36:04 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sdc fail
May 3 00:06:11 DS3615xs upnpd: (upnpd.c:269) no rule to add.
May 3 00:06:56 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sda fail
May 3 00:06:56 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sda fail
May 3 00:06:56 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sdb fail
May 3 00:06:56 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sdb fail
May 3 00:06:56 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sdc fail
May 3 00:06:56 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sdc fail
May 3 00:06:56 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sda fail
May 3 00:06:56 DS3615xs SystemInfo.cgi: SmartFirmAndSerialRead(156) AtaSmartFirmAndSerialRead fail
May 3 00:06:56 DS3615xs SystemInfo.cgi: disk_lib.cpp:417 SmartFirmAndSerialRead failed
May 3 00:06:56 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sdb fail
May 3 00:06:56 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sdc fail
May 3 00:06:57 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sda fail
May 3 00:06:57 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sda fail
May 3 00:06:57 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sdb fail
May 3 00:06:57 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sdb fail
May 3 00:06:57 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sdc fail
May 3 00:06:57 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sdc fail
May 3 00:06:57 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sda fail
May 3 00:06:57 DS3615xs SystemInfo.cgi: SmartFirmAndSerialRead(156) AtaSmartFirmAndSerialRead fail
May 3 00:06:57 DS3615xs SystemInfo.cgi: disk_lib.cpp:417 SmartFirmAndSerialRead failed
May 3 00:06:57 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sdb fail
May 3 00:06:57 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sdc fail
May 3 00:07:57 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sda fail
May 3 00:07:57 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sda fail
May 3 00:07:57 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sdb fail
May 3 00:07:57 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sdb fail
May 3 00:07:57 DS3615xs SystemInfo.cgi: SmartDataRead(107) read value /dev/sdc fail
May 3 00:07:57 DS3615xs SystemInfo.cgi: disk_temperature_get.c:71 read value /dev/sdc fail
May 3 00:07:57 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sda fail
May 3 00:07:57 DS3615xs SystemInfo.cgi: SmartFirmAndSerialRead(156) AtaSmartFirmAndSerialRead fail
May 3 00:07:57 DS3615xs SystemInfo.cgi: disk_lib.cpp:417 SmartFirmAndSerialRead failed
May 3 00:07:57 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sdb fail
May 3 00:07:57 DS3615xs SystemInfo.cgi: AtaSmartRawValueGet(65) read value /dev/sdc fail
  • 3 weeks later...
I dont think hibernation issue is caused by smart.
The harddisk is actually controlled by ESXi instead of Synology even you used RDM.
And there is no point to hibernate your synology when you are hosting it with ESXi.
If you want your hdd to sleep, at least you should try a dedicated SATA adapter with passthrough.
  • 3 months later...
SInce the root volume (/) is in RAID1 configuration, this kind of stuff is replicated across all your hard drive, which lead to a write of this log every minute, and prevent the system to be "idle" . This is affecting me as well. Does anyone know how to disable SmartDataRead and disk_temperature_get.c ?
  • 11 months later...
I just found out I got the same crap:
Aug 26 15:45:38 NAS SystemInfo.cgi: disk/disk_temperature_get.c:75 read value /dev/sda fail
Aug 26 15:45:39 NAS sk: SmartDataRead(108) read value /dev/sda fail
Aug 26 15:45:39 NAS sk: disk/disk_temperature_get.c:75 read value /dev/sda fail
Aug 26 15:45:51 NAS SystemInfo.cgi: SmartDataRead(108) read value /dev/sda fail
Aug 26 15:45:51 NAS SystemInfo.cgi: disk/disk_temperature_get.c:75 read value /dev/sda fail
Aug 26 15:46:33 NAS dnsdsm: Check failed. M
Aug 26 15:46:34 NAS dnsdsm: Check failed. M
Aug 26 15:46:35 NAS dnsdsm: SYSTEM:     Last message 'Check failed. M' repeated 1 times, suppressed by syslog-ng on NAS
Aug 26 15:46:35 NAS synoscgi_SYNO.Core.System.Status_1_get[6102]: external/external_buzzer_current_bitmap_get.c:20 CszBuf't get the current buzzer bitmap
Aug 26 15:46:36 NAS SystemInfo.cgi: SmartDataRead(108) read value /dev/sda fail
Aug 26 15:46:36 NAS SystemInfo.cgi: disk/disk_temperature_get.c:75 read value /dev/sda fail
Aug 26 15:46:39 NAS sk: SmartDataRead(108) read value /dev/sda fail
Aug 26 15:46:39 NAS sk: disk/disk_temperature_get.c:75 read value /dev/sda fail
Aug 26 15:47:37 NAS SystemInfo.cgi: SmartDataRead(108) read value /dev/sda fail
Aug 26 15:47:37 NAS SystemInfo.cgi: disk/disk_temperature_get.c:75 read value /dev/sda fail
Aug 26 15:47:39 NAS sk: SmartDataRead(108) read value /dev/sda fail
In my case, these are NOT disks controlled by ESX, but a HBA set pass-thru to DSM.
